Hen Ry
Enthusiast
- 1.680
C6603: How to update to 10.4.B.0.569:
For C6603: Download C6603.flashable.10.4.B.0.569.zip (Bittorrent: 754MB) and C6603_10.4.B.0.569_Stripped.ftf (18MB), save it somewhere you remember;
Put 'C6603.flashable.10.4.B.0.569.zip' on (the external) SDcard1;
Put 'C6603_10.4.B.0.569_Stripped.ftf' inside the Flashtool/firmwares folder;
Create a backup of your phone in CWM or TWRP and don't forget to backup the contents of 'SDCard0';
Flash 'C6603.flashable.10.4.B.0.569.zip' in TWRP, do not reboot but go back to the main menu, then go to reboot->power off;
Flash everything in 'C6603_10.4.B.0.569_Stripped.ftf';
Reboot to system without clearing (dalvik-/)cache.
NEW: DE-ODEX your ROM!
Make sure you have the flashable ROM installed before you do this.
Download deodex.10.4.B.0.569.zip (Bittorrent: 370MB), save it somewhere you remember;
Put 'deodex.10.4.B.0.569.zip' on (the external) SDcard1;
Flash 'deodex.10.4.B.0.569.zip' in recovery, do not reboot but go back to the main menu;
Clear dalvik-cache ONLY;
Reboot to system.
Quelle: XDA
Reboot to system.
Quelle: XDA
