Odys Neo - Thread for international users [English]
  • 254 Antworten
hävksitol
hävksitol
Ehrenmitglied
9.297
Hello,
as a German-language discussion board, we attach great importance to ensuring that all contributions are written in German. If you can't speak German, please post your questions and answers in English and only in the current thread; otherwise they will be deleted.
Thank you for your understanding.
Kind regards,
AH-Team
Reaktionen: pais83
pais83 schrieb:
The Original neox8 kernel works fine on kepler 2 excepting the ram (kepler 2 has 1024) all the other thinks works fine.
Here you go...
Credits goes to yatto/Xteam/Joaquim!
Based on github.com/yatto/xteam31 (Mediacom810C) source, patched to 1024MB memory, overclocked 1,2GHz, battery_fix included.
Use at your own risk and please report problems!
JK-Kepler2-1024MB_20121029.7z
Reaktionen: pais83 und Oma7144
thank you so much JochenKauz!!! you are my hero! XD i want to thank you in the forum but i don't find the place to do it, google translate is very bad and my german worse XD
You're welcome!
Give me a message if it works as expected, or not.
Gesendet von meinem Neo-X8 mit der Android-Hilfe.de App
Reaktionen: pais83
Could you pls test if the attached sensor fix also works for Kepler 2?
:thumbup:
  • Oma_JB_v1.2_Modell_fix_Pascal 2 akkufix.zip
Reaktionen: pais83
pais83 schrieb:
t i want to thank you in the forum but i don't find the place to do it
You need at least ten postings to make the "Thank you"-button appear.
Reaktionen: pais83
JochenKauz schrieb:
Here you go...
Thanks JochenKauz by working with the kernel. I tested your kernel with two different roms JB (oma and toiiki) in kepler 2, and both will not start. Always recovery loop.
Did you install the format_nand fix of Oma?
Yes, i installed format_nand fix but was not effective. Even nand_fix not installed and get the same result.
I've noticed that "recovery" can not mount the partitions manually.
Tomorrow I will give the error offering to install nand_flash.
sorry for my English of Google xD and thanks for the interest. :thumbup:
Same error here:
E: Can't mount /cache/recovery/command E: Can't mount /cache/recovery/log E: Can't open /cache/recovery/log E: Can't mount /cache/recovery/last_log
however your neox8 kernel works
Der ursprüngliche Beitrag von 23:43 Uhr wurde um 23:51 Uhr ergänzt:
yes the xteam works but rotation doesn’t work.
Oma your fix with the original kernel works fine. thank you to all of you guys :tongue:
If you want, I could compile 2 Kernels from the yatto Sources without modification for you, only to test which is working correct (MEDIACOM810C is one of them). After that I can change the amount of memory and we could give it a try.
Reaktionen: pais83
That could be great. I think after test your neo x8 kernel and the original one the only difference between the neo x8 and the kepler 2 is the amount of ram. The arnova 8 g3 is kepler 2 100%
Best regards from sPAIN, the future "new china" XD
@pais83,
one more question before I build new kernel...
Did you make a full flash of Oma's JB 1.2.2? I mean, did you make a eraseidb and then flashed the whole package with my kernel? On xda another user with a NEOX8 had the same problem only flashing the kernel without an eraseidb.
I try flashing first the kernel alone. Then i make an eraseidb and flash the whole rom (system, boot, misc, etc) but wait a moment. i will make the whole process again and tell you something
Please install the nand fix 1.2 of Oma at first boot in cwm.
Same error....
JochenKauz, thanks a lot for all your efforts, thanks for helping us with the kepler2 kernel in jb... my respects. a great developer
i will try to help with the kernel test if i can
:) thx so much
Okay,
I'll clone the github sources and compile it without modifications.
This are the 2 Kernels of yatto, the base of the Xteam Kernel.
As an alternative I have the Kepler 2 Sources, but don't know if they compile.. I'll give it a try.
Reaktionen: pais83
  • Hardtervirus
Hardtervirus
  • MK6
Android2003
Android2003
O
openglfreak
O
