[Firmware] HD1913_11.F.22
  • 0 Antworten
boomst
boomst
System
• Improves system stability and performance.
• Fixes an issue that might affect charging.
Apps
• Fixes an issue where new contacts cannot be added.
To view more or join a discussion, visit
OnePlus Community
Must-knows
1. Updating the system will not delete or modify your data. For security, it is recommended to back up your data before starting the update. Please also make sure you have sufficient space for the update.
2. If you encounter any problems when using the new version, please contact our customer service.
3. The update package will be deleted after being
installed.
Reaktionen: Zappel.12
boomst
  • boomst
boomst
boomst
boomst
boomst
boomst
boomst
boomst
