[Firmware][8.1] OxygenOS Open Beta 14 [Oreo]
  • 2 Antworten
dexxter88
dexxter88
Stamm-User
104
Hey everyone,
Here are the latest open beta builds for OnePlus 5 and OnePlus 5T.
ChangeLog
Calendar
  • Fixed calendar widget compatibility issue in shelf
  • Fixed issue with keyboard not popping up when creating a new schedule
OnePlus Switch
  • Optimized application and data classification list
Download
Please keep in mind that this is a beta software. These builds are sometimes not as stable as our official OTAs generally are. By installing this update, you accept the potential risks.
And please remember to tell us about any bugs you may find using the bug report forums, found here. https://forums.oneplus.com/feedback/
We have integrated the Feedback tool into Community App and you can report bugs and share Logs directly to our bug hunters with the community App.
To submit a new bug report
Community app > Profile > Feedback>click on + icon > select a category > fill in the details attach screenshots if any > submit (the tool will capture logs based on the category)
In some cases, you might have to record the logs for a longer period and reproduce the issue before you can submit a bug report (for example, network drops)
Community app > Profile > Feedback > click on + icon > select a category > fill in the details attach screenshots if any > start recording (the app records logs in the background > once the issue has been reproduced > Stop Recording > submit
Do try out the new Feedback tool, it is now much easier and simpler for our community to report bugs and share feedback with us. If you have any questions or need help, please contact Bughunters@oneplus.com
Please note:
    • If you have already flashed an Open Beta (you are currently running the latest Open Beta) you will receive this new build as an OTA.
    • If you ARE NOT running open beta software and would like to, please refer to the flashing instructions and the full ROM found on the downloads page here: http://downloads.oneplus.com/ (requires full data wipe before updating from stable to open beta).
    • Once you migrate to the Beta path, you will continue to receive Open Beta OTAs. You will NO LONGER receive the regular Official Stable OTAs.
    • Moving back to the Official OTA path from the Beta path will require a full install and clean flash (FULL WIPE of all data and cache).
Make sure to let us know how you feel about the beta builds here in the thread too, we are watching.
Never Settle.
Bearbeitet von: TomTim - Grund: Downloadlink hinzugefügt - TomTim
Der Changelog ist genial, dafür hätte ein Playstore Update auch genügt..
So sieht es aus. Etwas über 100 MB. Hätte man auch im nächst größeren Update mit rein packen können.
meik0N
fritzlr
TomTim
dasacom
AcmE85
AcmE85
AcmE85
