[Android 2.3.6][Frankenstein] I9100XILA2~mit OXXKJ2 CSC Modul ~ non official~
  • 91 Antworten
BLN(!) für stock SMS, sorry die Info war wichtig :D
@Nightly.
was würdest du meinen, könnte nicht auch ein FIX für die XXKL1
für XILA2 laufen, denn den gäbe es ja bei XDA.
Nur mal so angemerkt, bin mir jedoch nicht sicher.
@DeathMetal
du könntest VORHER ein Nandroidbackup machen und es dann testen.
Hellcat's Root Kernel unterstützt- neben vielen anderen Features - BLN,ich würde da nicht mehr als nötig herumbasteln ;)
Features
Root
Kernel comes "instant rooted", after flashing this kernel your system is completely rooted (su, busybox and the Superuser app).
Nothing more needs to be done, totally newb friendly
MULTIPLE Recoveries!
By default this kernel will run ClockworkMod 5.0.2.3 when booting into recovery.
You can, however, set an option to boot two other recoveries:
Create a file "opt.recovery.cwm4" in /sdcard to get ClockWorkMod Recovery 4.0.1.4 when booting to recovery.
Create a file "opt.recovery.stock" in /sdcard to get original stock (e3) recovery when booting to recovery.
Content of the files doesn't matter, a 0-byte size is good enough already, it just needs to exist and have the above stated names.
ADB with root priv's in recovery mode
When booted into recovery mode you have ADB available to connect to from your PC.
ADB also runns with full root priv's in recovery mode for all your haxx'n'tinker needs (in normally booted OS mode ADB still runns "secure" with only user priv's, use su to get root there)
Custom boot scripts
There is some bootscripts you can put your own commands in for being executed during boot.
The scripts are /system/bootrc.sh and /data/bootrc.sh.
Additional modules natively supported and loaded on boot
The original plan was to integrate these into the kernel, but due to hitting size limits of the zImage I decided to have them loaded from external directories.
Currently supported modules: (these modules are compiled together with the kernel and are included in the download!)
- slow-work.ko (not needed on Android 2.3.4 FWs, like XXKG2, e.t.c.)
- cifs.ko
If these modules are present in either /system/lib/modules or /data/lib/modules they will be automatically loaded at boot and are available to use (for example in case of CIFS, just get CifsManager from the marketplace and start mounting your shares)
Custom Bootanimation and Bootsound
This kernel also supports using a custom bootanim (bootanimation.zip) and bootsound (PowerOn.wav).
To install, simply create a folder "import" on in your /sdcard and drop your files into it, i.e.:
/sdcard/import/bootanimation.zip -> for bootanimation
/sdcard/import/PowerOn.wav -> for bootsound
If either one of those is present upon the next boot they will automatically be installed to the correct path and be available.
Custom Boot-LOGO !
This let's you change the logo shown BEFORE the bootanimation (usually the "Samsung Galaxy SII" splash screen).
Similar to the bootanim and -sound, copy the desired logo.jpg (480x800, max. 100k) to:
/sdcard/import/logo.jpg
Upon the next boot the new bootlogo will be installed!
Please read the additional note about installing a new bootlogo bellow!
BLN support
This kernel has BLN (=BackLight Notification) support!
Just install the BLN Pro App from the market (to actually use/get the notification lights you need the paid version, the free version only lets you test if BLN works propperly) and off your blinkieness goes
Touchscreen Sensitivity Fix
vitalij's touchscreen fix to make the touch more responsive again when performing movements on the screen.
init.d support
If you got a lot of shell scripts you want to have executed during boot, just drop them in
- /system/etc/init.d
or
- /data/etc/init.d
Everything put into those directories will be executed during boot
Es geht mir nicht um BLN. Hab den Siyah Kernel seit eh und je, aber eben nicht für Stock SMS...
Stock SMS ? ...hm,da müsstest Du wohl etwas auf smali Level hacken und eine modifizierte liblights verwenden, denke ich ...
Alternative: Tasker, BLN Pro und
Profil: Received SMS
Event: Received SMS
Task: A1: BLN - LED-Trigger [ configuration:LED = enabled] If [ %PENABLED !~ *BLN Sms Off* ]
A2: Profil Status [ Name:BLN Sms Off set:On]
Profil: BLN Sms Off
App: Messages
Task: A1: BLN - LED-Trigger [ Configuration:LED = disabled]
A2: Profil Status [ Name:BLN Sms Off set:Off]
Profil: Missed Call
Status: missed call *
Time: from 06:00 till 23:59
A2: Profil Status [ Name:BLN Call Off set:On]
Profil: BLN Call Off
App: telefon
Task: A1: BLN - LED-Trigger [ configuration:LED = disabled]
A2: Profil Status [ Name:BLN Call Off set:Off]
ich denke, hier wird dir direkt gehelft :D
Ganz genau. Gibt immer wieder Leute, die die bibliothek anpassen und sowas zur Verfügung stellen. Hatte ich fürs KI3 lange in Benutzung. Für die neue LA2 aber noch nicht gefunden.
Geb ich nicht mehr her und ist mir den Akku Drain auch wert.
Akku Drain ? ...kenne ich nicht :D (dank vernünftigem, ausgewogenem Energie Management :flapper:)
Gegen den Akku Mehrverbrauch durch BLN kannst du aber rein garnix machen und von dem habe ich gesprochen
Sehe ich das so richtig. Ich lade mir diese Datei aus dem Startpost:
XILA2 deodexed: Multiupload.com - upload your files to multiple file hosting sites!
Credits: R3MOR3MA
Dann habe ich diese Feature:
Features:
-stock rom
-rooted
-busybox
-zipaligned
-ClockworkMod Recovery 5
-CF-root
Und sind dann auch die Sachen drin wie sie dadrüber stehen?
Diverse Bugs wurden - angeblich- beseitigt, welche bei der KK1 (und folgenden FW´s) noch vorhanden waren.
Android 4.0 styled Lockscreen ^^ vergleichbar mit dem Lockscreen des Galaxy Note
Wi-Fi Chip Bug der KK1 wurde augenscheinlich gefixt
pre rootet mit: CF-Root XXLA2
CWM v.5 (Credits: Chainfire)
JIG freundlich durch die KI3 Bootloader :p
ICS styledLock Screen und Message Notification
@LaBro
das ist genau richtig.
Reaktionen: LaBro83
Die wird aber über das Recovery geflasht oder? Bin gerade durcheinander:blink:
nein Odin in PDA
Ist aber eine ZIP Datei die geladen wurde. Daher auch meine Frage
Moin,
will ungern widersprechen, aber...
@LaBro83
die Frankenstein XILA2 deodexed ist ZIP und wird über die CWM installiert :thumbup:
es gibt bereits eine XWLA4;)
Wahrscheinlich aus Slowenien.
Ist aber eine Provider Firmware eigentlich und unterschied gibt es laut XDA auch keinen großen von daher kann man bei der xila2 bleiben.
habe mich nun in die Materie reingelesen und Mein S2 gerootet.Dann die 2.3.6 Firmware aufgespielt,alles schön.Kann mir jemand sagen,welche Theme damit läuft?Hatte 2 Themen probiert,danach kommt,wenn man telefonieren will immer eine Fehlermeldung.
danke
Nightly
obicom
obicom
Nightly
Reddy
Reddy
Nightly
Nightly
Nightly
