Odys Neo - Thread for international users [English]
  • 254 Antworten
yattodettaman schrieb:
i Hope you can solve the issue of many users. This guys have a Mediacom 8203G, that is like a 810c (aka BQ Kepler) but the wifi chip is BCM4329
Could you give me the exact specification of this tablet, or as an alternative a dmesg log?
I think it has 512MB RAM, instead of the 1024MB of the Kepler 2, correct?
Yes, like NeoX8.
RK2918
512MB RAM
WIFI BCM4329
Touch Ft5301
display 800x600
Everything like your NeoX8, only the wifi hardware is different.
Okay, fine...
Then I have a look at it... should be possible to make it run.
JochenKauz schrieb:
Okay, fine...
Thanks, from Mediacom 8203G owners ;)
BCM4329 is in Odyss Express Hardware Too.
Hi Oma
Don't you like the Xteam boot logo ? :ohmy:
However we'll change it very soon ;)
I like Italy. 5 weeks ago I have been in Foligno, Umbria and visited a company named OMA - Officine Meccaniche Aeronautiche ;-)
We have had the first olive oil of the season - superb!
:thumbup:
Der ursprüngliche Beitrag von 15:36 Uhr wurde um 15:56 Uhr ergänzt:
Fine, things comming together!
First step is to look at the Kernel Archive.
For example the Mediacom Smartpad 852i guys running JB on the Teclast P85a kernel.
Maybe the Arnova 8G2 kernel will work ...
... but
ft5x0x-TS in combination with BCM4329 WLAN is very untypical.
So secound step is to compile a suitable kernel.
Guess base should be the Xpress kernel (Astralix knows best).
Can we have a full dmesg boot-log? One of the M820c 3G guys should post it on xda.
:thumbup:
Here we go...
Hope it works as expected. But keep in mind this kernel is optimized for Oma's JB 1.2.2.
JK-TestJB-M8203G-oc1104_20121127.7z
If all is fine, I could check it into repo.
Hey Jochen, ist mal wieder schneller als der Schall ;-)
:thumbup:
JochenKauz schrieb:
@djkail,
if you want all the functionality, you can use my kernel...
JK-JB-Pascal2-oc1104_20121116.7z
Features for BQ Pascal 2:
Overclocked CPU 1104MHz
Minimum CPU 24MHz
DDR RAM 1024MB/ 430MHz
Extended BT Stack by fr3ts0n
HDMI Fix
Camera Fix
TUN/TAP Device activated (VPN)
NTFS Support
What I cannot fix is the OTA. So if you use my kernel, you have to switch it off, or you will get the kernel from the xteam.
A complete overwiew of my kernels is here:
Homebrew kernel for Odys NEO X8/X7 und BQ Kepler 2/Pascal 2
Mmmm. Thank you my friend. But I have a Kepler 2, not a Pascal 2. I am using your kepler 2 kernel (http://crewrktablets.arctablet.com/?wpfb_dl=215). And pascal's users are using this one already.
There is no problem with OTA, i run RKtools after OTA update and i solved it. :thumbsup:
Nice to see you here yatto.
Thank you both...
Hi djkail,
both kernel Pascal 2 and Kepler 2 are from one building process.
Fine if it works for you!
Reaktionen: lmemperador
Hey Jochen,
I can't believe that I found your kernel!
There is like one month ago I'm searchin for a custom kernel that works with my Nextbook 8P. I've searched for many kernels and all I found was the stock kernel.
I need to enable the USB ACM support in my kernel, so I begin to collect kernel sources and compile for my own. But none kernel worked, all of them freeze at the second boot logo screen.
But incredibly I found your JK-JB-NEOX8 and flashed in my tablet, and for my surprise, everything worked fine!
Anyway, I'm here to beg you to point me the kernel source and if you could give me your kernel .config, so I can make the USB ACM support enable!
Thank you for all work! You've done a great job!
I hope to hear you soon! :)
Wow JK, now I re-read to whole topic, and you are really the man! What a great job have you done! I'm felling very dumb cause you got a working kernel with smartpad810c and yatto/xteam31, and this is exactly what I was trying to do for a whole month!
what you did? checked the dmesg and enabled each of the corresponding driver? what is the magic? I really want to know!
