Diskussionsthread 14.3.A.0.681 (offizielle 4.4.2er)
  • 136 Antworten
20/002/2014 01:02:47 - INFO - <- This level is successfully initialized
20/002/2014 01:02:47 - INFO - Flashtool Version 0.9.13.0 built on 2013-06-04 22:50:00
20/002/2014 01:02:51 - INFO - Device disconnected
20/003/2014 01:03:27 - INFO - Device connected in flash mode
20/003/2014 01:03:30 - INFO - Flash canceled
20/003/2014 01:03:32 - INFO - Please connect your device into flashmode.
20/003/2014 01:03:33 - INFO - Opening device for R/W
20/003/2014 01:03:33 - INFO - Reading device information
20/003/2014 01:03:33 - INFO - Phone ready for flashmode operations.
20/003/2014 01:03:33 - INFO - Current device : Unknown: Nov 25 2013/21:36:17 - EP7331CAQ4 - Unknown: Nov 25 2013/21:36:17 - Unknown: Nov 25 2013/21:36:17 - Unknown: Nov 25 2013/21:36:17
20/003/2014 01:03:36 - INFO - Processing loader.sin
20/003/2014 01:03:36 - INFO - Checking header
20/003/2014 01:03:36 - INFO - Flashing data
20/003/2014 01:03:37 - INFO - Loader : S1_Root_6732 - Version : MSM8974_23 / Boot version : S1_Boot_MSM8974_LA1.04_15 / Bootloader status : ROOTED
20/003/2014 01:03:37 - INFO - Start Reading unit 000008B2
20/003/2014 01:03:37 - INFO - Reading TA finished.
20/003/2014 01:03:37 - INFO - Unlock code saved to C:\Flashtool neu\custom\mydevices\EP7331CAQ4\ulcode.txt
20/003/2014 01:03:38 - INFO - Ending flash session
20/003/2014 01:03:38 - INFO - You can now unplug and restart your device
20/003/2014 01:03:38 - INFO - Device connected in flash mode
20/003/2014 01:03:39 - INFO - Device disconnected
20/003/2014 01:03:41 - INFO - Device connected in flash mode
20/003/2014 01:03:42 - INFO - Device disconnected
20/003/2014 01:03:51 - INFO - Selected C6833 / 14.3.A.0.681 / Europe LTE
20/003/2014 01:03:51 - INFO - Preparing files for flashing
20/009/2014 01:09:43 - ERROR - 1
20/009/2014 01:09:43 - INFO - Cannot open bundle. Flash operation canceled
20/009/2014 01:09:54 - INFO - Selected C6833 / 14.3.A.0.681 / PL_1275-9426
20/009/2014 01:09:54 - INFO - Preparing files for flashing
20/011/2014 01:11:34 - INFO - Log written to C:\Flashtool neu\flashtool_2014-03-19_01-02-46.log
Der ursprüngliche Beitrag von 01:13 Uhr wurde um 01:15 Uhr ergänzt:
Die Polnische flasht jetzt gerade und hängt wieder im grünen balken ganz am Anfang..:confused2:
Time was passiert hier nur??
Der ursprüngliche Beitrag von 01:15 Uhr wurde um 01:21 Uhr ergänzt:
Polnische auch Error 1
Der ursprüngliche Beitrag von 01:21 Uhr wurde um 01:24 Uhr ergänzt:
Ich fahr den Lappi mal runter und wieder hoch, bin gleich zurück im Unglück,...
Versuch mal die FTF mit WinRAR oder einem anderen ZIP-gähigen Programm zu öffnen - check auch mal die MD5 ob die passt. Hast Du das Mega-Addin im Firefox installiert? Wenn nein, mit dem nochmal herunterladen. Mehr weis ich da auch nich, das FTF ist bei mir definitiv OK, ich habs ja selbst vorhin nochmal geflasht.
Error 1 und alles Mist...Danke erstmal Time,... schlaf später gut ich sag später was los ist, ok?! Wäre die Polnische denn ein Problem?
OK, ich bin auch gerade mit dem Einrichten fertsch geworden (136er), werd dann mal an der Matratze horchen gehen.
An sich sollte die Polnische kein Problem sein (ist vermutlich auch Europe LTE), hab ich mir allerdings nicht angeschaut.
Reaktionen: Tabbi71
Was ist no MD5 file found?
Der ursprüngliche Beitrag von 02:02 Uhr wurde um 02:03 Uhr ergänzt:
Carbon ist jetzt drauf, keine andere geht und das muss reichen bis morgen am Abend, wenn du noch ne Idee hast, lass es Tabbi wissen :D
Der ursprüngliche Beitrag von 02:03 Uhr wurde um 03:30 Uhr ergänzt:
Edit: Flashtool neu installiert und ta da, alles gut. Danke Time für deine Hilfe
Reaktionen: TimeTurn
Es ist ganz wichtig....
die NEUSTE Version von Flashtool zu verwenden: 0.9.15.0
die ist vom 15.3.2014 ohne die gehts nicht!
Das ist das einzige Problem hier gewesen :lol:
Reaktionen: Tabbi71, Topy28 und TimeTurn
Ja das hat mich fünf Stunden gekostet und dann dachte ich nehme die neue Version vom Flashtool. Weil alles andere hab ich mit Time ausgeschlossen.... Und zackig, erster Versuch war okay...:):):):):):)
Gesendet von meinem C6833 mit der Android-Hilfe.de App
Tja Tabbi mir sind da auch die Ideen ausgegangen :) - Das Einzigste was Du noch hättest versuchen können (vielleicht braucht's mal jemand): Mit Flashtool den Bootloader sperren falls offen und dann mit SUS nochmal drüberflashen. Das erkennt dann hoffentlich das schon 681 drauf ist und läd die dann auch herunter. SUS kann nämlich im Flashmode arbeiten, auch wenn das System nicht mehr hochfährt, im Gegensatz zum PC Companion, der ein hochgefahrenes stock ROM braucht.
XperiaZx schrieb:
Es ist ganz wichtig....die NEUSTE Version von Flashtool zu verwenden: 0.9.15.0 die ist vom 15.3.2014 ohne die gehts nicht! Das ist das einzige Problem hier gewesen :lol:
Guter Einwand, ich habe natürlich gleich die neuste Version installiert, als mir das Flashtool die vor ein paar Tagen angeboten hat. Habe auch gelesen, das die alte version Probleme machen soll, aber das hatte ich nicht mehr im Hinterkopf, das das mit Kitkat zu tun hat.
Außerdem hat mich irre geleitet, das er das Flashtool im Ordner "Flashtool neu" installiert hatte :flapper:
Der ursprüngliche Beitrag von 11:41 Uhr wurde um 11:55 Uhr ergänzt:
Update für 14.3.A.0.681:
14.3.A.0.681 flashen
Mit Option auf root bei offenem Bootloader:
Mit root zusätzlich:
  1. Root Kernel mit Recovery herunterladen und auf dem PC ablegen.
  2. SuperSU herunterladen und auf die Speicherkarte (!) legen
Ohne root:
  1. Das von mir erstellte (von mir aus auch ein anderes :flapper:) FTF 14.3.A.0.681 C6833 LTE Europe herunterladen.
  2. Flashtool herunterladen.
    WICHTIG! ES MUSS VERSION 0.9.15.0 ODER HÖHER SEIN! Bei älteren Versionen schlägt der Flashvorgang fehl! Das führt zwar nicht zum hard brick, aber man sucht erstmal den Fehler.
  3. Internen Speicher des Handys sichern (!!!)
  4. Handy komplett herunterfahren und ausschalten lassen.
  5. Prüfen, ob sowohl im Flashmode, als auch im Fastboot Mode die Treiber sauber installiert sind (LEISER + USB-Kabel einstecken und LAUTER + USB-Kabel einstecken). Unter Windows 8 x64 ggf. diese Anleitung benutzen.
