[Firmware][8.0.0] OxygenOS 5.0 [Oreo]
  • 196 Antworten
CerealKiller77
CerealKiller77
Stamm-User
435
OxygenOS 5.0 basierend auf Android 8.0 ist veröffentlicht worden.
Hello everyone!
We are pushing out the incremental roll-out of OxygenOS 5.0, our first official Android O OTA update for the OnePlus 3 and 3T. Here are some of the highlights of this build:
System
  • Update to Android O (8.0)
  • Added Parallel Apps
  • Added Picture in Picture
  • Added Auto-fill
  • Added Smart text selection
  • New Quick Settings design
  • Updated security patch to September
Launcher
  • Added notification dots
  • New app folder design
  • Now able to upload photos directly to Shot on OnePlus
For those who were on previous versions for OnePlus 3 and 3T, we appreciate your active feedback and attempts to reach out to us. With your help, we have been able to better optimize and improve several key areas. Thank you for your patience and as always, we look forward to hearing your continued feedback in the bug reporting forum here: Bug Reports - OnePlus Forums.
As always, this OTA will be incremental. The OTA will reach a small percentage of users today, and we'll begin a broader rollout in a few days.
Your feedback is appreciated. We may not always be able to respond to every comment in the forums, but please be assured that we take your comments and feedback seriously. Hope you enjoy and let us know how you feel about the update in the comment below.
Thank you.
Download der kompletten Rom:
http://otafsg.h2os.com/patch/amazon...ygen_16_OTA_060_all_1711160505_d8b688b464.zip
Reaktionen: Axileo, datt-bo, tenzin und 2 andere
Bei mir ist seit 3 Tagen Oreo drauf und kann nichts beklagen.
Bei dir ist es aber die OpenBeta 27, jetzt wurde aber die Stable veröffentlicht.
ich wopllte jetzt diese OnePlus3Oxygen_16_OTA_036_all_1710262329_97651662219b4e6b.zip über TWRP installieren bricht aber mit Fehler ab !
Das war unerwartet. Bin gespannt...
@Mannimb
Die ZIP ist doch ziemlich alt (Beta26) wenn ich mich nicht irre.
Ich würde die nicht mehr flashen. Entweder Beta27 oder direkt auf die Stable zip warten.
Für Oreo brauchst du eine aktualisierte TWRP Version:
https://forum.xda-developers.com/devdb/project/dl/?id=27225
edit: auf XDA wurde der Link zur komplettem Rom auf OnePlus' Server gepostet:
(zum Startpost hinzugefügt)
Reaktionen: datt-bo
Wow, das ging aber fix. Download läuft, ich bin gespannt wie ein Flitzebogen.
@AcmE85:
Brauche ich die aktualisierte TWRP auch für die komplette Rom oder nur für die Beta?
:biggrin:
@Berlifan
Ja brauchst du , da 1+ einiges geändert hat bei Oreo im Vergleich zu Nougat.
Da mußte die TWRP erst angepasst werden.
Reaktionen: Berlifan und AcmE85
@Berlifan
Ich bleibe vorerst bei der Beta, von daher kann ich dir das nicht beantworten. Ich würde aber vermuten du brauchst die aktualisierte TWRP.
Und selbst wenn nicht solltest du dadurch keine Nachteile haben. Ist ja in Sekunden innerhalb TWRP selbst geflasht.
Kann ich Magisk auch gleich hinterher schieben oder braucht es da auch was spezielles?
@Berlifan
Das gilt es jetzt herauszufinden :). Kannst ja gern mal testen und uns dann aufklären.
Bei der aktuellsten Beta funktioniert Magisk wieder, aber die zwei vorigen Versionen (Beta 25 u. 26) wollten mit Magisk nicht booten.
@CyPress1988
Habe eine vorhandene Magisk (die bisher auf 7.1 funktionierte) nachgeschoben und seh jetzt keine Bootanimation mehr. Aktuell habe ich einen 1+ Bildschirm mit "powered by android".
Ich sollte wohl besser die "Magisk Beta V14.3 (1437)" aus dem Beta-Thread nehmen, oder soll ich noch warten?
Du kannst die erwähnte Magisk Beta gern ausprobieren. Würde aber vorher den Magisk uninstaller flashen oder die Rom nochmal neu flashen.
Hast du dirty oder clean geflasht?
So, habe nicht mehr gewartet und neu geflasht.
Dann die "Magisk Beta V14.3 (1437)" geflasht und nun sehe ich auch wieder die Bootanimation...:biggrin:
Daher empfehle ich nur die Beta-Version von Magisk zu benutzen.
Okay, Gerät hat komplett gebootet und System ist nun Oxygen-OS 5.0 bzw. Android 8.0
Alles gut:biggrin::biggrin::biggrin:
[doublepost=1511096940,1511096838][/doublepost]@CyPress1988
Habe zuerst mein Backup eingespielt und dann dirty Oxygen und Magisk-Beta geflasht.
Reaktionen: datt-bo und KyleRiemen
Ich würde gerne die neue Oreo ganz frischdrauf machen damit der Müll weg ist.
Wie gehe ich dazu vor ? System löschen und die zuvor , da ich ja keine externe Speicherkarte habe wo ich die Rom hinpacken kann.
LG Manni
Ich habe die oben erwähnte TWRP-Version von Bluespark geflasht und anschließend das ROM sowie SU2.8.2. Aber das Gerät hängt leider beim Neustart im "Powered by Android"-Screen und es tut sich nix. Hat jemand ne Idee?
2 Beiträge über deinem habe ich eine Empfehlung abgegeben.
Also zur Klarstellung: mit Magisk erhälst du auch Rootrechte....
Ich hatte auch Hänger.
nochmal die Rom flashen ohne su , dann erweiteter Neustart , USB Debucking , dann nochmal in die Recovery und da erst die Su flashen
Ich spare mir das Flashen für das kommende Wochenende auf. Ich möchte vermeiden komplett clean zu flashen. Wäre cool, wenn ihr eure Erfahrung in Bezug auf Dirty Flash via TWRP teilen könnt. Das habe ich beim Sprung von Marshmallow auf Nougat auch getan und nie Probleme gehabt.
Bin irre gespannt...
