[Firmware][9.0] OxygenOS 9.0.11 [Pie]
  • 151 Antworten
TomTim
TomTim
Ehrenmitglied
6.425
System
  • Updated Android security patch to 2020.02
  • Improved system stability and general bug fixes
Reaktionen: JCFish, KyleRiemen, Timmih und 2 andere
OnePlus 5T Updateverlauf
System
System
  • Updated Android security patch to 2019.12
System
  • Fixed an issue with Expanded Screenshots
  • Updated Android security patch to 2019.10
  • General bug fixes and improvements
System
  • Optimized and made the screenshot taking process smoother and faster
  • General bug fixes and stability improvements
  • Updated Android security patch to 2019.08
Zen Mode
  • Optimized visual effects
  • Added the additional setting to select the duration of time
System
  • Updated Android security patch to 2019.6
  • Added Screen recorder feature (Quick Settings - Edit - Screen Recorder)
  • Added Quick reply in landscape (Settings - Utilities - Quick reply in landscape)
  • General bug fixes and system improvements
Gaming mode
  • Added Fnatic mode (Settings - Utilities - Gaming mode)
Phone
  • Fixed issue with Speed Dial
System
  • Updated Android security patch to 2019.5
Bluetooth
  • Supported Quick Pairing of Bullets Wireless 2
  • Fixed issue with automatic answering failing while connected to Bluetooth Headset
System
  • Updated Android security patch to 2019.4
Phone
  • Improved stability for the Phone app
Parallel Apps
  • Fixed issue with parallel apps showing primary account
  • Fixed issues with download pictures in parallel WhatsApp
Gaming mode
  • Fixed couldn't receive third-party apps video call issues
System
  • Improved stability for OTA upgrade
Phone
  • Deep integration with Google Duo
Networks
  • Improved network stability
Hot Fix
  • Fixed connectivity issue with certain third-party Apps
  • Improved stability for Sound settings
  • Stability improvements for the system upgrade
System
  • Improved stability for Wi-Fi connection
  • Optimized sRGB display mode
  • Optimized Reading mode
  • Fixed issue with 4G VoLTE toggle missing
  • Fixed random reboots when Screen Casting
Hot Fix
  • Fixed WiFi connectivity issue with certain third-party Apps
  • Fixed issue with physical/capacitive navigation buttons not working at times(OnePlus 5 only)
System
System
  • Improved stability for Wi-Fi connenction
  • Fixed random reboots when screen casting
  • System
    • Updated system to Android™ 9 Pie™
    • Brand new UI for Android Pie
    • Brand new navigation gestures (Available for OnePlus 5T only)
    • Updated Android security patch to 2018.12
    • Other new features and system improvements
  • New Gaming mode 3.0
    • Added text notification mode
    • Added notification for 3rd party calls
  • Do Not Disturb mode
    • New Do Not Disturb (DND) mode with adjustable settings
  • Camera
    • Integrated Google Lens mode
Hot fix
  • Fixed stability issue with Bluetooth for cars
System
  • Supported for Project Treble
  • Supported IDEA Indea VoLTE (Default On)
  • Improved Bluetooth stabiltiy for phone calls
  • Updated Android security patcht o 2018.10
[*]System
  • Supported Project Treble
  • Supported IDEA India VoLTE (Default On)
  • Improved Bluetooth stability for phone calls
  • Updated Android security patch to 2018.10
[*]Download
Gibt es schon ein Full-ZIP?
Ja, klar - siehe oben. :1f617:
Reaktionen: Uljanow
Ist ja nicht wirklich eine Alternative wenn man TWRP und root erhalten will. ;)
Huhu, danke erstmal.
Wiesl erscheint das Update nicht aau der offiziellen OnePlus Seite?
Die Updates erscheinen dort immer um ein paar Wochen versetzt - das warum, dass musst du OnePlus selber Fragen.
Deswegen wird die Vollversion auch immer im ersten Beitrag verlinkt. Außerdem, was macht der Osterhase hier, wo es doch bald Zeit für den Weihnachtsmann ist. ;) :)
Danke für die antwort und bitte kein mobbing xD
Reaktionen: TomTim
Hat den jemand das Update schon über OTA erhalten?
Ja, soeben ist es per OTA gekommen, obwohl ich es ja schon installiert hatte!?
Habs gestern auch schon per OTA gekriegt.
Hatte vorher manuell auf 5.1.7 aktualisierit - dann kam die Benachrichtigung für das OTA und das konnte ich wiederum installieren. Etwas merkwürdig das Ganze.
Halt wie bei mir. War halt ein Datum 5.11.18 deshalb kam es per OTA nochmal.
OxygenOS 9.0.0 Android Pie ist draußen.
Link
Reaktionen: denkmawos, KyleRiemen, AstaBeagle und eine weitere Person
Nun verfügbar, s. Foto.
Bin noch bei 5.1.7 mit Root und TWRP 3.2.1.2 und Magisk.V16 . Wie kann ich die neue Version am besten flashen, ebenso dass es hinterher auch läuft ?
Danke schonmal für eine kurze Erklärung.
Bearbeitet von: CyPress1988 - Grund: Beitrag in vorhandenen Thread verschoben. Gruß CyPress1988
Hallo zusammen,ich habe heute das Update auf Pie erhalten. Soweit alles ok! Jetzt habe ich festgestellt das unter Standort,man nicht mehr auswählen kann Hohe Genauigkeit oder Stromsparfunktion und nur Gerät! Wie kann ich jetzt nur Stromsparfunktion nutzen ohne das GPS immer an ist? denn das scheint nicht mehr zu funktionieren.
Gruß Andi
[doublepost=1545825001,1545824539][/doublepost]@Nec75 Hallo also ich habe es so gemacht Update runtergeladen mit TWRP geflasht und dann einfacht über ADB TWRP von Blu_spark und Magisk V.18 geflasht ! Gruß Andi
GPS ist nicht immer an, das ist jetz wohl eine der "Verbesserungen" :)
Es ist nur an, wenn es eine App nutzt (steht dann auch dran)
Bin mir jetzt auch nicht sicher, ob das für mich persönlich ne Verbesserung ist.. naja
@Nec75 hatte auch probleme mit dem update..egal ob OTA oder mit der Android Updater App..
auch 5.1.7 mit Root und TWRP 3.2.1.2 und Magisk.V18 ...Immer Fehlermeldung.
Hab dann das original Recovery geflasht und OTA gemacht... Läuft
Sry ... aber ich bitte um hilfe da ja einige auch auf xda Probleme mit PIE haben...
ich habe derzeit 5.1.7 installiert mit magisk und twrp 9.85 glaube... jetzt will ich eine KOMPLETTE SAUBERE (OHNE RESTMÜLL VON OREO 8.1) INSTALLATION von PIE haben, danach TWRP installieren und MAGISK...
wie sind die schritte ^^?
DAnke für eure hilfe
idladues
idladues
meik0N
fritzlr
TomTim
  • Angepinnt
  • TomTim
3 4 5
tolong4u
tolong4u
