[Firmware][9.0] OxygenOS 9.0.11[Pie]
  • 90 Antworten
TomTim
TomTim
Ehrenmitglied
6.425
System
  • Updated Android security patch to 2020.02
  • Improved system stability and general bug fixes
Reaktionen: s9gg9, ger_kar, deltay78 und 2 andere
OnePlus 5 Updateverlauf
System
System
  • Updated Android security patch to 2019.12
System
  • Fixed an issue with Expanded Screenshots
  • Updated Android security patch to 2019.10
  • General bug fixes and improvements
System
  • Optimized and made the screenshot taking process smoother and faster
  • General bug fixes and stability improvements
  • Updated Android security patch to 2019.08
Zen Mode
  • Optimized visual effects
  • Added the additional setting to select the duration of time
System
  • Updated Android security patch to 2019.6
  • Added Screen recorder feature (Quick Settings - Edit - Screen Recorder)
  • Added Quick reply in landscape (Settings - Utilities - Quick reply in landscape)
  • General bug fixes and system improvements
Gaming mode
  • Added Fnatic mode (Settings - Utilities - Gaming mode)
Phone
  • Fixed issue with Speed Dial
System
  • Updated Android security patch to 2019.5
Bluetooth
  • Supported Quick Pairing of Bullets Wireless 2
  • Fixed issue with automatic answering failing while connected to Bluetooth Headset
System
  • Updated Android security patch to 2019.4
Phone
  • Improved stability for the Phone app
Parallel Apps
  • Fixed issue with parallel apps showing primary account
  • Fixed issues with download pictures in parallel WhatsApp
Gaming mode
  • Fixed couldn't receive third-party apps video call issues
System
  • Improved stability for OTA upgrade
Phone
  • Deep integration with Google Duo
Networks
  • Improved network stability
Download
Hot Fix
  • Fixed connectivity issue with certain third-party Apps
  • Improved stability for Sound settings
  • Stability improvements for the system upgrade
System
  • Improved stability for Wi-Fi connection
  • Optimized sRGB display mode
  • Optimized Reading mode
  • Fixed issue with 4G VoLTE toggle missing
  • Fixed random reboots when Screen Casting
Hot Fix
  • Fixed WiFi connectivity issue with certain third-party Apps
  • Fixed issue with physical/capacitive navigation buttons not working at times(OnePlus 5 only)
System
System
  • Improved stability for Wi-Fi connenction
  • Fixed random reboots when screen casting
System
  • Updated system to Android™ 9 Pie™
  • Brand new UI for Android Pie
  • Brand new navigation gestures (Available for OnePlus 5T only)
  • Updated Android security patch to 2018.12
  • Other new features and system improvements
New Gaming mode 3.0
  • Added text notification mode
  • Added notification for 3rd party calls
Do Not Disturb mode
  • New Do Not Disturb (DND) mode with adjustable settings
Camera
  • Integrated Google Lens mode
Hot fix
  • Fixed stability issue with Bluetooth for cars
System
  • Supported for Project Treble
  • Supported IDEA Indea VoLTE (Default On)
  • Improved Bluetooth stabiltiy for phone calls
  • Updated Android security patcht o 2018.10
System
  • Supported Project Treble
  • Supported IDEA India VoLTE (Default On)
  • Improved Bluetooth stability for phone calls
  • Updated Android security patch to 2018.10
Download
Hallo zusammen
Ich befinde mich grad auf 4.5.15 unlocked, rooted.
Wie komme ich auf das aktuelle Stockrom?
Ich bin voll raus aus den Thema und brauche deshalb grad was Hilfe.
Hat schon jemand die neue Version getestet?
Die angebotene Vollversion ist nicht neuer wie die 5.1.5, zeigt mir das Phone an wenn man sie installieren möchte.
Als OTA habe ich noch nichts bekommen
ja hab es am Freitag installiert über die APP Oxygen Updater vom Playstore. Nichts auffälliges nur das der GPS empfang sich deutlich verschlechtert hat. Sonst wer noch das Problem.
Reaktionen: Pascal54
Ist Dein Phone gerootet oder geht das auch ohne Root
geht auch ohne Root
hier die App
Alles klar, Danke
Habe das Update durchgeführt, VoLTE musste ich trotzdem erst nach Anleitung aktivieren
Läuft bei mir auch wunderbar. VoWifi und VoLTE muss nach dem Update tatsächlich neu freigeschaltet werden.
vaszago schrieb:
geht auch ohne Root
hier die App
Wird beim Updaten mit dieser APP das Gerät zurückgesetzt, oder bleiben die Einstellungen und installierte App´s erhalten?
MfG denkmawos
bisher ist bei mir alles glatt gelaufen und die Apps/Einstellungen blieben erhalten.
Die App lädt ja nur die originalen Update Dateien also ggf. kommt man so schneller ans Update, da Oneplus die Updates langsam ausrollt.
Reaktionen: denkmawos
@dasacom
Das Update ist problemlos durchgelaufen. Dein Problem bezüglich GPS-Empfang kann ich bei meinem Gerät nicht feststellen, habe mit "GPS Test plus"
vor und nach dem Update keinen Unterschied festgestellt (sowohl Satfix als auch Signalqualität)!
MfG denkmawos
Update 5.1.7 über Oxygen Updater installiert. VoWifi und VoLTE mussten diesmal nicht neu freigeschaltet werden.
Über das Systemupdate lief es auch ohne Probleme. Nur 38MB groß das Update.
Weihnachtszeit ist Kuchenzeit. Android Pie wird verteilt...
Reaktionen: KyleRiemen und denkmawos
Habe heute Android Pie bekommen, wie meine Frau auch auf dem Oneplus 5T
Schon irgendwelche Erfahrungen bei dem Update auf Android 9.0?
@Scanda
Update problemlos durchgelaufen, bis jetzt keine Auffälligkeiten.
Gesprächsqualität, GPS, WLAN, Bluetooth, sowie Kamera (Foto&Video) getestet.
Kosake77
Kosake77
Kosake77
Kosake77
traxxy
