AcmE85
Enthusiast
- 5.702
OxygenOS Open Beta 19/10 for the OnePlus 3/3T
All new OnePlus Launcher v2.1:
OnePlus 3 OxygenOS Open Beta 19
- Supports dynamic icons for Weather and Calendar
Added ‘Home screen layout’ under launcher settings for grid and icon customizations - Grid layout will be kept irrespective of display size changes
- Added search history records in app drawer, displaying the 5 most recent apps on the first row
- Newly installed apps will now be tagged with a blue dot for easier recognition
- You can access icon pack resources on the Play store directly under launcher settings
- User interface improvements during widget selection
- Launcher version information is now visible under launcher settings
- Added an option to display battery status of connected Bluetooth devices
Added OnePlus widget (Not usable on Shelf) - Email address recognition within the text message contents
- Size of clock widget is now adjustable
- Updated UI style for Clock
- Smart Callback works better
- Incoming call animations redesigned
- OnePlus font optimizations for select languages
- Compatibility optimizations for variousBluetooth devices