Anyway, I still wondering if you can give me your kernel .config and maybe give me some hints if it's possible to enable the USB ACM support, and if isnt what can be done to make it work?
Once more, thank you very very much for all you work!
I'm glad to hear that my kernel is working for you on your Nextbook 8P.
You're right, the base of my kernel was the yatto/XTeam31 kernel. But with this kernel sources I had many problems with not working gsensor, HDMI, OTG, overclocking, Bluetooth.
So this was the point I started to correct the not working things.
Checking dmesg of different working kernels was very helpful.
All you need to get started are my repo which you can find in our crew site in my Signature.
Crew RKTablets | Per aspera ad astra, we rock the Tablets or in our github repo https://github.com/crewrktablets/android_kernel_odys_neox_3.0.8.git.
We have started to publish all our sources in this github repo.
You can find my different configs in arch/arm/configs.
One important point... you need the right toolchain. I have experimented with many toolchains, but this one was the only one that was working correct for me:
arm-2010.09-50-arm-none-linux-gnueabi-i686-pc-linux-gnu
Reaktionen: pais83
JochenKauz schrieb:
Here we go...
Hi, This is the dmesg of your kernel, Wifi is still not working, but in dmesg the wifi chip is detected..... Any Ideas ?
I also tryed to compile my kernel with bcm2349 and i've got the same result.
PHP:
<6>[    0.000000] Initializing cgroup subsys cpu
<5>[    0.000000] Linux version 3.0.8+ (jk@ubuntu) (gcc version 4.5.1 (Sourcery G++ Lite 2010.09-50) ) #1 PREEMPT Tue Nov 27 16:29:21 CET 2012
<4>[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
<4>[    0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
<4>[    0.000000] Machine: RK29board
<4>[    0.000000] Memory policy: ECC disabled, Data cache writeback
<4>[    0.000000] Boot mode: 6
<6>[    0.000000] bootconsole [earlycon0] enabled
<4>[    0.000000] CPU SRAM: copied sram code from c0b82000 to fef00000 - fef01dc8
<4>[    0.000000] CPU SRAM: copied sram data from c0b83dc8 to fef03000 - fef031d8
<6>[    0.000000] Clocking rate (apll/dpll/cpll/gpll/core/aclk_cpu/hclk_cpu/pclk_cpu/aclk_periph/hclk_periph/pclk_periph): 300/135/297/288/300/150/75/37/144/144/36 MHz (20110909)
<4>[    0.000000] DDR DEBUG: version 2.02 20111109
<4>[    0.000000] DDR DEBUG: DDR3 Device
<4>[    0.000000] DDR DEBUG: 1 CS, ROW=14, Bank=8, COL=10, Total Capability=512MB
<4>[    0.000000] DDR DEBUG: init success!!! freq=426MHz
<4>[    0.000000] DDR DEBUG: CSR:0x0, RSLR0:0x249, RSLR1:0x0, RDGR0:0x55, RDGR1:0x55
<7>[    0.000000] On node 0 totalpages: 80640
<7>[    0.000000] free_area_init_node: node 0, pgdat c0b80f14, node_mem_map c0000000
<7>[    0.000000]   DMA zone: 630 pages used for memmap
<7>[    0.000000]   DMA zone: 0 pages reserved
<7>[    0.000000]   DMA zone: 80010 pages, LIFO batch:15
<7>[    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
<7>[    0.000000] pcpu-alloc: [0] 0
<4>[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 80010
<5>[    0.000000] Kernel command line: console=ttyS1,115200n8n androidboot.console=ttyS1 init=/init initrd=0x62000000,0x250000 mtdparts=rk29xxnand:0x00002000@0x00002000(misc),0x00004000@0x00004000(kernel),0x00008000@0x00008000(boot),0x00008000@0x00010000(recovery),0x00078000@0x00018000(backup),0x0003a000@0x00090000(cache),0x00200000@0x000ca000(userdata),0x00002000@0x002ca000(kpanic),0x000c0000@0x002cc000(system),-@0x0038c000(user) bootver=2012-08-07#2.28 firmware_ver=0.2.3
<6>[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
<6>[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
<6>[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
<6>[    0.000000] Memory: 315MB = 315MB total
<5>[    0.000000] Memory: 298744k/298744k available, 23816k reserved, 0K highmem
<5>[    0.000000] Virtual kernel memory layout:
<5>[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
<5>[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
<5>[    0.000000]     DMA     : 0xff600000 - 0xffe00000   (   8 MB)
<5>[    0.000000]     vmalloc : 0xd4000000 - 0xfe800000   ( 680 MB)
<5>[    0.000000]     lowmem  : 0xc0000000 - 0xd3b00000   ( 315 MB)
<5>[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
<5>[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
<5>[    0.000000]       .init : 0xc0408000 - 0xc04a4000   ( 624 kB)
<5>[    0.000000]       .text : 0xc04a4000 - 0xc0b32d30   (6716 kB)
<5>[    0.000000]       .data : 0xc0b34000 - 0xc0b81c00   ( 311 kB)
<5>[    0.000000]        .bss : 0xc0b84024 - 0xc1609640   (10774 kB)
<6>[    0.000000] Preemptible hierarchical RCU implementation.
