dg1994
- 19
HWOTA (HuaWei Over The Air)
MEGA
MEGA
MEGA
LINKS ALS ANHANG
1. DAS PROGRAMM HOWTA HERUNTERLADEN UND AM BESTEN AUF DEN DESKTOP ZIEHEN
2. ADB UND FASTBOOT DATEN , ADB DRIVER INSTALLER HERUNTERLADEN UND INSTALLIEREN
3. AUF DEM HANDY UNTER ENTWICKLEROPTIONEN USB-DEBUGGING UND OEM-ENTSPERRUNG AKTIVIEREN:
3. BOOTLADER UNLOCK CODE BESORGEN AUF DER HUAWEI SEITE
4. DIE BAT.SH DATEI MIT NOTEPAD+ ÖFFNEN UND DORT DEN UNLOCKCODE EINTRAGEN UND ABSPEICHERN.
DORT WO DIE XXXXXXXXXXXXXX SIND DEN CODE EINGEBEN.
#!/bin/bash
printf "\033c" # Clear screen
# Get path variables
if [ "$1" = "" ]; then
ROOTPATH=`pwd`
AWK=awk
else
ROOTPATH=`cygpath -m "$1"`
AWK=gawk
fi
TOOLPATH=$ROOTPATH/tools
OEMPATH=$ROOTPATH/oeminfo
RECPATH=$ROOTPATH/recovery
FASTBOOT=$TOOLPATH/fastboot
ADB=$TOOLPATH/adb
UNLOCK_CODE=XXXXXXXXXXXXXX
5. DIE GEWÜNSCHTE FIRMWARE MIT DEM FIRMWARE FINDER PROGRAMM HERUNTER LADEN. (AUCH MIT DER APP MÖGLICH, ES IST EINFACHER UND SCHNELLER),
DANN AUF DEN PC ZIEHEN !
6. DIE HERUNTERGELADENE FIRMWARE, BESTEHT AUS DREI DATEIEN.
DIESE DANN UMBENNEN IN : update.zip , update_all_hw.zip , update_data_public.zip
UND IN DEN HOWTA ORDNER - UPDATE ORDNER VERSCHIEBEN.
7.DANN DAS PROGRAMM STARTEN UND DEN ANWEISUNGEN FOLGEN.
SOLLTE EIN LINK NICHT GEHEN EINFACH BESCHEID SAGEN HABE NOCH NIE SOWAS GEMACHT
PS: BEI DER FRAGE WIE MAN FLASHEN WILL NICHT DIE SD CARD METHODE WÄHLEN , FÜRHT OFT NUR ZU PROBLEMEN
MEGA
MEGA
MEGA
LINKS ALS ANHANG
#!/bin/bash
ROOTPATH=`pwd`
AWK=awk
else
AWK=gawk
fi
ADB=$TOOLPATH/adb
