[Firmware][2.3.6][29.12.2011] I9000XXJVU - [VALUE PACK] - ODIN / ROOT
  • 478 Antworten
Bin grad beim Flashen, sieht schon mal gut aus. [:
Screenshots:
Änderungen:
Galaxy Note Lockscreen
Face Unlock (wie bei ICS)
Galaxy S2 Photo Editor
320 Mb RAM
Man kann nun in der Kamera-App während des filmens Bilder machen. o.O
Der Browser ist auch um einiges schneller und flüssiger.
build.prop
# begin build properties
# autogenerated by buildinfo.sh
ro.build.id=GINGERBREAD
ro.build.display.id=GINGERBREAD.XXJVU
ro.build.version.incremental=XXJVU
ro.build.version.sdk=10
ro.build.version.codename=REL
ro.build.version.release=2.3.6
ro.build.date=Thu Dec 29 16:42:13 KST 2011
ro.build.date.utc=1325144533
ro.build.type=user
ro.build.user=se.infra
ro.build.host=SEI-22
ro.build.tags=release-keys
ro.product.model=GT-I9000
ro.product.brand=samsung
ro.product.name=GT-I9000
ro.product.device=GT-I9000
ro.product.board=GT-I9000
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.manufacturer=samsung
ro.product.locale.language=en
ro.product.locale.region=GB
ro.wifi.channels=
ro.board.platform=s5pc110
# ro.build.product is obsolete; use ro.product.device
ro.build.product=GT-I9000
# Do not try to parse ro.build.description or .fingerprint
ro.build.description=GT-I9000-user 2.3.6 GINGERBREAD XXJVU release-keys
ro.build.fingerprint=samsung/GT-I9000/GT-I9000:2.3.6/GINGERBREAD/XXJVU:user/release-keys
# Samsung Specific Properties
ro.build.PDA=I9000XXJVU
ro.build.hidden_ver=I9000XXJVU
ro.build.changelist=851880
ro.flash.resolution=720
# end build properties
# system.prop for smdkc110
rild.libpath=/system/lib/libsec-ril.so
rild.libargs=-d /dev/ttyS0
ro.sf.lcd_density=240
dalvik.vm.heapsize=64m
ro.opengles.version=131072
# Samsung USB default mode
persist.service.usb.setting=0
# ADDITIONAL_BUILD_PROPERTIES
ro.config.ringtone=01_Minimal_tone.ogg
ro.config.notification_sound=01_Sherbet.ogg
ro.config.alarm_alert=Good_Morning.ogg
ro.url.legal=http://www.google.com/intl/%s/mobile/android/basic/phone-legal.html
ro.url.legal.android_privacy=http://www.google.com/intl/%s/mobile/android/basic/privacy.html
ro.com.google.locationfeatures=1
ro.setupwizard.mode=DISABLED
ro.com.google.gmsversion=2.3_r7
wifi.interface=eth0
wifi.supplicant_scan_interval=15
ro.secdevenc=true
ro.error.receiver.default=com.samsung.receiver.error
keyguard.no_require_sim=true
ro.com.android.dateformat=MM-dd-yyyy
ro.com.android.dataroaming=true
ro.ril.hsxpa=1
ro.ril.gprsclass=10
ro.config.notification_sound=OnTheHunt.ogg
ro.config.alarm_alert=Alarm_Classic.ogg
media.stagefright.enable-player=false
media.stagefright.enable-meta=false
media.stagefright.enable-scan=false
media.stagefright.enable-http=true
media.stagefright.enable-rtsp=false
dev.sfbootcomplete=0
dalvik.vm.dexopt-flags=m=y
net.bt.name=Android
dalvik.vm.stack-trace-file=/data/anr/traces.txt
@philippsp
Von welcher FW kommst du? Kannst du bitte nachsehen, wenn du geflasht hast, ob es wieder den QWERTY-Bug hervorruft bzw. schon von vorhersagen, ob es den geben wird, wenn ich von der JW1 mit der DBT-CSC der offiziellen 2.3.3 komme?
@Charly Harper Mein Download ist bei 85 %. Ich komme auch von JW1! Ich werde alles testen und dann berichten.
_______________________________________________________________________________________________________
Edit: So, hab jetzt geflasht. Der QWERTY Bug ist bei mir vorhanden und man hat 320 MB Ram. O.O
Face Unlock funktioniert bei mir ausgezeichnet!
Zum Rooten kann man einfach den Semaphore JW1 Kernel Flashen.
NEWS: Chainfire's CF-Root for JVU coming soon...
Reaktionen: Charly Harper
Hattest du die DBTJV2 (CSC) bei deiner JW1 vorher drauf?
Auch auf Deutsch verfügbar & für den privaten Gebrauch zu empfehlen?
@charly
flash doch einfach mal, dann weißt du es :)
so mach ichs auch...
vorher aber nandroid machen ;)
-tapatraced-
Gewiss, ich könnte es selbst flashen, aber philippsp hat sich dazu bereiterklärt, es vor mir zu flashen. Ich war bei der JVZ einer der ersten, habs bereut. Insofern danke ich philippsp und evtl. auch dir, der du ja auch gerade im Begriff bist zu flashen und mir vielleicht meine Frage zu beantworten bereit bist? Es wär' mir ein "Danke" wert :)
ja klar, gleich weiß ich mehr.
...und du auch ;)
-tapatraced-
Nein ich hatte die Multi CSC von der JVT drauf. :]
Der Cf-root funktioniert bei mir einwandfrei. :]
Gesendet von meinem GT-I9000 mit Tapatalk
kein querty-bug vorhanden, alles schööön :)
Hab etwas herausgefunden: Wenn man bei Sprache Deutschland (Österreich) auswählt ist der Bug vorhanden, sonst nicht.
ok aber das wählt ja kein deutscher :cool2:
ich verstehe jetzt mal nicht so ganz. ist das jetzt die 2.3.6 mit einigen ICS features
weil ja eigentlich das value pack ja 4.0.3 sein sollte oder nicht?
Hab sie jetzt seit ungefähr einer Stunde am laufen und wollte mal ein paar Dinge schildern die mir aufgefallen sind bis jetzt.
1. Die Firmware ist wahnsinnig schnell!!!
2. Faceunlock funktioniert sehr gut, besser als in der ICS beta von Onecosmic,
allerdings ist der Einrichtungsassistent von Faceunlock auf englisch.
3. Standard lockscreen ist jetzt der selbe wie beim Galaxy note, mir gefällt er nicht aber ist Geschmackssache.
4. QWERTY Bug ist bei mir nicht vorhanden.
5 Google Talk ist immer noch ohne Videochat Funktion!
6. Browser Läuft meiner Meinung nach etwas flüssiger.
Wenn das von den Features her wirklich das Finale Value Pack sein soll dann komm ich mir ziemlich verarscht vor von Samsung
So jetzt aber ab ins bettchen :)
Reaktionen: SlntBob und kurt_c_hose
Ich glaube, das 'Value Pack' ist in der ersten Aufregung des OPs auf xda entstanden. :)
Dies müsste doch älter sein als die JW1 oder ? Der Value Pack ist zwar dabei, aber die entwickelte GB FW an sich ist älter. Wahrscheinlich werden neuere Versionen mit Value Pack kommen.
Was meint Ihr ?