<6>[    0.000000] NR_IRQS:388
<4>[    0.000000] rk29_gpio_init: 224 gpio irqs in 7 banks
<6>[    0.000000] sched_clock: 32 bits at 36MHz, resolution 27ns, wraps every 119304ms
<6>[    0.000000] Console: colour dummy device 80x30
<6>[    0.005382] Calibrating delay loop (skipped) preset value.. 299.83 BogoMIPS (lpj=1499184)
<6>[    0.014515] pid_max: default: 32768 minimum: 301
<6>[    0.019986] Mount-cache hash table entries: 512
<6>[    0.025689] Initializing cgroup subsys debug
<6>[    0.030491] Initializing cgroup subsys cpuacct
<6>[    0.035528] Initializing cgroup subsys freezer
<6>[    0.040556] CPU: Testing write buffer coherency: ok
<6>[    0.047039] devtmpfs: initialized
<6>[    0.059647] print_constraints: dummy:
<6>[    0.064233] NET: Registered protocol family 16
<4>[    0.069294] last_log: 0xd3480000 0xc0b85368
<6>[    0.182972] rk29sdk_wifi_bt_gpio_control_init: init finished
<6>[    0.221314] bio: create slab <bio-0> at 0
<6>[    0.226653] print_constraints: PWM2: 950 <--> 1400 mV at 1200 mV
<6>[    0.233658] pwm_regulator: driver initialized
<5>[    0.239413] SCSI subsystem initialized
<6>[    0.244121] usbcore: registered new interface driver usbfs
<6>[    0.250401] usbcore: registered new interface driver hub
<6>[    0.256564] usbcore: registered new device driver usb
<6>[    0.263080] rk29_i2c rk29_i2c.0: i2c-0: RK29 I2C adapter
<6>[    0.269349] rk29_i2c rk29_i2c.1: i2c-1: RK29 I2C adapter
<6>[    0.275709] rk29_i2c rk29_i2c.2: i2c-2: RK29 I2C adapter
<6>[    0.281933] rk29_i2c rk29_i2c.3: i2c-3: RK29 I2C adapter
<6>[    0.288169] rk29-adc rk29-adc: rk29 adc: driver initialized
<6>[    0.294949] Advanced Linux Sound Architecture Driver Version 1.0.24.
<6>[    0.302912] Bluetooth: Core ver 2.16
<6>[    0.307037] NET: Registered protocol family 31
<6>[    0.312057] Bluetooth: HCI device and connection manager initialized
<6>[    0.319147] Bluetooth: HCI socket layer initialized
<6>[    0.324624] Bluetooth: L2CAP socket layer initialized
<6>[    0.330302] Bluetooth: SCO socket layer initialized
<6>[    0.336108] Switching to clocksource timer3
<6>[    0.341794] Switched to NOHz mode on CPU #0
<4>[    0.400017]  rk29fb_probe ok
<6>[    0.416874] NET: Registered protocol family 2
<6>[    0.422121] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
<6>[    0.430526] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
<6>[    0.439295] TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
<6>[    0.446986] TCP: Hash tables configured (established 16384 bind 16384)
<6>[    0.454290] TCP reno registered
<6>[    0.457849] UDP hash table entries: 256 (order: 0, 4096 bytes)
<6>[    0.464415] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
<6>[    0.471908] NET: Registered protocol family 1
<6>[    0.477147] Unpacking initramfs...
