[I9300][Stock ROM] *01.02.13* I9300XXEMR2 [4.1.2] - DBT
  • 216 Antworten
myreality
myreality
Enthusiast
3.898
[Stock ROM] 4.1.2 I930XXEMR2
Base Firmware: I9300XXEMR2
Modem: I9300BUEMA1
CSC: I9300VFREMA3
Build Date: 01.02.2013
Changlist: 919627
Version: 4.1.2
Regions: Germany Vodafone (VD2)
Download:
Firmware (Odin) : Hotfile.com: 1-CLICK Dateihoster: Samsung-Updates.com-GT-I9300-VD2-I9300XXEMR2-1359696036.zip
download - filecloud.io
https://docs.google.com/file/d/0BxQZqZhVTRx-OGVYX0JDVGFwY2s/edit?usp=sharing&pli=1 (Dank an TheZero)
Modem (Dank an extralife): https://www.android-hilfe.de/forum/...mr2-4-1-2-dbt.375085-page-2.html#post-5116016
Anleitung zum flashen:
  • Extrahiere die Firmware
  • Starte Odin
  • Gehe in den Downloadmode (Home + Volume Down + Power)
  • Verbinde dein S III mit dem Computer, ID:COM muss nun blau aufleuchten (bei Odin 3.04)
  • Klicke auf PDA und füge die *.tar.md5 dort ein
  • Klicke dann auf Start
Nicht ausführlich genug, dann gehts für Dich [OFFURL="https://www.android-hilfe.de/anleitungen-fuer-samsung-galaxy-s3/251286-anleitung-mit-odin-das-siii-flashen.html"]HIER weiter [/OFFURL];)
Änderungen laut DeadSOL
Differences:
1) Extra applications: Appselect, Discover, and Updates can be disabled. Music Shop and My Web can be uninstalled.
2) Notification Panel: It has a different background in Settings only. That's it! The actual notification panel is still the same.
3) Cloud: New Cloud option in the Settings menu. Allows you to sync pictures and videos to Dropbox. The only way to disable it is to unlink your device from Dropbox once you register.
Positives
1) Contacts/Phone: They open up quicker than EMA2 (as fast as ELLC/ELLA). Somehow, they were slow again in EMA2.
2) Touchwiz Redraw: Redraw is quite fast (clear RAM and see).
3) NFC Toggle Bug: Fixed!
4) Landscape mode: I don't use it much except for pictures so can someone check if "Phone" allows landscape mode on a previous firmware? Because a lot of applications seem to support landscape mode now.
Negatives/Unresolved issues/Bugs:
1) Home button to prevent screen timeout still tied to S-Voice.
2) Widgets drawer still has the initial lag.
3) Multitasking with games is still broken. You can't run two or more medium/heavy games in the background. One of them eventually restarts (if not instantly).
4) Launcher can still redraw. The redraw is instantaneous!
5) One finger expandable notifications are not present.
6) Contacts/Phone doesn't open instantaneously.
7) Shadow redraws on Touchwiz icons are still present (they occur a lot less frequently now).
8) The Recent App tabs may still forget your most recent app (it occurs less frequently now).
9) When recording a video, left and right audio is switched.
Recommended or not?:
Your choice. The higher changelist is probably due to the inclusion of the Cloud storage. All it does is sync pictures and videos with Dropbox (which you can already do). There's nothing special about the ROM, as far as I can see. If the positives appeal to you, flash i
Reaktionen: craP_cillA, heavymetall66, Akelschnakel und 2 andere
Na, da bin ich mal auf die ersten Erfahrungen gespannt.
Die Changelist hat ja einen richtigen Sprung gemacht.
Dann kann ja langsam mal die DBT kommen. Geht ja jetzt Schlag auf Schlag.
Hast Du sie schon runter geladen und reingeschaut, ob ein Bootloader enthalten ist?
Taper di Tap with my S3 @206 days
Bisher war in jedem 4.1.2 ein Bootloader dabei und das immer mit Single CSC.
Ja, aber da es von VF schon eine 4.1.2 gab und diese schon einen BL drin hatte, macht es in meinen Augen keinen Sinn schon wieder einen BL rein zu packen. Das Flashen eines BL birgt ja auch immer ein gewisses erhöhtes Risiko.
Will ich mir auch nicht an tun, bis ich nämlich 825 MB bei Hotfile heruntergeladen habe vergeht gefühlt ein Jahr :lol:
Gibt wohl auch noch ne spanische.
Bootloader ist mit drin. Dual CSC VD2/ATL.
Kann ich die einfach über die MA2 flashen? Hab ein freies Gerät mit ner Vodafone Sim....
Die FW hat ja sogar ne noch höhere changelist als die asiatische die gestern erschienen ist.
Speed mit hotfile ~200kb/s
Ausm XDA Speed ~800kb/s
http://filecloud.io/ag7uj0tn
ja einfach drüber flashen ;)
Werd ich dann gleich mal machen. Ist da ein "spezielles" neues vodafone Modem drin? Hab mir bei der MA2 nachträglich das XXELLA Modem drauf gemacht...
Bitte auf den laufenden halten sobald eine Mod fürs multiview kommt^^
Sorry für OT, aber vielleicht geht es ja nicht nur mir so.
Das ist es was ich auch einfach nicht verstehe.
Wenn die Provider es schaffen, wieso bekommt Samsung selber es nicht auf die Reihe?
Wenn die Provider es schon bekommen haben, was ist daran so schwer es auch für die Geräte ohne Branding herauszugeben?
So nun habe ich genug gequängelt.
Sorry noch einmal für mein OT.
das versteh ich aber allerdings auch nicht...
Wir wissen nicht, welche Verträge Samsung mit den Providern hat. Eventuell haben die Provider ja Vorzugsrechte, weil die Abnahmemenge wesentlich höher ist.
Ist doch schön, dass Samsung wenigstens das Versprechen hält.
Mit der Induktionsladung und dem neuen Akku falen sie ja wieder in ihre ales Form zurück.
auf jedenfall ist der . bug nicht mehr vorhanden
und keine vodafone boot animation vorhanden
dafür ne menge bloatware
Reaktionen: TheZero
Habe mit der XXEMR2 das erste mal Probleme mit CF Auto root.
(SUpersu wird nicht installiert)
Hat es bei irgendjemand geklappt?
Mir kommt vor, hab mal wo gelesen einfach SuperSu ausm Market installieren, dann sollte es funktionieren.
