OxygenOS 13 - IN202X_11_F.13
  • 54 Antworten
MDXDave
MDXDave
Ehrenmitglied
1.631
Neues Update mit OyxgenOS 13 verfügbar - das erste Android 13 Update.
Sicherheitspatch-Level Oktober 2022.
Wird wie immer in Wellen ausgerollt.
Aquamorphic Design
  • Adds Aquamorphic Design theme colors for enhanced visual comfort.
  • Applies the Aquamorphic Design philosophy to animations to make them natural and vivid.
  • Adds Shadow-Reflective Clock, with shadow simulating the orientation of the sun and moon.
  • Upgrades to Quantum Animation Engine 4.0, with a new behavior recognition feature, which recognizes complex gestures and provides optimized interactions.
  • Optimizes UI layers for a clearer and neater visual experience.
  • Applies real-world physical motions to animations to make them look more natural and intuitive.
  • Adapts responsive layouts to accommodate different screen sizes to improve readability.
  • Optimizes the widget design to make information easier and quicker to find.
  • Optimizes fonts for better readability.
  • Optimizes system icons by using the latest color scheme to make the icons easier to recognize.
  • Enriches and optimizes illustrations for features by incorporating multicultural and inclusive elements.
Efficiency
  • Adds Meeting Assistant to enhance the meeting connecting and note-taking experience, and introduces an option to make notifications more subtle and less distracting.
  • Adds large folders to the Home screen. You can now open an app in an enlarged folder with just one tap and turn pages in the folder with a swipe.
  • Adds media playback control, and optimizes the Quick Settings experience.
  • Adds more markup tools for screenshot editing.
  • Upgrades Doodle in Notes. You can now draw on graphics to take notes more efficiently.
  • Optimizes Shelf. Swiping down on the Home screen will bring up Shelf by default. You can search content online and on your device.
Seamless interconnection
  • Optimizes earphone connectivity to deliver a more seamless experience.
Personalization
  • Optimizes Bitmoji to offer more Always-On Display animations.
  • Adds Omoji to let you fully express yourself with customized avatars. (IN&NA version)
  • Optimizes Insight Always-On Display, with more personalized Always-On Display settings available.
  • Optimizes Canvas Always-On Display, with more drawing tools and line colors available.
Security & privacy
  • Adds an automatic pixelation feature for chat screenshots. The system can identify and automatically pixelate profile pictures and display names in a chat screenshot to protect your privacy.
  • Adds regular clearing of clipboard data for privacy protection.
  • Optimizes Private Safe. The Advanced Encryption Standard (AES) is used to encrypt all files for enhanced security of private files.
Health & Digital wellbeing
  • Adds Kid Space, providing screen time limit, ambient light reminders, and Eye-protecting display features.
Gaming experience
  • Upgrades to HyperBoost GPA 4.0 to stabilize the frame rate and balance the performance and power consumption in key scenarios.
  • Optimizes the pre-launch capabilities of Quick startup to load games faster.
Quelle: OnePlus Community
Reaktionen: Micha8945
hat es schon wer getestet?
Reaktionen: Pimped
Joa läuft hier. Muss aber sagen die Quicksettings gefallen mir nicht vom Design her. Nutze das Gerät aber nicht mehr aktiv, daher kann ich nicht viel dazu sagen.
Bei ersten Tests konnte ich aber keine krassen Bugs etc feststellen.
bin ja auf 11 zurück gewechselt weil ich mit 12 unzufrieden war na mal abwarten
Hab es heute auch über den Oxygen installiert. Läuft nicht anders als vorher.
Zum Akku kann ich noch nix sagen, morgen dann vielleicht.
Das Einzige was mich nervt ist das das Discover auf dem Startbildschirm wieder da ist. Die Lösung wie bei A12 funktioniert leider nicht mehr. Vielleicht kann ja wer helfen.
Kam gestern noch über den Oxygen Updater rein. IN2023_11_F.13.
Läuft bisher ganz gut! Android Sicherheitspatch vom 5. Oktober 2022.
Reaktionen: fenie
Läuft sehr gut. Keinerlei Probleme, root funktioniert auch. Alles schnell. Perfekt.
@gustfuzz geht's AoD auch?
Wenn AOD = Allways on Display. Ja funktioniert.
Reaktionen: Pimped
Geht der Wireless Charger wieder in den leisen Schlafmodus?
Hallo,leider habe ich ein Problem
Mein Op8pro lässt sich nicht updaten
Bin noch immer auf der c20 und es findet keine Updates
Mit dem Obigen hat es jetzt die F13 gefunden aber installieren geht nicht
Schreibt nur Fehler bei der Installation,nicht kompatibel
Es bis zum c20 immer gegangen
Mfg Michael
Geh mal nach Einstellungen -- Über das Gerät -- Version. Poste mal was da steht.
Überprüfung fehlgeschlagen
Mfg Michael
Oben im Infocenter steht Extraktion fehlgeschlagen
Gestern installiert, läuft bisher sehr gut. Noch keine Bugs bemerkt.
Mfg Michael
Schon mal mit der System Update app probiert?
Mit was ?
Überprüfung fehlgeschlagen deutet darauf hin das die Software nicht zur Region passt. Deshalb solltest du mal Posten was bei Dir unter Version steht @Michi1210 .
Bei mir hatte ich damals die indische Version installiert... daher war die Version auch .20 stehen geblieben...
Bin dann aufs 6a umgestiegen und habe das Gerät per Anleitung auf Android 11 zurückgesetzt.
Danach kamen prompt alle Update, die vorher nicht angezeigt wurden.
Vielleicht hilft die Aussage ja...
Build In 2023_11_C 21
Basis q_v1_p14q_V1_p14
Kernel 4.19.157 perf+
Hoffe das passt
Alle OnePlus liefen bis jetzt super nur das Ticket jetzt
LG Michael
@Michi1210
hast du es mit dem Oxygenupdater runtergeladen?
Wie versuchst du es zu installieren, über die interne Installationsfunktion?