<6>[    0.882859] Freeing initrd memory: 2368K
<4>[    0.887746] RK29 Backlight Driver Initialized.
<6>[    0.892969] PMU: registered new PMU device of type 0
<6>[    0.898941] Loaded driver for PL330 DMAC-0 rk29-pl330
<6>[    0.904653]       DBUFF-32x8bytes Num_Chans-6 Num_Peri-8 Num_Events-3
<6>[    0.911606] Loaded driver for PL330 DMAC-1 rk29-pl330
<6>[    0.917271]       DBUFF-64x8bytes Num_Chans-7 Num_Peri-20 Num_Events-4
<4>[    0.928852] vpu_mem: 62 initialized
<4>[    0.933033] vpu: power on
<6>[    0.956153] VPU_SERVICE: HW ID = 0x67311148
<6>[    0.960883] VPU_SERVICE: Compatible HW found at 0x10104200
<6>[    0.967020] VPU_SERVICE: HW ID = 0x82701110
<6>[    0.971745] VPU_SERVICE: Compatible HW found at 0x10104000
<4>[    0.978441] vpu: power off...done
<6>[    1.002573] VPU_SERVICE: init success
<6>[    1.026913] bt shut off power
<6>[    1.070655] bt shut off power
<4>[    1.094243] ret=0x0
<6>[    1.110179] ashmem: initialized
<6>[    1.115172] NTFS driver 2.1.30 [Flags: R/W].
<6>[    1.120125] fuse init (API version 7.16)
<6>[    1.127174] io scheduler noop registered
<6>[    1.131791] io scheduler cfq registered (default)
<4>[    1.158436] func anx7150_hw_reset, line 203: request gpio fail
<6>[    1.165395] rk29_i2c rk29_i2c.1: addr: 0x39 receive no ack
<3>[    1.171649] rk29_i2c rk29_i2c.1: i2c transfer err, client address is 0x39 [20110106]
<6>[    1.180429] rk29_i2c rk29_i2c.1: addr: 0x39 receive no ack
<3>[    1.186791] rk29_i2c rk29_i2c.1: i2c transfer err, client address is 0x39 [20110106]
<6>[    1.195597] rk29_i2c rk29_i2c.1: addr: 0x39 receive no ack
<3>[    1.202203] rk29_i2c rk29_i2c.1: i2c transfer err, client address is 0x39 [20110106]
<6>[    1.210926] rk29_i2c rk29_i2c.1: addr: 0x39 receive no ack
<3>[    1.217108] rk29_i2c rk29_i2c.1: i2c transfer err, client address is 0x39 [20110106]
<6>[    1.225847] rk29_i2c rk29_i2c.1: addr: 0x39 receive no ack
<3>[    1.232040] rk29_i2c rk29_i2c.1: i2c transfer err, client address is 0x39 [20110106]
<6>[    1.240764] rk29_i2c rk29_i2c.1: addr: 0x39 receive no ack
<3>[    1.246960] rk29_i2c rk29_i2c.1: i2c transfer err, client address is 0x39 [20110106]
<6>[    1.255693] rk29_i2c rk29_i2c.1: addr: 0x39 receive no ack
<3>[    1.261889] rk29_i2c rk29_i2c.1: i2c transfer err, client address is 0x39 [20110106]
<6>[    1.270612] rk29_i2c rk29_i2c.1: addr: 0x39 receive no ack
<3>[    1.276806] rk29_i2c rk29_i2c.1: i2c transfer err, client address is 0x39 [20110106]
<6>[    1.285533] rk29_i2c rk29_i2c.1: addr: 0x39 receive no ack
<3>[    1.291726] rk29_i2c rk29_i2c.1: i2c transfer err, client address is 0x39 [20110106]
<6>[    1.300449] rk29_i2c rk29_i2c.1: addr: 0x39 receive no ack
<3>[    1.306644] rk29_i2c rk29_i2c.1: i2c transfer err, client address is 0x39 [20110106]
<3>[    1.315247] anx7150 1-0039: anx7150 is not exist
<4>[    1.320457] anx7150: probe of 1-0039 failed with error -5
<6>[    1.326809] rk29_serial.1: ttyS1 at MMIO 0x20060000 (irq = 67) is a rk29_serial.1
<6>[    1.335155] rk29_serial rk29_serial.1: baud:115200
<4>[    1.340875] serial.1 timeout:1000000
<6>[    1.344899] console [ttyS1] enabled, bootconsole disabled
<6>[    1.370835] rk29_serial rk29_serial.1: membase 0xd4016000
<6>[    1.376252] rk29_serial.0: ttyS0 at MMIO 0x20030000 (irq = 66) is a rk29_serial.0
