SavanTorian
Ehrenmitglied
- 7.196
dropbox is big in business. will gar nicht wissen, was sie an "sponsorengeldern" einstecken
Spawnhl schrieb:Ich habe S Voice ausgeschaltet und gerade deshalb hab ich auch den Bug, dass wenn der Screen Timeout mit der Home Taste beendet wird der Homescreen angezeigt und nicht die laufende App.
Oder gibts da schon eine Lösung?
DeadSOL schrieb:Right. So, I was previously on the French EMA2 firmware. I've flashed the latest German EMR2. No wipe.
Differences:
1) Extra applications: Appselect, Discover, and Updates can be disabled. Music Shop and My Web can be uninstalled.
2) Notification Panel: It has a different background in settings. That's it.
3) Cloud: New Cloud option in the Settings menu. Allows you to sync pictures and videos to Dropbox. The only way to disable it is to unlink your device from Dropbox.
Positives:
1) Contacts/Phone: They open up quicker than EMA2 (as fast as ELLC/ELLA). Somehow, they were slow again in EMA2.
2) Touchwiz: Redraw is quite fast (clear RAM and see).
3) NFC Toggle Bug: Fixed!
Negatives/Unresolved issues/Bugs:
1) Home button to prevent screen timeout still tied to S-Voice.
2) Widgets drawer still has the initial lag.
3) Multitasking with games is still broken. You can't run two or more medium/heavy games in the background. One of them eventually restarts (if not instantly).
4) Launcher can still redraw. Although it is a lot quicker to redraw itself.
5) One finger expandable notifications are not present.
6) Contacts/Phone doesn't open instantaneously.
7) Shadow redraws on Touchwiz icons are still present (they occur a lot less frequently now).
8) The Recent App tabs may still forget your most recent app (it occurs less frequently now).
9) When recording a video, left and right audio is switched.
Recommended or not?:
Your choice. The higher changelist is probably due to the inclusion of the Cloud storage. All it does is sync pictures and videos with Dropbox (which you can already do). There's nothing special about the ROM, as far as I can see. If the positives appeal to you, flash it.
BlackSmokah schrieb:Lässt sich ausschalten wie es bei dieser FW weis ich nicht da sie direkt überall integriert ist :3
bastilein schrieb:cool super gleich flashen
