rockster76
Moderator
Teammitglied
- 5.908
Das angesprochene Update mit dem März Security Patch ist verfügbar. 375MB
MOD-EDIT /Walhalla360
System
• Improved the charging stability to provide a better user experience
• Improved WhatsApp's video clarity when giving video calls
• Improved the vibrating performance of games such as Call of Duty and PUBG
• Fixed the issue that the time of Last Full Charge is reset after restarting the device
• Fixed the issue that the icon showing low battery is not displayed in the status bar
• Fixed the small probability issue that the device may restart when playing games
• Fixed known issues and improved system stability
• Updated Android security patch to 2021.03
• Updated GMS package to 2021.02
Dark Mode
• Fixed the issue that the navigation bar of split-screen apps might not be adapted to Dark Mode
Camera
• Improved the sharpness, noise and white balance of the rear camera
• Improved the white balance performance of the front camera
• Improved the zoom performance
• Improved the camera stability
Dark Mode
Camera
Bearbeitet von:
Walhalla360
- Grund: Changelog eingefügt. Grüße Walhalla360