<6>[    1.400869] rk29_serial rk29_serial.0: membase 0xd401e000
<6>[    1.406342] rk29_serial.2: ttyS2 at MMIO 0x20064000 (irq = 68) is a rk29_serial.2
<6>[    1.430905] rk29_serial rk29_serial.2: membase 0xd4026000
<6>[    1.444284] loop: module loaded
<6>[    1.447569] pmem_cam: 1 init
<6>[    1.453834] pmem: 1 init
<6>[    1.459646] Android kernel panic handler initialized (bind=kpanic)
<4>[    1.466052] drivers/misc/rk29_modem/modem_rockchip_demo.c[57]: demo_init
<4>[    1.472843] drivers/misc/rk29_modem/rk29_modem.c[282]: rk29_modem_init
<4>[    1.479828] drivers/misc/rk29_modem/rk29_modem.c[208]: rk29_modem_dev_init
<6>[    1.487058] PPP generic driver version 2.4.2
<6>[    1.491451] PPP Deflate Compression module registered
<6>[    1.496497] PPP BSD Compression module registered
<6>[    1.501756] PPP MPPE Compression module registered
<6>[    1.506546] NET: Registered protocol family 24
<6>[    1.511020] tun: Universal TUN/TAP device driver, 1.6
<6>[    1.516067] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
<4>[    1.522385] Rockchip WiFi SYS interface (V1.00) ...
<6>[    1.527372] Initializing USB Mass Storage driver...
<6>[    1.532324] usbcore: registered new interface driver usb-storage
<6>[    1.538325] USB Mass Storage support registered.
<6>[    1.543042] usbcore: registered new interface driver usbserial
<6>[    1.548896] USB Serial support registered for generic
<6>[    1.553990] usbcore: registered new interface driver usbserial_generic
<6>[    1.560508] usbserial: USB Serial Driver core
<6>[    1.564893] USB Serial support registered for GSM modem (1-port)
<6>[    1.570937] usbcore: registered new interface driver option
<6>[    1.576504] option: v0.7.2:USB Driver for GSM modems
<6>[    1.581561] DWC_OTG: dwc_otg_driver_probe otg2.0 reg addr: 0x10180000 remap:0xd4080000
<6>[    1.799731] DWC_OTG: ^^^^^^^^^^^^^^^^^Device Mode
<6>[    1.804465] usb20_otg usb20_otg: DWC OTG Controller
<6>[    1.809353] usb20_otg usb20_otg: new USB bus registered, assigned bus number 1
<6>[    1.816604] usb20_otg usb20_otg: irq 48, io mem 0x00000000
<6>[    1.822095] DWC_OTG: dwc_otg_hcd_start controller in device mode,everest
<6>[    1.828840] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
<6>[    1.835635] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[    1.842857] usb usb1: Product: DWC OTG Controller
<6>[    1.847555] usb usb1: Manufacturer: Linux 3.0.8+ dwc_otg_hcd
<6>[    1.853218] usb usb1: SerialNumber: usb20_otg
<6>[    1.857871] hub 1-0:1.0: USB hub found
<6>[    1.861648] hub 1-0:1.0: 1 port detected
<6>[    1.865890] DWC_OTG: host20_driver_probe host2.0 reg addr: 0x101c0000 remap:0xd4100000
<6>[    2.084214] DWC_OTG: ^^^^^^^^^^^^^^^^^^Host Mode
<6>[    2.088835] usb20_host usb20_host: DWC OTG Controller
<6>[    2.093911] usb20_host usb20_host: new USB bus registered, assigned bus number 2
<6>[    2.101326] usb20_host usb20_host: irq 49, io mem 0x00000000
<6>[    2.106992] DWC_OTG: Init: Port Power? op_state=1
<6>[    2.111688] DWC_OTG: Init: Power Port (0)
<6>[    2.115737] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
<6>[    2.122529] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[    2.129743] usb usb2: Product: DWC OTG Controller
<6>[    2.134451] usb usb2: Manufacturer: Linux 3.0.8+ host20_hcd
