AcmE85
Enthusiast
- 5.702
OxygenOS Open Beta 21/12 for the OnePlus 3/3T
New addition:
http://oxygenos.oneplus.net.s3.amaz...6_OTA_029_all_1708021851_2c1c9a69a243423e.zip
edit:
Sicherheitspatch-Level: 1. Mai
Nightmode + sRGB wurde endlich gefixt
New addition:
- Parallel apps:
- All new parallel apps feature that lets you run a parallel version of the same app using a separate account. Right now this supports Facebook, Twitter, Whatsapp, and Instagram (and a few more popular apps)
- Updated to Launcher V2.1.5 :
- Optimized home screen folder icon, with a preview look of first 4 icons in the folder
- Redesigned UI for folders, allowing switch between folders by swiping left or right
- Added double finger slide support, you can now slide the home screen with one finger while using another to hold an item
- Updated to Gallery V1.8
- Supports light theme
- Supports opening RAW format images
- Updated File Manager to V1.7.1
- Long pressing search items now shows edit operations
- Call histories from the same person will now be merged
- Fixed increased battery consumption after connecting to a bluetooth device
edit:
