[I9300][Stock ROM] *22.12.12* I9300XXELLA [4.1.2] - BTU
  • 397 Antworten
Android56
Android56
Stamm-User
274
Reaktionen: daniel1985ffo, cccp2501, TheZero und 3 andere
Hui nice werde ich gleich flashen
Hier ein Highspeed Mirror Download
Reaktionen: dkionline und martintt
In der Rom sind bestimmt viele Änderungen enthalten Changelist 742798 die DBT hat Changelist 566833
Hallo und guten Morgen!
Wenn das jemand geflasht hat, könnte er bitte kurz ausprobieren ob die Exynos Sicherheitslücke in dieser Rom bereits gefixt wurde?
Danke
Andi
Wir kann ich das prüfen?
Hier schon der erste Erfahrungsbericht von XDA zur neuen FW....zwar auf englisch sollte aber jeder Verstehen was gemeint ist.
Okay, I came from the German (VD2) ELL5 stock ROM. I just flashed the British (BTU) ELLA. No wipe!
Positives:
1) Dialler and Contacts takes a little less time to open as compared to ELL5.
2) Shadows on icons in the app drawer aren't re-drawing like they sometimes used to (I've tried running 15+ apps at once)
3) The Recent Apps page (multi-tasker) doesn't seem to forget the most recent app any more.
4) The ROM seems generally smooth even with up to 15 applications open.
Negatives/Unresolved issues:
1) Home button to prevent screen timeout still tied to S-Voice.
2) Widgets drawer still lags.
3) Multitasking with games is still broken.
4) Launcher still redraws. Though only if you're a heavy multi-tasker or if you clear RAM.
5) One finger expandable notifications are still not present.
6) Contacts/Phone still takes a while to open.
For me, the ROM just feels more polished and smoother. I don't see the inclusion of anything new but I would definitely recommend this update since multi-tasking just feels smoother and better. We seem to be getting closer and closer to pure buttery smoothness.
Quelle:
http://forum.xda-developers.com/showthread.php?p=36173182#post36173182
http://forum.xda-developers.com/showpost.php?p=36173182&postcount=7367
Gruß "D"
Reaktionen: eagle1977 und red_guard
Und ich dachte schon wir bekommen ne Fw vom aktuellen Jahr.
Aber ein Blick auf den Code schließt das ja aus.
Geistige Umnachtung nennt man sowas.
Aber von der Beurteilung des XDAs ist die FW wohl keinen näheren Blick Wert.
Mein üblicher Gdrive folgt gleich in diesem Post.
https://docs.google.com/open?id=0B7DKa-PuA5IlLXl1bUppaWNNVTA
Reaktionen: MPille und -stephan-
Du redest wie immer ........... ohne etwas probiert zu haben.
Die FW ist absolut nicht zu vergleichen mit den 4.1.2 Vorgängern, die läuft sehr flüssig und hat eine bedeutend bessere WLAN Verbindung.
Ich kann nur jedem empfehlen sie zu flashen allein schon wegen WLAN und Akku
Zur Erinnerung das Jahr ist noch nicht mal 2 Tage alt:thumbdown:
Reaktionen: gonz81 und eagle1977
Hab keine Probl. mit W Lan und Akku usw. Deswegen ist deine Empfehlung für alle nicht richtig. Ich bleibe bei der DBT.
Ich hatte Problem und bin zurück auf die 4.1.1, und laut dem Thread zur zufriedenheit geht es mehreren so.
Aber es wird ja niemand gezwungen, kann ja jeder für sich entscheiden.
Nur etwas vom Hörensagen schlecht machen, ist einfach mies
wers braucht:
XXELLA stock-kernel: dropbox link
XXELLA stock-modem: dropbox link
einige nützliche dateien liegen auch in meinem dropbox ordner... :) darunter aktuelle stock-kernel und stock-modems für jelly bean ab 4.1.x
Edit : das neue Modem läuft perfekt, besser als das letzte Stock von Vodafone oder DBT... ausgezeichneter Durchsatz auf beiden Freq-Bändern (2.4, 5) und sprachlich besser. Die Höhen klarer. :)
Reaktionen: frank e., Gene S, BigBug und 10 andere
Bitte kein Mobbing. ^^
B2T: In meinen Augen läuft 4.1.2 jetzt schon sehr stabil, vermutlich bald oder schon besser als das pure Android.
Reaktionen: ChrisN7
Habe euer Kindergarten-Ätsch-Bätsch gelöscht.
Wenn jetzt hier nicht Ruhe ist, werde ich den Thread mal schließen.
Danke
Reaktionen: Android56 und Benny1988
Danke
Andi
Wurde gefixt steht auch auf xda.
Funktioniert die Navigation/Gps damit problemlos in Deutschland?
Nein, nur in Australien und Belgien.
Reaktionen: myreality und Benny1988
? ist das ironisch gemeint?
bei der I9300XXELKC hatte ich gps probleme hier
Gizl
Gizl
dkionline
dkionline
dkionline
dkionline
N19ht5had0w