<6>[    2.140015] usb usb2: SerialNumber: usb20_host
<6>[    2.144763] hub 2-0:1.0: USB hub found
<6>[    2.148515] hub 2-0:1.0: 1 port detected
<6>[    2.152692] DWC_OTG: host11_driver_probe host1.1 reg addr: 0x10140000 remap:0xd4180000
<6>[    2.370875] DWC_OTG: ^^^^^^^^^^^^^^^^^^Host Mode
<6>[    2.375494] usb11_host usb11_host: DWC OTG Controller
<6>[    2.380552] usb11_host usb11_host: new USB bus registered, assigned bus number 3
<6>[    2.387964] usb11_host usb11_host: irq 50, io mem 0x00000000
<6>[    2.393641] DWC_OTG: Init: Port Power? op_state=1
<6>[    2.398337] DWC_OTG: Init: Power Port (0)
<6>[    2.402386] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
<6>[    2.409167] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[    2.416394] usb usb3: Product: DWC OTG Controller
<6>[    2.421102] usb usb3: Manufacturer: Linux 3.0.8+ host11_hcd
<6>[    2.426666] usb usb3: SerialNumber: usb11_host
<6>[    2.431378] hub 3-0:1.0: USB hub found
<6>[    2.435131] hub 3-0:1.0: 1 port detected
<6>[    2.440073] android_usb gadget: Mass Storage Function, version: 2009/09/11
<6>[    2.446966] android_usb gadget: Number of LUNs=1
<6>[    2.451592]  lun0: LUN: removable file: (no medium)
<6>[    2.456596] android_usb gadget: android_usb ready
<6>[    2.461516] input: rk29-keypad as /devices/platform/rk29-keypad/input/input0
<6>[    2.468780] usbcore: registered new interface driver xpad
<6>[    2.474248] usbcore: registered new interface driver usb_acecad
<6>[    2.480160] acecad: v3.2:USB Acecad Flair tablet driver
<6>[    2.485424] usbcore: registered new interface driver aiptek
<6>[    2.491000] aiptek: v2.3 (May 2, 2007):Aiptek HyperPen USB Tablet Driver (Linux 2.6.x)
<6>[    2.498905] aiptek: Bryan W. Headley/Chris Atenasio/Cedric Brun/Rene van Paassen
<6>[    2.506331] usbcore: registered new interface driver gtco
<4>[    2.511733] GTCO usb driver version: 2.00.0006
<6>[    2.516029] usbcore: registered new interface driver hanwang
<6>[    2.521909] usbcore: registered new interface driver kbtab
<6>[    2.527389] kbtab: v0.0.2:USB KB Gear JamStudio Tablet driver
<6>[    2.533212] usbcore: registered new interface driver wacom
<6>[    2.538690] wacom: v1.52:USB Wacom tablet driver
<4>[    2.543317] ft5x0x module init
<4>[    2.546405] ft5x0x_probe enter
<6>[    2.550966] input: gsensor as /devices/platform/rk29_i2c.0/i2c-0/0-004c/input/input1
<4>[    2.558867] i2c-core: driver [mma7660] using legacy suspend method
<4>[    2.580818] i2c-core: driver [mma7660] using legacy resume method
<6>[    2.604672] using rtc device, rtc_hym8563, for alarms
<6>[    2.609563] rtc_hym8563 0-0051: rtc core: registered rtc_hym8563 as rtc0
<6>[    2.631024] lirc_dev: IR Remote Control driver registered, major 252
<6>[    2.637459] IR NEC protocol handler initialized
<6>[    2.660818] IR RC5(x) protocol handler initialized
<6>[    2.665603] IR RC6 protocol handler initialized
<6>[    2.670126] IR JVC protocol handler initialized
<6>[    2.680818] IR Sony protocol handler initialized
<6>[    2.685427] IR RC5 (streamzap) protocol handler initialized
<6>[    2.700833] IR LIRC bridge handler initialized
<6>[    2.705277] Linux video capture interface: v2.00
<6>[    2.820830] usb 3-1: new full speed USB device number 2 using usb11_host
<6>[    2.827534] DWC_OTG: dwc_otg_hcd_qh_init tt->hub null!
