FCU
Ist bei mir gerade im Oxygen Updater erschienen.
Traue mich aber noch nicht
Für alle die die Version 72 drauf haben, beträgt die Größe lediglich 182 MB.
System
• Integrates the December 2022 Android security patch to enhance system security
• Improves system stability
• Fixes an issue where the Quick Settings panel occasionally cannot be pulled down after you unlock your device
• Fixes a display issue with the icons in Quick Settings
• Fixes an issue where the floating window icon might remain on the Home screen when Dark mode is enabled
Communication
• Improves the stability of mobile network connections
System
Communication
