[Firmware][9.0] OxygenOS Open Beta 33 [Pie]
  • 96 Antworten
TomTim
TomTim
Ehrenmitglied
6.425
Was gibt´s neues?
System
  • General bug fixes and stability improvements
Weather
  • Improved scrolling experience for switching between pages
  • Weather cards for multiple cities can now be rearranged or deleted by tapping and holding on them
  • Optimized user experience by allowing you to use this app while app permission to access GPS location is disabled
Phone
  • Improved animation effects when switching between pages
  • Improved experience with searching for contacts
  • Optimized Quick Responses for declined calls and supported editing Quick Responses
Zen Mode
  • Added Zen Mode helping you keep away from the screen and back to life for 20 minutes
OnePlus 5T Updateverlauf
System
Weather
Phone
Zen Mode
System
  • Updated Android security patch to 2019.06
  • Added digital wellbeing (Settings – Digital WellBeing)
Fnatic Mode
  • Brand new Fnatic mode offering you immersive gaming experience
System
  • Fixed the bug where Facebook Messenger pops up notifications in gaming mode
  • Improved smooth-scrolling experience
Message
  • Supported PIN-TO-TOP for notification category (India Only)
Communication
  • Optimized the logic of dialing a contact while using two SIM cards
System
  • Updated Android security patch to 2019.05
OnePlus Switch
  • More accurate remaining time for completion
System
  • Display overheating device warning
  • New UI für system update
Quick reply in landscape
  • Supported mor IM APPs for Quick Reply in landscape
  • Apps don´t get paused when using quick reply in landscape
Community
  • Optimized search experience by adding search field, and grouping search results in different categories
  • Improved the UI of Social page
  • Oprimized Log recording in Bug Report section
System
  • Updated Android security patch to 2019.04
  • Improved network speed display
  • Supported shortcuts to access corresponding interfaces in Quick Settings
  • Supported quick reply in the notification bar
Launcher
  • Added tutorial in shelf
  • Added Parking location feature
  • Improved page Indicator to mirror Icon pack
System
  • Screenshot UI optimizations
Launcher
  • Improved color adaptation for cards in the shelf
OnePlus Switch
  • Supported permissions migration for applications
Weather
  • More details added to weather warnings
  • Weather timeline now follows system time format
  • General bug fixes
Phone
  • UI optimizations
Download
System
  • Updated Android security patch to 2019.03
  • New animation for flight mode
  • Optimized notifications for quick settings
  • Optimized battery consumption
Messages
  • Now able to select contact groups for sending SMS
System
  • Updated Android security patch to 2019.02
  • Gaming mode enhancement
OnePlus Clock
  • Added weather information to the clock widget
System
  • Optimizations for the screenshot function
  • Support for quick reply in landscape mode, now easier to reply to new messages when watching videos
System
  • Updated Android security patch to 2019.01
  • Improvements for screen brightness control
  • Confirm pin without tapping √ for app locker
  • Improved color adaptation for navigation bar when using third-party apps
Gallery
  • Added create collection, copy and move photos features
  • New illustrations and design on blank pages
  • General Bug fixes and overall experience improvements
Launcher
  • Added recommended tools in the toolbox
  • Improved UI for category tags in the app drawer
Phone
  • Added call history for incoming calls from unknown numbers
  • Improved UI for Call History
  • Deep integration with Google Duo
  • Added caller identification feature (For India only)
Weather
  • Added more search options to improve the accuracy of search results
  • Improved accuracy of weather descriptions
  • Added more unit options for precipitation, visibility, pressure and other data
  • Added more detailed descriptions to weather icons
OnePlus Switch
  • Now supports migrating data from iPhone
System
  • Fixed random audio tuner crashes
  • General bug fixes and system stability improvements
System
• Updated Android Security patch to 2018/12
• Fixed issues with custom accent colour not getting applied every second try
• Optimizations for Face Unlock
Launcher
• Fixed UI issues with scroller in app drawer
• Improved colour adaptation for navigation bar
Third-Party App
• Fixed issue with Netflix crashing randomly
  • System
    • Updated system to Android™ 9.0 Pie™
    • Brand new UI for Android Pie
    • Brand new navigation gestures (this is only for 5T)
    • Updated Android security patch to 2018.11
    • Optimizations for background app process handling
  • Do Not Disturb mode
    • New Do Not Disturb mode with adjustable settings
  • Communication
    • UI Improvements for emergency rescue
    • Optimized UI for speed dial and calling interface
    • Now able to assign a specific SIM for a specific contact or group of contacts when using dual SIM
  • Parallel Apps
    • Added support for more apps (Telegram, Discord, IMO, Uber, OLA) in parallel apps
  • Weather
    • Now able to switch dynamically to your current location
    • Display more suggestions when the search function is used
    • Fixed an issue that prevented the app from refreshing when the location is changed
    • Fixed an issue that resulted in some users being unable to find certain locations
Download
SystemUpdated Android security patch to 2018.10
General bug fixes and improvements
Wie geil:
  • General bug fixes and improvements
Und das bei einer beta?!