<6>[    3.050824] DWC_OTG: dwc_otg_hcd_qh_init tt->hub null!
<4>[    3.059093] rk2918_low_battery_check: gBatVoltage = 3800, gBatCapacity = 2
<6>[    3.070504] rk2918_battery: driver initialized
<6>[    3.077151] usb 3-1: New USB device found, idVendor=12d1, idProduct=1001
<6>[    3.090930] device-mapper: uevent: version 1.0.3
<6>[    3.095631] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
<6>[    3.102844] device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: dm-devel@redhat.com
<6>[    3.120821] usb 3-1: Product: HUAWEI Mobile
<6>[    3.125086] usb 3-1: Manufacturer: HUAWEI Technology
<6>[    3.130315] Bluetooth: HCI UART driver ver 2.2
<6>[    3.140822] Bluetooth: HCI H4 protocol initialized
<6>[    3.145610] Bluetooth: HCI BCSP protocol initialized
<6>[    3.150568] Bluetooth: HCILL protocol initialized
<4>[    3.155793] Skip device
<6>[    3.158282] option 3-1:1.0: GSM modem (1-port) converter detected
<6>[    3.170849] DWC_OTG: dwc_otg_hcd_qh_init tt->hub null!
<6>[    3.176136] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB0
<6>[    3.190827] Bluetooth: HCIATH3K protocol initialized
<6>[    3.195795] Bluetooth: Broadcom Blutonium firmware driver ver 1.2
<4>[    3.210971] Skip device
<6>[    3.213445] option 3-1:1.1: GSM modem (1-port) converter detected
<6>[    3.219681] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB1
<6>[    3.226546] usbcore: registered new interface driver bcm203x
<6>[    3.240824] Bluetooth: Generic Bluetooth USB driver ver 0.6
<6>[    3.246450] usbcore: registered new interface driver btusb
<4>[    3.260940] Skip device
<6>[    3.263412] option 3-1:1.2: GSM modem (1-port) converter detected
<6>[    3.269653] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB2
<4>[    3.397018] rk29_sdmmc_change_clk_div..1663..  newDiv=80, newCLK=300Khz====xbw[sd_mmc]=====
<4>[    3.426028] .Line3352..The End of SDMMC-probe Ver.2.14 The last modify date is 2011-11-17,modifyed by XBW. ===xbw[sd_mmc]===
<4>[    3.426036]
<4>[    3.438764]
<4>[    3.438766] drivers/mmc/core/core.c...1823..  ===== mmc_rescan Begin....======xbw[mmc0]=====
<4>[    3.460821]
<4>[    3.460823] =================
<4>[    3.460826] mmc_rescan..1830..  ====find no SDMMC host.====xbw[mmc0]=====
<4>[    3.610991] sdmmc_send_cmd_start.. 1337   set cmd(value=0x202000) register timeout error !   ====xbw[sdio]====
<4>[    3.630820]
<4>[    3.630823] drivers/mmc/host/rk29_sdmmc.c....1580..  control clock fail!!! Enable=0, ret=0xb ===xbw[sdio]====
<4>[    3.650821] drivers/mmc/host/rk29_sdmmc.c..1678..  change division fail, errorStep=0x9,ret=11  !!! ====xbw[sdio]====
<4>[    3.670894]
<4>[    3.670896] drivers/mmc/core/core.c...1823..  ===== mmc_rescan Begin....======xbw[mmc1]=====
<4>[    3.680855] .Line3352..The End of SDMMC-probe Ver.2.14 The last modify date is 2011-11-17,modifyed by XBW. ===xbw[sdio]===
<4>[    3.680863]
<4>[    3.700820]
<4>[    3.700822] =================
<4>[    3.700825] mmc_rescan..1830..  ====find no SDMMC host.====xbw[mmc1]=====
<6>[    3.719383] usbcore: registered new interface driver usbhid
<6>[    3.724993] usbhid: USB HID core driver
<6>[    3.739246] logger: created 256K log 'log_main'
<6>[    3.743906] logger: created 256K log 'log_events'
<6>[    3.748670] logger: created 256K log 'log_radio'
<6>[    3.753389] logger: created 256K log 'log_system'
<4>[    3.758229] ft5406 g_vid = 0x51
<4>[    3.761452] ---- gpu regbase: 0xd4050000 ----
<4>[    3.771410] r_value = 7
<4>[    3.771414] , i = 0, flag = 1
<6>[    3.776802] input: ft5x0x-ts as /devices/platform/rk29_i2c.2/i2c-2/2-0038/input/input2
<4>[    3.810385] -----> dma_alloc_writecombine 1 pages!