  6. FTF in en Firmware-Ordner vom installierten Flashtool kopieren
  7. Flashtool starten
  8. Blitzsymbol clicken, Flashmode auswählen
  9. 14.3.A.0.681 Firmware auswählen
  10. Wenn Flashtool dazu auffordert, USB-Kabel bei ausgeschaltetem Handy mit gedrücketer LEISER-Taste anschließen.
  11. 14.3.A.0.681 Firmware wird geflasht.
  12. Nach Abschluß USB-Kabel abziehen
  13. Handy einschalten
  14. Wenn das Handy hochgefahren ist und der Assistent fertig ist, Backup des internen Speichers via USB-Kabel zurückspielen.
Schritt 13 und 14 könnt ihr bei root weglassen, da es dann direkt weitergeht. Mit root geht's hier weiter:
  1. USB-Kabel mit gedrücker LAUTER-Taste anstecken
  2. Im Flashtool den Blitz clicken, Fastboot mode wählen
  3. "Select Kernel to flash" wählen und das modifizierte Root Kernel auswählen (rechts unten den Typ auf .IMG umstellen) und es flashen.
    Wer es denn unbedingt will, kann das Ganze natürlich auch zu Fuß über die Kommandozeile flashen: fastboot.exe flash boot 681_jackie099.img
  4. Nach Abschluß USB-Kabel wieder abziehen
  5. Handy einschalten
  6. Wenn die LED leuchtet, LAUTER gedrückt halten, bis die LED ausgeht oder die Farbe ändert (eins von beiden, weis nicht mehr genau)
  7. Im Recovery "Install from ZIP" oder ähnlich auswählen#
  8. Wählt "Install from /storage/sdcard1" wählen und zu SuperSU-Updatexxx.zip durchhangeln und es auswählen
  9. Bestätigen, das es geflasht werden soll
  10. Wenn es geflasht wurde, ins Hauptmenü zurückkehren (Go back)
  11. "Reboot device" wählen
  12. Wenn das Handy hochgefahren ist und der Assistent fertig ist, Backup des internen Speichers via USB-Kabel zurückspielen.
  13. Eventuell müsst ihr noch busybox aus dem Play Store nachinstallieren.
Das war's :)
Reaktionen: phoenix887, compi, Topy28 und 2 andere
Sehr guter Post Time....
Was allerdings an der tollen Anleitung fehlt, wenn man sich schon die Mühe macht ist der flash Befehl:
und wie man ihn ausführt - für alle die es noch nicht wissen :love::thumbsup:
In der Anleitung wird das Boot-Image mit dem Flashtool geflasht. Hatte ich sonst auch immer drin, aber da man das Flashtool eh braucht, muss man dann nicht mit der Kommandozeile hantieren.
Habe den Punkt 3 der unteren Liste, der dies beinhaltet, noch etwas angepasst.
Ist ein full wipe nötig?
bei mir sah das so aus:
20/048/2014 13:48:34 - INFO - <- This level is successfully initialized
20/048/2014 13:48:34 - INFO - Flashtool Version 0.9.15.0 built on 15-03-2014 23:00:00
20/048/2014 13:48:39 - INFO - Device disconnected
20/048/2014 13:48:56 - INFO - Device connected in flash mode
20/049/2014 13:49:04 - INFO - Selected Bundle for Sony Xperia Z Ultra (C6833). FW release : 14.3.A.0.681. Customization : Europe LTE
20/049/2014 13:49:04 - INFO - Preparing files for flashing
20/049/2014 13:49:08 - INFO - Device disconnected
20/049/2014 13:49:17 - INFO - Device connected in flash mode
20/049/2014 13:49:31 - INFO - Selected Bundle for Sony Xperia Z Ultra (C6833). FW release : 14.3.A.0.681. Customization : Europe LTE
20/049/2014 13:49:31 - INFO - Preparing files for flashing
20/049/2014 13:49:31 - ERROR - Cannot delete C:\Flashtool\.\firmwares\prepared\system.sin
20/049/2014 13:49:31 - INFO - Cannot open bundle. Flash operation canceled
20/050/2014 13:50:02 - INFO - Please connect your device into flashmode.
