Poco X3: 10bit Farbtiefe bei HDR10?
  • 1 Antworten
linuxnutzer
Enthusiast
182
Das X3 kann ja HDR10, aber kann es auch 10bit Farbtiefe darstellen?
Vielleicht etwas zur Klärung der Frage
That's why the Xiaomi Mi 10 Ultra screen is the "best in the world"
Currently most smartphones have screens with 8-bit depth: doing their math maximum color display capability is 64 times lower to that of a 10-bit depth screen. But now comes the beauty: most of the devices on the market use the technology of pixel dithering (FRC or Frame Rate Control) which allows you to change colors on the 8-bit screen for simulate the 10-bit display effect. This effect is called “8-shake-10” e it is absolutely not a native 10 bit. Xiaomi Mi 10 Ultra is equipped with a native 10-bit screen instead and it does not use the compensation argument we have just described. The difference between the two screens, 8-bit that simulate the native 10 and 1 bit, is almost imperceptible to the human eye but in reality it is not non-existent.
While in the first case (10 bit) there is a clear transition between colors, in the second case there is one multi-state color display and therefore slower. The reported effect is similar to that of 10 bit but it is only a simulation. Quite frankly, the difference is not seen and if the cost is less then so be it. But it is okay to be aware of the technology of a device since it is from what the right price to pay is calculated.
Ultimately the Mi 10 Ultra is the best as it is the only smartphone to mount a NATIVE 10-bit display.
Es ist also die Frage ob das Mi 10 das einzige 10bit-Handy ist.
U
Meerjungfraumann
Meerjungfraumann
I
MSSaar
MSSaar
c.t
