[Firmware][2.3.6][29.12.2011] I9000XXJVU - [VALUE PACK] - ODIN / ROOT
  • 478 Antworten
Wenn die Rom älter ist, lohnt sich dann überhaupt der Umstieg von der JV1?
Gesendet von meinem GT-I9000 mit Tapatalk
1.1 Firmware-Details:
Android-Version: 2.3.6
Firmwaretyp: 3-File Firmware
PDA: I9000XXJVU
MODEM: I9000XXJVU
CSC: I9000OXAJVU - [CPW] [DBT] [KOR] [XEO] [XEU]
Build date: Thu Dec 29 16:42:13 KST 2011
Change List: 851880
RAM: 320 MB
1.2 build.prop
# begin build properties
# autogenerated by buildinfo.sh
ro.build.id=GINGERBREAD
ro.build.display.id=GINGERBREAD.XXJVU
ro.build.version.incremental=XXJVU
ro.build.version.sdk=10
ro.build.version.codename=REL
ro.build.version.release=2.3.6
ro.build.date=Thu Dec 29 16:42:13 KST 2011
ro.build.date.utc=1325144533
ro.build.type=user
ro.build.user=se.infra
ro.build.host=SEI-22
ro.build.tags=release-keys
ro.product.model=GT-I9000
ro.product.brand=samsung
ro.product.name=GT-I9000
ro.product.device=GT-I9000
ro.product.board=GT-I9000
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.manufacturer=samsung
ro.product.locale.language=en
ro.product.locale.region=GB
ro.wifi.channels=
ro.board.platform=s5pc110
# ro.build.product is obsolete; use ro.product.device
ro.build.product=GT-I9000
# Do not try to parse ro.build.description or .fingerprint
ro.build.description=GT-I9000-user 2.3.6 GINGERBREAD XXJVU release-keys
ro.build.fingerprint=samsung/GT-I9000/GT-I9000:2.3.6/GINGERBREAD/XXJVU:user/release-keys
# Samsung Specific Properties
ro.build.PDA=I9000XXJVU
ro.build.hidden_ver=I9000XXJVU
ro.build.changelist=851880
ro.flash.resolution=720
# end build properties
# system.prop for smdkc110
rild.libpath=/system/lib/libsec-ril.so
rild.libargs=-d /dev/ttyS0
ro.sf.lcd_density=240
dalvik.vm.heapsize=64m
ro.opengles.version=131072
# Samsung USB default mode
persist.service.usb.setting=0
# ADDITIONAL_BUILD_PROPERTIES
ro.config.ringtone=01_Minimal_tone.ogg
ro.config.notification_sound=01_Sherbet.ogg
ro.config.alarm_alert=Good_Morning.ogg
ro.url.legal=http://www.google.com/intl/%s/mobile/android/basic/phone-legal.html
ro.url.legal.android_privacy=http://www.google.com/intl/%s/mobile/android/basic/privacy.html
ro.com.google.locationfeatures=1
ro.setupwizard.mode=DISABLED
ro.com.google.gmsversion=2.3_r7
wifi.interface=eth0
wifi.supplicant_scan_interval=15
ro.secdevenc=true
ro.error.receiver.default=com.samsung.receiver.err or
keyguard.no_require_sim=true
ro.com.android.dateformat=MM-dd-yyyy
ro.com.android.dataroaming=true
ro.ril.hsxpa=1
ro.ril.gprsclass=10
ro.config.notification_sound=OnTheHunt.ogg
ro.config.alarm_alert=Alarm_Classic.ogg
media.stagefright.enable-player=false
media.stagefright.enable-meta=false
media.stagefright.enable-scan=false
media.stagefright.enable-http=true
media.stagefright.enable-rtsp=false
dev.sfbootcomplete=0
dalvik.vm.dexopt-flags=m=y
net.bt.name=Android
dalvik.vm.stack-trace-file=/data/anr/traces.txt
1.3 Anmerkungen:
1. Diese Firmware ist der erste Leak einer Firmware, die das von Samsung angekündigte "Value Pack" enthält. Erwartet keine Wunder. Bugs und kleinere Fehler sind absichtlich integriert ;-) (Siehe 7. Probleme). Das "Value Pack" soll eine Art Schadensersatz herhalten, da Samsung kein Update auf Android 4 (ICS) für das SGS bringen wird und soll aus diesem Grund einige Features imitieren.