Wird immer lächerlicher die Betas.... Die sollen langsam mal mit Pie anfangen.
Zu Pie wurde doch schon was gesagt wann es kommt. Die werden sich aktuell auf den Lunch des 6T konzentrieren. Was ich auch verstehen kann. Und guckt man sich die Bugs beim 6er an bin ich froh das noch etwas dauert. Ich denke es kommt noch diese Jahr. Und dann sollen die meisten Bugs auch wohl behoben sein und wir dürfen uns über ein vernünftiges Pie freuen.
Naja, ein eigener Thread je Beta mag etwas übertrieben sein, aber dass nicht jede Beta unzählige gravierende Änderungen enthält, dürfte auch klar sein. Ich finde also angesichts der ordentlichen Gesamtsituation bzgl. der Beta Programme - gerade wo es aktuell ein neues Gerät zu promoten gilt - nicht so dramatisch.
Bzgl. Pie: Es ist durchaus gut möglich, dass es dieses Jahr noch eine Open Beta von Pie geben wird.
Gehe auch davon aus das es zumindest noch eine Pie Beta dieses Jahr geben wird
Habe soeben ein Update angeboten bekommen, obwohl ich es schon vor fast drei Wochen schon installiert hatte:
Moin,
Kommt da noch ne Betal Habe massiv Bluetooth Probleme.
Gruß René
Ja, ein Beta im Form von Pie soll demnächst erscheinen.
Ah, cool!
Gleich pie, darum kam so lange nichts!
Mercie
Beta 20 sollte heute Vormittag kommen!!!
Läuft schon, 1775 MB:D
[doublepost=1544606899,1544604432][/doublepost]..... und fluppt:1f44d:
androidpie-png.934548
OxygenOS Open Beta 22 for the OnePlus 5 and Open Beta 20 for OnePlus 5T
CHANGELOG
System:
Do Not Disturb Mode:
Communication:
Parallel Apps:
• Added support for more apps (Telegram, Discord, IMO, Uber, Ola) in Parallel Apps
Weather:
DOWNLOAD
Full Zip: Official Link
Sonstiges:
Kleines allgemeines Q&A zu häufigen Fragen rund um Pie in OxygenOS
Reaktionen: dexxter88, Timmih, dasacom und eine weitere Person
Lade sie auch schon. Bin gespannt ^^
Edit:
Muss schon sagen das ich sehr zufrieden bin. Sieht super aus. Läuft bis jetzt auch alles rund. Jetzt mal den Akku im Blick halten.
läuft echt Recht flauschig.
Hoffentlich sind meine Bluetooth Probleme weg.
@rendra Berichte mal ob es noch BT Probleme gibt.
Bis jetzt nichts dergleichen festgestellt:1f44d::D
Netflix geht leider bei mir nicht mehr?!
Problem ist bekannt und es wird dran gearbeitet.
idladues
idladues
meik0N
fritzlr
TomTim
  • Angepinnt
  • TomTim
6 7 8
fritzlr
