MDXDave
Ehrenmitglied
- 1.560
Neues System-Update wird ab heute ausgerollt:
Sicherheitspatch-Level bleibt bei November 2020
Changelog:
Changelog:
- System
- Newly added keyboard height adjustment where you can raise or hide the bottom shortcut bar for a better input experience (Go to Settings-System-Language & input-Keyboard height adjustment)
- Fixed the issue of a small probability that the alarm clock starts abnormally
- Fixed the failure to enable auto rotate feature
- Gallery
- Fixed a small probability issue that photos don’t display in the Gallery
- Bluetooth
- Fixed the small probability issue that no pop-up window shows up when connecting Bluetooth headset
- Network
- Fixed the issue that the WiFi connection failed in a specific situation
- OnePlus Store (IN only)
- An intuitive and convenient way to manage your OnePlus account, get easy-to-access support, discover exciting members-only benefits, and shop for OnePlus products. (Please note that it can be uninstalled)