2. Neue Features des Value Packs in diesem Build:
NEU: Galaxy Note Lockscreen
NEU: Face Unlock
NEU: Photo Editor
Improved: Schnellerer Browser
Improved: Neue Kamera-App mit neuem Design und neuen Features. Diese läuft um einiges schneller als die bisherige Kamera-App und erlaubt die Aufnahme von Photos während einer Videoaufname.
Improved: Autorotation wurde verbessert.
Improved: Im xda-thread berichten mehrere User ein verbessertes GPS-Verhalten. -> Bestätigung benötigt
3. Verschiedene Kernels und deren Kompatibilität könnt ihr im Kernel-Sammelthread von Apple.griebsch nachlesen. Vielen Dank!
2.1 Voraussetzungen zum flashen via Odin (für unerfahrene flasher/ innen):
1. Ihr habt die FAQ gelesen und verstanden!
2. Ihr habt einen funktionierenden 3-Button Mode. - Hier gehts weiter, wenn er nicht geht.
3. Ihr habt alle Lagfixes vorher deaktiviert, oder hattet nie welche installiert.
4. Ihr habt eine Sicherung des /efs/ Ordners. - Wie mache ich das?
5. Ihr habt den Unterschied der verschiedenen Firmwaretypen verstanden. - Es gibt verschiedene Firmwaretypen?
6. Ihr habt ein voll geladenes Galaxy S i9000
7. Ihr habt die FAQ gelesen und verstanden!
8. Ihr habt Hoden aus Stahl und Nerven wie Brückenpfeiler! Ja, auch Ihr weiblichen Wesen! ;-)
2.2 Wichtige Anmerkung zum Update Froyo (2.2.x) > Gingerbread (2.3.x)
Ihr benötigt die Gingerbread Bootloader! Solltet ihr bisher noch Android 2.2.1 auf dem Handy haben, müsst Ihr die Firmware MIT Bootloadern flashen, sofern eine ohne Bootloader angeboten wird. Solltet ihr bereits Android 2.3.x (JV*) auf eurem Telefon haben, könnt ihr auch die Version OHNE Bootloader flashen! Gerade beim Update von 2.1 / 2.2 / 2.2.1 wird ein Factory Reset nach dem erfolgreichen flashen empfohlen um das System von resten der alten Firmware zu bereinigen! Dieser führt zu Verlust der persönlichen Einstellungen. Inhalte der internen/externen SD werden hierbei NICHT gelöscht!
3. Flashanleitung JVU
- Diese Anleitung gilt grundsätzlich sowohl für die Version MIT Bootloadern als auch für die Version OHNE Bootloader (sofern überhaupt eine ohne Bootloader angeboten wird. In keinem Fall wird in Odin der Haken "Phone Bootloader Update" gesetzt!
Alles was Ihr ab jetzt macht erfolgt auf EIGENE GEFAHR! Weder ich noch android-hilfe.de übernehmen Verantwortung für einen möglichen Brick eures Handys!
Achtung! Es muss jedem klar sein, dass ihr durch das flashen dieser Firmware euer Providerbranding (incl. ProductCode) entfernt und Ihr erhaltet eine Firmware (und damit auch den ProductCode) eines freien Gerätes (welche fast immer aktueller sind). Vor dem entfernen des Branding solltet Ihr auf jeden Fall euren efs-Ordner gesichert haben! Dieser Vorgang kann, sofern das Gerät keinen Hardwareschaden hat, jederzeit durch flashen einer gebrandeten Firmware wieder rückgängig gamcht werden! Besitzer eines gebrandeten Gerätes sollten nach dem flashen unbedingt Punkt 3.1 beachten!
1. Herunterladen und entpacken der 3-File-Firmware.
2. Starte Odin 1.3 (Und schliesse Kies vorher, falls geöffnet. Es ist wichtig ODIN zu öffnen, bevor das Telefon verbunden wird!)
3. Wähle die PDA = CODE , MODEM = PHONE und CSC = CSC aus dem heruntergeladenen Paket.
4. Auch diese Firmware kann mit repartition und 512er PIT geflasht werden. Dieses ist nötig, wenn ihr momentan ein CM7/CM9/MIUI oder ein anderes Custom-Rom installiert habt!
