Holomen
Hat jemand ein Tip wo ich die Version als ZIP finde?
Ich meine damit ich sie über TWRP flashen kann.Kann auch pre-rooted sein.
Jein, und wegen dem hervorgehobenen bezweifle ich doch etwas das es auf dem S3 läuft, v.a. mit einem original ROM.Chainfire;59959596 schrieb:FlashFire is the spiritual successor to Mobile ODIN.
It's long overdue for release, but some i's still need to be dotted and some t's crossed. That being said, most of the functionality actually works well already, and it's pretty darned powerful. I have used it to update various Samsung devices from 4.x to 5.x, done (block-level!) OTAs on Nexus devices, etc.
If you're fairly tech-savvy and/or used to Mobile ODIN I suspect you won't have much trouble getting around with this app. Updates and the manual (which would be bloody useful, wouldn't it?) are coming over the next few days and weeks.
Notes and hints to help you use it:
- No kernels or recoveries are flashed for FlashFire to run, Android is torn down and restarted in a minimalist manner for the flashing part of the app to run. I'm sure this will completely fail on some devices.
- A lot(!) of memory is used, likely the entire operation will fail on low-memory devices. I strongly suggest you make an 'ID' backup as the very first test and see if that works at all.
- Technically it should be compatible with 4.2, but note virtually all of the testing so far has been done on 4.4 and 5.0 firmwares.
- SuperSU is required, unless you are running a CM-based ROM in permissive mode.
Standard Firmware (3tlg): -->i9300XXUGNG3_bitstopfen_3tlg.tar.zip (directlink)<--
Es gab da mal einen Geheimtipp bei Foren: lesen, v.a. den ersten Beitrag.bitstopfen schrieb:1.2 Downloads:
Hoster:
mit factory reset (zurücksetzen auf Werkseinstellung)
- Standard Firmware (3tlg): -->i9300XXUGNG3_bitstopfen_3tlg.tar.zip (directlink)<--
- prerooted Firmware Hinweis: wer sein Gerät rootet, verliert die Herstellergarantie (3tlg): -->i9300XXUGNG3_root_bitstopfen_3tlg.zip (directlink)<--
- Einzeldownload Modem: -->CP_I9300XXUGNA8_bitstopfen.tar.md5 (directlink)<--
________
Passwort:
android-hilfe.de
Uids on the System are Inconsistent -> [I'm feeling Lucky]
Ob ich es in den nächsten Tagen software bedingt reparieren kann, wird sich zeigen.
