![meik0N](/data/avatars/s/410/410137.jpg,q1628008917.pagespeed.ce.qDH6663kq4.jpg)
meik0N
Stamm-User
- 698
Nach nur einer Beta wird OOS 12 jetzt final verteilt. Der EU Build lässt allerdings noch auf sich warten, dieser erfordert lt. OP noch zusätzliche "Validierungsschritte". Wird dann hoffentlich zeitnah nachgereicht...
OxygenOS 12 for the OnePlus 8TKey updates
Known issues
- System
- Optimized desktop icons with improved textures, by using a design inspired by brand-new materials and uniting lights and layers
- Fixed the issue that background applications are abnormally closed in specific scenarios
- Fixed the issue with lens permissions when using third party camera applications
- Fixed the issue of screen cannot respond when receiving notifications
- Dark mode
- Dark mode now supports three adjustable levels, bringing a more personalized and comfortable user experience
- Shelf
- New additional style options for Cards, making data contents more visual and easier to read
- Newly added Earphone Control Card with Bluetooth earphone one-click adjustment
- Newly added access to OnePlus Scout in Shelf, allowing you to search multiple contents on your phone, including Apps, Settings, Media Data, etc
- Newly added OnePlus Watch Card in Shelf, to easily glance at your health stats
- Work Life Balance
- Work Life Balance feature is now available to all users, allowing you to effortlessly switch between Work and Life mode via quick settings
- WLB 2.0 now supports automatic Work/Life mode switching, based on specific locations, Wi-Fi network, and time, also bringing customized App notification profiles according to the personalization
- Gallery
- Gallery now allows you to switch between different layouts with a two-finger pinch gesture, intelligently recognizing the best-quality pictures, and cropping the thumbnail based on the content, making the gallery layout more pleasing
- Canvas AOD
- Canvas AOD brings you new diverse styles of lines and colors, for a more personalized lock screen experience with inspiring visuals
- Newly added multiple brushes and strokes and support for color adjustment
- Optimized software algorithm and improved face recognition to better identify the features and skin color of different figures
- Network
- Fixed the issue that unable to automatically connect to Wi-Fi
- Bluetooth
- Fixed the issue that wireless earphones cannot play sound when connecting Bluetooth in specific scenarios
- The clock displays smaller. You can try to adjust it manually or delete it and add the clock widget again
- Phone application may be replaced by Contacts in Dock. You can adjust it manually to move Phone application in the right place
