[Firmware] B115 China
  • 36 Antworten
Raimund1
Neue Huawei AscendP6 Unicom version (P6-U06, EmotionUI 1.6, B115) Stable Release erschienen.
19. Juli 2013 Update - Changelog:
Fit for:
Huawei Ascend P6 Unicom version (P6-U06)
Note:
Please read carefully before Brush Brush tutorial, to avoid the risks of the process;
This version only applies to the above fit models do not support other models;
Brush or use in any need of help and resolve problems can go to the pollen club for support.
Update:
[The recommendation]
New high power consumption prompted third-party applications
Optimize media files scanning speed
Optimization Mobile Power
Performance Optimization SMS
Repair small probability can not open WIFI
Repair phone screen small probability point does not shine
Repair after taking a picture of small probability can not be stored
Email spam repair small probability lost synchronization
Fix attribution after a language switch displays an error
Fix small error probability Caller ID
Fix input flip Caton
[System]
Repair phone as a hot spot, after a period of idle disconnect data services
Repair phone battery display inaccurate
Fix light up the screen backlight blinks when a small probability
[Camera]
Optimize image stabilization algorithm
Fix Gallery can not turn off Auto-rotate screen
Repair from the panoramic switch to other modes, face box does not display
[Media Player]
Fix RTSP streaming media on demand can not fast forward / rewind
Fix some special MP3 music files can not be played
[/B]
Edited to add the Exchange e-mail forwarding
[B][SMS][/B]
Tuning session chat interface supports two-finger zooming text font size
Bring forward the message optimizing sender's name, number
Repair turn off SMS vibration function still shaking after the restart
[B][Calls][/B]
Fix Network account can not share contacts
[B]Input[/B]
[B]WIFI[/B]
Reaktionen: burner8, bm3108 und Dr.No
hier ein Link, wo es wesentlich schneller geht.
Reaktionen: MarkusOSX und bm3108
ich habe heute Zeit, also ausprobieren...
gib mal bitte Bescheid, wie sie so läuft. Die B112 hatte noch zu viele Fehler bei der Übersetzung.
und und und ??? :drool:
auf Werkseinstellungen zurückgesetzt:
- Root mit Eroot war wieder problemlos möglich
- Kameraton lässt sich wieder über das Menü abschalten
- System läuft noch flüssiger :)
- Scan der SD Karte geht sehr schnell :)
Benachrichtigungsleiste fehlt :/
Rest folgt :razz:
Geh wieder zurück auf die 107
ohhh ne, wieder keine Benachrichtigungsleiste :sad:
die B107 läuft gut. Ich warte auf eine offizielle oder Custom.
Gibt es irgendwelche nennenswerte verbesserungen?
es ist zwar schon eine (inoffizielle) Build109 für den europäischen Raum im Anmarsch, aber die China-Roms sind alle immer etwas weiter in den Builds.
Evtl. liegen die Probleme mit der Benachrichtigungsleiste ja in den regionalen Beschränkungen. Im russischen P6-Forum wird davon berichtet das einige Probleme dadurch behoben werden konnten, in dem man den Regionsordner \cn löscht und den Eigenen \de in \cn umbenennt. Probiert habe ich es jedoch nicht.
Die ROM ist aber für das U00 und nicht für das U06.
die Build109 ist eine europäisch ROM, damit gab es bisher keine Probleme. Mein Hinweis bezog sich auf die chinesischen Rom´s, welche in der Build etwas weiter sind als wir.
B115 User:
könnte bitte jemand einen Screenshot von der Build-Nummer (Einstellungen - über das Telefon) einstellen?
Danke im voraus.
Screenshots sind zwar in Estnischer Sprache dürften aber für die Infos die du brauchst genügen.
Reaktionen: digitdia
ich blicke nimmer durch. was denn jetzt die letzte offizielle Version bei der es die benachrichtigungsleiste noch funzt? habe 107 drauf.
@loler
Den Thread über die Firmwares habe ich soeben aktualisiert.
Wenigtelefonierer
digitdia
  • digitdia
digitdia
digitdia
  • Paolo83
Gast7007
