[Firmware][10.0] OxygenOS Open Beta 6 | Ende
  • 120 Antworten
TomTim
TomTim
Ehrenmitglied
6.425
System
  • Now unlock the LockBox without any problems in File Manager
  • No more chrashes in the Launcher with apps in full-screen display
  • Got rid of blank screen while clearing up the background apps
  • Updeted Android Security Patch to 2020.03
Installationshinweis der Vollversion: Root & TWRP [Methode 1]
  • Die Vollversion Laden und ins Hauptverzeichnis des Telefons kopieren, TWRP installer.zip und Magisk.zip ebenso.
  • Ins TWRP Navigieren
  • 1. OOS und TWRP installer installieren
  • 2. Neustart in TWRP
  • 3. Magisk.zip installieren
  • 4. Neustart ins System
Installationshinweis der Vollversion: Root & Stock-Recovery [Methode 2]
Update mit Root und Stock-Recovery
  • System lädt komplette ROM runter nach Erkennen von Root
  • Magisk im Magisk-Manager deinstallieren
  • Update installieren lassen (NICHT Neustarten)
  • Magisk-Manager öffnen und Magisk im 2. Slot installieren
  • Reboot
Root bleibt erhalten
Viel Spaß beim Testen :)
Reaktionen: bbfh, blur, AcmE85 und 2 andere
Updateverlauf OnePlus 6T
System
System
  • Fixed and removed white bar below the keyboard
  • Fixed the issue with app crashes during installing and updating
  • Improved system stability and fixed general bugs
  • Updated Android security patcht o 2020.02
Phone
  • Optimized the one-handed mode experience in the Phone app
  • Fixed the issue with the duplication of contacts
Zen Mode V1.5.0
  • Improved OnePlus Account login for synchronization of badges and user´s data
System
  • Optimized details for Emergency Rescue
  • Added a feature to support reminders for privacy alerts
  • Improved system sytility and fixed general bugs
  • Updated Adroid security patcht o 2019.12
Phone
  • Added ringtone increasing and decreasing features for incoming calls
Reading Mode
  • Fresh new chromatic effect for a more immersive and comfortable reading experience with color gamut and saturation adjustment (Settings-Display-Reading Mode-Turn on Reading Mode-Chromatic effect)
System
  • Added the notch area display options under Settings>Display>Notch display>Hide the notch area
  • Updated the GMS Package
  • Updated Android security patch to 2019.11
  • Improved system stability and general bug fixes
OnePlus Care (India only)
  • Sign up to get rewards, premium experience, and exclusive offers
System
  • Fixed the fingerprint identification issue
  • Fixed the animation lag for the fingerprint unlock
  • Fixed the automatic Freeze and Reboot issue
  • Improved system stability and fixed other known issues
Camera
  • Improved the performance and General bug fixes
WiFi & internet
  • Fixed the 5Ghz WiFi connection
System
  • The purpose of this Update is to optimize the system performance and prepare for major upcoming updates.
System
  • Optimized and made the screenshot taking process smoother and faster
  • General bug fixes and stability improvements
  • Updated Android security patch to 2019.08
Zen Mode
  • Optimized visual effects
  • Added the additional setting to select the duration of time
System
Screen Recorder
  • Hide floating widget when recording
  • More options added for resolution, fps and bit rate
OnePlus Laboratory
  • Brand new UI design
  • Added DC dimming feature
Weather
  • Added popular cities for search suggestions
System
  • Fixed issue with the camera while using quick reply in landscape
  • General bug fixes and inprovements
  • Updated Android security patch to 2019.07
File Manager
  • Improved UI
  • Optimized bottom navigation
  • Improved app stability
OnePlus Switch
  • Supported more types of data migration
OnePlus Widget
  • Added clock widget on home screen
Download
System
Screen Recorder
  • Added FPS option giving morecontrol over recording effects
Weather
  • Improved scrolling experience for switching between pages
  • Weather cards for multiple cities can now be rearranged or deleted by tapping and holding on them
  • Optimized user experience by allowing you to use this app while app permission to access APS location is disabled
Phone
  • Better animation effects for switching between pages
  • Improved experience with searching for contacts
  • Optimized Quick Responses for declined calls and supported editing Quick Replies
Download
  • Vollversion
System
  • Updated Android security patch to 2019.06
  • Added digital wellbeing (Settings – Digital WellBeing)
Fnatic Mode
  • Brand new Fnatic mode offering you immersive gaming experience
Download
System
  • Fixed the bug where Facebook messenger pops up notifications when in gaming mode
  • Improved smooth-scrolling experience
Message
  • Supported PIN-TO-TOP for notification category (India Only)
Network
  • Support Telia Denmark VoLTE/VoWiFi
Zen Mode
  • Added Zen Mode feature
Screen Recorder
  • Added Screen Recorder feature
Communication
  • Optimized the logic of dialing a contact while using two SIM cards
Download
  • Vollversion
System
  • Updated Android security patch to 2019.05
OnePlus Switch
  • More accurate remaining time for completion
Download
System
  • Display overheating device warning
  • New UI for system update
Quick reply
  • Supported more IM APPs for Quick Reply in landscape
  • Apps don't get paused when using quick reply in landscape