20/050/2014 13:50:03 - INFO - Opening device for R/W
20/050/2014 13:50:04 - INFO - Reading device information
20/050/2014 13:50:04 - INFO - Phone ready for flashmode operations.
20/050/2014 13:50:04 - INFO - Current device : C6833 - EP7335CJHT - 1275-8026_R2C - 1274-7565_14.3.A.0.681 - EURO-LTE_14.3.A.0.681
20/050/2014 13:50:04 - INFO - Start Flashing
20/050/2014 13:50:04 - INFO - Processing loader.sin
20/050/2014 13:50:04 - INFO - Checking header
20/050/2014 13:50:04 - INFO - Flashing data
20/050/2014 13:50:04 - INFO - Processing of loader.sin finished.
20/050/2014 13:50:04 - INFO - Loader : S1_Root_6732 - Version : MSM8974_23 / Boot version : S1_Boot_MSM8974_Rhine1.2_LA1.04_12 / Bootloader status : ROOTABLE
20/050/2014 13:50:04 - INFO - Processing partition-image.sin
20/050/2014 13:50:04 - INFO - Processing of partition-image.sin finished.
20/050/2014 13:50:04 - INFO - Parsing boot delivery
20/050/2014 13:50:04 - INFO - Phone boot version : S1_Boot_MSM8974_Rhine1.2_LA1.04_12. Boot delivery version : S1_Boot_MSM8974_Rhine1.2_LA1.04_12
20/050/2014 13:50:04 - INFO - Boot delivery up to date. Nothing to do
20/050/2014 13:50:04 - INFO - Processing kernel.sin
20/050/2014 13:50:06 - INFO - Processing of kernel.sin finished.
20/050/2014 13:50:06 - INFO - Processing rpm.sin
20/050/2014 13:50:06 - INFO - Checking header
20/050/2014 13:50:06 - INFO - Flashing data
20/050/2014 13:50:06 - INFO - Processing of rpm.sin finished.
20/050/2014 13:50:06 - INFO - Processing fotakernel.sin
20/050/2014 13:50:08 - INFO - Processing of fotakernel.sin finished.
20/050/2014 13:50:08 - INFO - Processing amss_fs_2.sin
20/050/2014 13:50:08 - INFO - Checking header
20/050/2014 13:50:08 - INFO - Flashing data
20/050/2014 13:50:08 - INFO - Processing of amss_fs_2.sin finished.
20/050/2014 13:50:08 - INFO - Processing amss_fs_1.sin
20/050/2014 13:50:08 - INFO - Processing of amss_fs_1.sin finished.
20/050/2014 13:50:08 - INFO - Processing amss_fsg.sin
20/050/2014 13:50:08 - INFO - Processing of amss_fsg.sin finished.
20/050/2014 13:50:08 - INFO - Processing apps_log.sin
20/050/2014 13:50:09 - INFO - Processing of apps_log.sin finished.
20/050/2014 13:50:09 - INFO - Processing cache.sin
20/050/2014 13:50:09 - INFO - Checking header
20/050/2014 13:50:09 - INFO - Flashing data
20/050/2014 13:50:10 - INFO - Processing of cache.sin finished.
20/050/2014 13:50:10 - INFO - Processing system.sin
20/050/2014 13:50:10 - INFO - Checking header
20/050/2014 13:50:10 - INFO - Flashing data
20/054/2014 13:54:50 - INFO - Processing of system.sin finished.
20/054/2014 13:54:50 - INFO - Processing userdata.sin
20/054/2014 13:54:50 - INFO - Checking header
20/054/2014 13:54:50 - INFO - Flashing data
20/055/2014 13:55:18 - INFO - Processing of userdata.sin finished.
20/055/2014 13:55:18 - INFO - Processing elabel-C6833-row_201310161732.1_14.3.A.0.681.sin
20/055/2014 13:55:18 - INFO - Checking header
20/055/2014 13:55:18 - INFO - Flashing data
20/055/2014 13:55:21 - INFO - Processing of elabel-C6833-row_201310161732.1_14.3.A.0.681.sin finished.
