[Firmware][7.1.1] OxygenOS Open Beta 22 [Nougat]
  • 20 Antworten
Neue HydrogenOS Beta:
【camera】
- support to add Shot on OnePlus watermark, you can also add your name in the watermark
【system】
- redesigned the display style of the bright screen, the interface is more concise and clear, support the display battery power
- Apply lock support to hide the content of the notification, to further protect your privacy and security
- Optimize the stability of the application of double open
- Adjust the screen default color display
- Update Android security patches
【clock】
- Add alarm clock function, you can now set the alarm clock for the specific date, you can also set the alarm clock according to the statutory holidays
【communication】
- The right side of the contact list supports direct display of quick index bars
- Contact management increases the quick merge function
【Gallery】
- Optimize picture loading and display speed, look at the picture one step further
【the weather】
- Optimize the experience of searching the city
Reaktionen: madX5, TomTim, meik0N und 3 andere
madX5
Caddie
AcmE85
SleepwalkDrive
SleepwalkDrive
TomTim
  • Angepinnt
  • TomTim
2 3 4
Cris_
Cris_