5. Boote das SGS in den DownloadMode durch drücken und halten von VolumeDown+Home+Power.
6. Verbinde erst jetzt das Telefon mit dem Rechner und warte das die Treiber installiert werden.
7. Wenn die Treiber fertig installiert wurden, erscheint oben links in Odin ein gelbes Symbol.
8. Drücke Start um den Flashvorgang zu starten. Entferne das USB-Kabel nicht, bis das Telefon erfolgreich ganz hochgefahren ist. Dieses kann auch 10-15 Minuten dauern! Geduld haben! Sollte es in einer Startschleife hängen, nehmt einfach "brutal" den Akku raus und macht mit Schritt 8 direkt weiter!
9. NICHT ZWANGSLÄUFIG NÖTIG, ABER DRINGEND EMPFOHLEN. Schaltet das Telefon ab, bootet in den RecoveryModus, und führt einen FactoryReset und einen CasheWipe aus! Dieser löscht alle persönlichen Daten (die Inhalte der internen und externen SD ausgenommen) aber löscht auch alle übrigen Reste der alten Firmware und sorgt für ein sauberes und schnelles System!
10. Reboot, Fertig!
3.1 Der folgende Teil ist nur für Benutzer mit gebrandeten Geräten, oder die, die sich nicht sicher sind!
11. Kontrolliert nach dem erfolgreichen flashen euren ProductCode durch Eingabe von *2767*4387264636# in die Telefontastatur! Sollte dieser mit DBT aufhören, ist alles gut, und ihr braucht NICHT mit Schritt 12 fortzufahren!
12. Wenn nun aber die letzten 3 Stellen eures ProductCodes nun KOR lauten gebt *#06# in eure Telefontastatur ein und notiert euch nun die angezeigte IMEI.
13. Verlasst das angezeigte Fenster und gebt nun *#272*???????????????# in eure Telefontastatur ein, wobei ihr die ??? durch eure eben notierte IMEI ersetzt.
14. Im folgenden Fenster wählt ihr DBT aus und klickt unten auf INSTALL. Dadurch wird euer falscher ProductCode KOR auf den, für deutsche ungebrandete Geräte DBT gesetzt. ACHTUNG! Hierbei wird ein FactoyReset durchgeführt!
15. Reboot abwarten, Fertig!
4. Root & CWM via CF-root:
1. CF-Root-XX_OXA_JVU_2.3.6-v4.3-CWM3RFS.zip herunterladen und entpacken.
3. Wähle die entpackte .tar als PDA aus. Sonst in Odin alles so lassen wie es ist! Keine pit, kein repart, kein MODEM/PHONE, keine CSC!
4. Boote das SGS in den DownloadMode durch drücken und halten von VolumeDown+Home+Power.
5. Verbinde erst jetzt das Telefon mit dem Rechner und warte das die Treiber installiert werden.
6. Wenn die Treiber fertig installiert wurden, erscheint oben links in Odin ein gelbes Symbol.
7. Start drücken und warten bis das Handy neu gestartet ist. Kabel entfernen. Odin schliessen.
8. Fertig gerootet!
5. Addons / Mods / Themes:
1. [MOD] CRT Screenoff Animation für JVU - @xda-developers.com
2. [THEME/MOD] Boeffla-Mod by andip71 - @xda-developers.com
3. [MOD] Ext.Power / %-Battery / MMS / Gtalk Video - Deodexed only!
4. [MOD] Toggle Statusbar - @xda-developers.com
6. Links & Download
Download - JVU Stock Firmware incl Bootloader (Passwort: 4android-hilfe.de) - zip@uploaded.to - zip@minus.com
Download - cf-root für JVU - @xda-dev - @chainfire.eu
Download - Odin 1.3 incl 512 PIT - @dropbox
Link - JVU-Thread - @xda-developers.com
Link - JVU deodexed [CWM][ODIN] by [Ramad] - @xda-developers.com
7. Probleme:
1. [BUG] - FaceUnlock: Anscheinend gibt es noch einzelne Probleme mit Faceunlock. Es scheinen auch fremde Personen das Gerät entsperren zu können. Eine erste Beschreibung findet Ihr hier. Danke, Charlie Harper!