20/055/2014 13:55:21 - INFO - Flashing fota-reset.ta
20/055/2014 13:55:21 - INFO - Writing TA unit : [00, 00, 09, 64, 00, 00, 00, 01, 00]
20/055/2014 13:55:21 - INFO - Flashing cust-reset.ta
20/055/2014 13:55:21 - INFO - Custumization reset is now based on UI choice
20/055/2014 13:55:21 - INFO - Ending flash session
20/055/2014 13:55:21 - INFO - Flashing finished.
20/055/2014 13:55:21 - INFO - Please unplug and start your phone
20/055/2014 13:55:21 - INFO - For flashtool, Unknown Sources and Debugging must be checked in phone settings
20/055/2014 13:55:22 - INFO - Device connected in flash mode
20/055/2014 13:55:33 - INFO - Device disconnected
hab alle häckchen bei wipe gelassen also appslog,cache,data und so hoffentlich hab ichs richtig gemacht, hab zur sicherheit nochmal auf werkeinstellung zurückgesetzt, das müsste ich jetzt eigendlich geschafft haben, also eine clean installation oder?
Nein, nicht wenn Du von einem stock ROM kommst. Ich habs auch beim zweiten Mal einfach über SUS als Update eingespielt. Wenn man es über Flashtool macht, den Haken bei "WIPE" rausnehmen.
ich hatte allerdings Probleme mit dem scheiß Google Play Diensten - die schmierten imemr weg. Dank root hab ich die aus dem System gekickt und manuell neu installiert, ebenso das Google-Konto entfernt und neu hinzugefügt, dann lief es.
Ja, müsste passen. Wenn das Handy beim hochfahren wieder den Assistenten für die Einrichtung startet, daran siehste das auch.
Sehe gerade, das Du auch den Fehler "ERROR - Cannot delete C:\Flashtool\.\firmwares\prepared\system.sin" hast - lösch den Ordner "Firmware/Prepared" falls es noch Probleme gibt.
Reaktionen: compi
also mein handy ist wieder betriebsbereit, flashvorgang war erfolgreich aber der ton bug ist nicht weg, ich glaub das es international ist :(
Was ist den neu ? Bin auf Carbon lohnt der wechsel ?
was noch nicht geht ist das xposed Framework
Sind ein paar interessante Sachen dabei. Etwa
  • ICE (In case of emergency) in den Kontakten und sogar auf dem Sperrbildschirm - Notfallkontakte
  • Prozentanzeige für den Akku in dem Batteriesymbol statt daneben
  • Neues Design
  • Launcher kann wahlweise 5x5 oder 6x6 Symbole
  • Kalender kann nun endlich Farben von Terminen darstellen, Feiertage anzeigen und auch das Wetter
  • Kamera: Auswahl zwischen 16:9 und 4:3
  • Schnelleinstellungen haben im Notification Bereich einen eigenen Button bekommen (ich fand's vorher besser, aber sei's drum)
  • Transparente Notification bar
  • Man kann wählen, welche Symbole in der Notification bar auftauchen sollen
  • Man kann Benachtichtigungen automatisch entfernen lassen, wenn man die Notification bar öffnet und wieder schließt
  • Man kann die Benachrichtigungen für jede App festlegen - konnte man zwar vorher auch, dazu musste man aber jede App im App-Manager öffnen - nun sind alle untereinander per Haken deaktivierbar.
  • Einfacher Startbildschirm - ist etwas fürs Auto, da riesige Symbole - einstellbar
Was mir so spontan aufgefallen ist.
Walkman kann übrigens immer noch nicht auf VIPER4Audio zugreifen. Mit Apollo geht's aber wie vorher auch schon.
Stimmt, Xposed Framework hab ich auch gerade wieder runtergekickt.
Reaktionen: Topy28
Wie jetzt gibt's die fw auf deutsch?
Wo kann ich diese laden? Einfach via Flashtool?
TimeTurn
  • TimeTurn
Vocalking
V
TimeTurn
  • TimeTurn
TimeTurn
TimeTurn
TimeTurn
  • TimeTurn
NIK0
