Lunatic-
Siehste und ich hab noch die 2.79... Danke für den Tipp!
Anmerkung: Diese Funktion erfordert derzeit den Zugriff auf die Seite über den integrierten Safari-Browser.
Updates
- update the input method to solve the problem of voice recognition switch failure
- Update a plus community to V2.6
Repair/ Bug Fixed
- Fix the problem of duplication sometimes
- repair long screenshots to repeat the problem
- Fix the application lock part of the color is not correct
- Repair the power display is not accurate
- Fix a display problem with a plus black font part of the scene
- repair the camera occasionally open the problem
- Fix third-party software to send files through hotspots
- Fixed the problem of automatic flow calibration failure
- Repair the hot spot after the real-time speed display error
- Repair the display of some of the weather under the scene