2. [BUG] - Fehlende Übersetzungen: Innerhalb der neuen Features wird alles in Englisch angezeigt.
3. [BUG] - Anzeige: Noch dem Laden des Gerätes wird im Lockscreen weiterhin "Wird geladen" angezeigt, obwohl das Ladekabel bereits entferbt wurde.
8. Video & Screenshots
9. Thanks to:
[OFFURL="https://www.android-hilfe.de/original-firmwares-fuer-samsung-galaxy-s/188055-firmware-i9000xxjvu-2-3-6-value-pack.html"]heleis[/URL], Faryaab@xda-developers.com, andip71, Charlie Harper, reflex[/OFFURL]
https://www.android-hilfe.de/members/reflex-27991.html
Reaktionen: Mike's_Note, 4ndr01dn3rd, OBI-Hoernchen und 34 andere
Das ROM ist nicht älter, wie man ja schon am Build-Datum erkennt. Und beachtet: XWJW1 und XXJVU!
Übrigens: Da es ja nie einen ValuePack gegen sollte, kann jetzt auch niemand böse sein.
Reaktionen: Donald Nice
Ich dachte an eine alte GB FW, wozu nur der Value Pack ergänzt wurde und daher das neue Build-Datum vom letzten Schritt erhielt. Also muss man die letzten 5-Stellen in Betracht ziehen. Gut man lernt immer wieder dazu.
Was bedeutet xx und xw?
@sonics: Wirf mal einen Blick in die FAQ.. Dort wird der Unterschied erklärt
@mirac: Builddate sagt EINDEUTIG aus, dass diese Firmware neuer ist!
XX = Austria, Belgium, France, Germany, Hungary, Italy, Spain, United Kingdom
XW = Central Europe
Für mich hat das aber keine Aussagekraft bezüglich Build-Datum.
XX und XW sagt erst mal nichts über das Builddatum aus, das ist richtig. Aber XXJVU ist eine andere Firmware, als XWJVU. Deshalb kann eine XXJVU auch neuer sein, als eine XXJVU oder eine XWJW1.
Das Build-Datum aus der build.prop spricht eine eindeutige Sprache.
Kann mir bitte jemand erklären, wo ich diesen "face unlock" finde? Stehe gerade auf dem schlauch :confused:
naja.. das wäre irgendwie sinnbefreit.
die ersten 2 stellen sind Region und danach doch das Build. Außerdem sagt ein Builddatum nichts über die Aktualität des Codes aus. Wie jemand vorher schon sagte, älterer Code + ValuePack = neues Build, aber nicht unbedingt neuerer Code. Die von Samsung werden schon einen Grund gehabt haben nicht hinten weiterzuzählen (z.B. JW2), sondern quasi nach der alten JVx Reihe.
--> Einstellungen - Sicherheit - Bildschirmsperre.
Reaktionen: krosscheck
hat schon jemand batterymod% dafür? :)
wenn die firmware ja noch beabsichtigte bugs, warum auch immer, enthält, macht dann ein umstieg von der jvi sinn?
hab nämlich keine lust in drei tagen eine eventuelle neue firmware zu flashen:confused2::confused2:
Jo, aber neuerer Code ist nicht unbedingt gleich besserer Code ;)
Manchmal nimmt man auch einen älteren Entwicklungsbranch und setzt darauf was neues mit nem neuen Build auf, weil vielleicht was doof gelaufen ist ;)
Naja alles nur Spekulation. Abwarten wie alle die Firmware finden und dann schauen ob man flashed :) fertig.
matze6989 schrieb:
Batterymod und bln service.jar wäre fehlen dafür :-(
Kann man für BLN einfach die service.jar der jw1 nehmen?
Sollte alles so funzen, mit bln pro funktioniert alles ohne etwas austauschen zu müssen.
-tapatraced-
Reaktionen: yosenami
benötigt vllt. jemand eine andere batterieanzeige?
falls ja, bitte sehr :)
einfach per cwm flashen (zur eigenen sicherheit: vorher bitte framework-res.apk & systemui.apk safen)...
  • UOT-01-07-13-24-3.zip
Reaktionen: Radagast und susdiehl
TramJens
TramJens
chriwa2002
  • email.filtering
email.filtering