Community
  • Optimized search experience by adding search field, and grouping search results in different categories
  • Improved the UI of Social page
  • Optimized Log recording in Bug Report section
Download
System
  • Updated Android Security Patch to 2019.04
  • Improved network speed display
  • Supported shortcuts to access corresponding interfaces in Quick Settings
Quick reply in landscape
  • Supported quick reply in the notification bar
Launcher
  • Added tutorial in shelf
  • Added Parking location feature
  • Improved page Indicator to mirror Icon pack
Download
System
  • Screenshot UI Optimizations
Gallery:
  • Improved photo editor
Launcher
  • Improved color adaptation for cards in the shelf
OnePlus Switch
  • Supported permissions migration for applications
Weather
  • More details added to weather warnings
  • Weather timeline now follows system time format
  • General bug fixes
Phone
  • UI Optimizations
Download
System
  • Updated Android security patch to 2019.03
  • Improved lock screen interface
  • Improved sensitivity for screen rotation
Messages
  • Now able to select contact groups for sending SMS
Download
System
  • General bug fixes and improvements
Clock
  • Fixed lag while setting an alarm
Phone
  • Improved stability for video calls
Download
System
  • Added OnePlus Laboratory for OnePlus 6
  • Optimizations for screenshot function
  • Support for quick reply in landscape mode - now easier to reply to new messages when watching videos
  • Gaming mode enhancement
Clock
  • Now supports world clock with weather information
Download
System
File Manager
  • Optimized UI for unlocking lockbox
Phone
  • Messages now support landscape mode
  • Deep integration with Google Duo
Weather
  • Added more search options to improve the accuracy of search results
  • Weather descriptions more accurate
  • Added more unit options for precipitation, visibility, pressure and other data
  • Added more detailed descriptions to weather icons
Download
Was gibt´s Neues?
System
· Improvements for screen brightness control
· Confirm pin without tapping √ for app locker
· Improved colour adaptation for navigation bar when using third party apps
· General bug fixes and system stability improvements
Phone
· Added the caller identification feature (For India only)
· Improved UI for Call History
Gallery
· Added create collection, copy and move photos features
· New illustrations and design on blank pages
· General Bug fixes and overall experience improvements
Launcher
· Added recommended tools in toolbox
· Improved UI for category tags in app drawer
Download
System
· Updated Android security patch to 2018.12
· Added toast message when parallel apps are unavailable due to data corruption
Communication
· Added call history for incoming calls from unknown numbers
· Optimized UI for Spam messages and calls
OnePlus Switch
· Now supports migrating data from iPhone
Download
· Vollversion
Reaktionen: MarcoG:, bbfh und AcmE85
Anleitung zurück zu Stock
Das hier ist meiner Meinung nach die einfachste Methode für alle die einen Entsperrten Bootloader haben. Wer keinen entsperrten Bootloader hat der kann auf das MSMDownloadTool zurück greifen.
Los geht´s und nochmals zur Erinnerung: Die Installation im Fastboot setzt einen Entsperrten Bootloader vor raus. Der speicher wird dabei Formatiert und alle Daten werden dabei gelöscht.
  1. Datei in einen Ordner entpacken
  2. OnePlus 6T in den Fastboot-Modus navigieren (Power & Volume +)
  3. Telefon und PC verbinden
  4. Im Ordner (punkt 1) die Datei flash-all.bat starten
  5. Warten bis das Installationsprozedere durchgelaufen ist – wenn das Telefon startet ist es soweit.
Download: Fastbootversion
Aktuell ist im Moment die 9.0.12
Reaktionen: MarcoG:, bbfh und vergilbt
Open Beta 2 wird seit heute ausgerollt.
Reaktionen: TomTim
Helligkeitseinstellung jetzt wieder linear.
So langsam wird Beta 3 verteilt.
Reaktionen: AcmE85
Bei mir auch, hab jetzt folgende Meldung,
was ist jetzt zu tun um Root zu behalten und um das Telefon nicht neu aufsetzen zu müssen?
Vielen Dank
steht im ersten Post?
Reaktionen: TomTim, Tim_Taylor und bbfh
:1f633: Bin ich blind, hab überall gesucht, nur nicht gleich hier:] tut mir leid, Entschuldigung
und vielen Dank :1f44d:
Nochmal Danke, muss ich jetzt warten bis ich die Beta selber bei OnePlus runter laden kann,
denn wenn ich die Meldung auf dem Bildschirm anklicken wird ja die Firmware geladen und gleich
installiert, oder?
Na bist du auf der beta oder auf der original?
Beta 2
Und du hast TWRP?
Dann musst du wohl die Firmware von der HomePage nehmen, sonst wird dir TWRP überschrieben
Jau, TWRP, auf der Homepage ist die 3er noch nicht, dann warte ich.
Beta 4 ließ sich vorgestern zunächst downloaden, stockte aber bei 100 % und ist seitdem nicht mehr erschienen.
@Trevor70
OnePlus hat die Beta zurückgezogen.
Zitat aus dem OP Forum:
Hey everyone
Due to a critical issue reported on OnePlus 5 and 5T Open beta builds. we are pausing the OTA rollout for now as a precautionary step to make sure the open beta build is well cooked ... thank you
Reaktionen: bbfh und Trevor70
Wurde auch pausiert,stehr ganz unten.
Reaktionen: toffer84 und Trevor70
Die Beta 4 wird wohl wieder verteilt...
Reaktionen: TomTim
pLAUBi
scara2
scara2
Cua
xwolf
xwolf
Bl4ck3urn
Bl4ck3urn