<4>[    3.815211] -----> dma_alloc_writecombine 1 pages!
<4>[    3.820037] -----> dma_alloc_writecombine 128 pages!
<4>[    3.825850] -----> dma_alloc_writecombine 1 pages!
<6>[    3.835270] RT5631 Audio Codec 0.01 alsa 1.0.24
<6>[    3.970767] RT5631 initial ok!
<3>[    3.973865] RT5631 0-001a: dapm: unknown pin HP_L
<3>[    3.978574] RT5631 0-001a: dapm: unknown pin HP_R
<6>[    4.001835] asoc: RT5631 HiFi <-> rk29_i2s.0 mapping ok
<6>[    4.007397] ALSA device list:
<6>[    4.010374]   #0: RK29_RT5631
<6>[    4.013444] GACT probability NOT on
<6>[    4.016941] Mirror/redirect action on
<6>[    4.020609] u32 classifier
<6>[    4.023329]     Actions configured
<6>[    4.026736] Netfilter messages via NETLINK v0.30.
<6>[    4.031505] nf_conntrack version 0.5.0 (4704 buckets, 18816 max)
<6>[    4.037736] ctnetlink v0.93: registering with nfnetlink.
<6>[    4.043244] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
<6>[    4.050212] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
<6>[    4.056282] xt_time: kernel timezone is -0000
<6>[    4.060807] ip_tables: (C) 2000-2006 Netfilter Core Team
<6>[    4.066270] arp_tables: (C) 2002 David S. Miller
<6>[    4.070950] TCP cubic registered
<6>[    4.074266] NET: Registered protocol family 10
<6>[    4.079196] Mobile IPv6
<6>[    4.081695] ip6_tables: (C) 2000-2006 Netfilter Core Team
<6>[    4.087212] IPv6 over IPv4 tunneling driver
<6>[    4.092042] NET: Registered protocol family 17
<6>[    4.096514] NET: Registered protocol family 15
<5>[    4.101032] Bridge firewalling registered
<6>[    4.105165] Bluetooth: RFCOMM TTY layer initialized
<6>[    4.110054] Bluetooth: RFCOMM socket layer initialized
<6>[    4.115250] Bluetooth: RFCOMM ver 1.11
<6>[    4.119005] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
<6>[    4.124332] Bluetooth: BNEP filters: protocol multicast
<6>[    4.129560] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
<6>[    4.135598] NET: Registered protocol family 35
<4>[    4.140196] drivers/media/video/fcam.c sensor_mod_init
<7>[    4.145397]
<7>[    4.145400] sensor_mod_init..ov2655..
<4>[    4.145407]
<4>[    4.145409] sensor_mod_init..nt99250..
<4>[    4.150734] ***
<4>[    4.150736] sensor_mod_init..gc0307..
<4>[    4.156244]
<4>[    4.156247] sensor_mod_init..gt2005..
<3>[    4.161521] RK29 Camera driver version: v0.1.7
<6>[    4.166192] camera 33-0: Probing 33-0
<6>[    4.170271] camera 33-1: Probing 33-1
<4>[    4.174187]
<4>[    4.174191] sensor_probe..drivers/media/video/fcam.c..452..
<4>[    4.181378] drivers/media/video/fcam.c sensor_video_probe
<7>[    4.186786] ov2655 sensor_ioctrl  cmd(1) on(0)
<6>[    4.188955] rk29_i2c rk29_i2c.1: addr: 0x30 receive no ack
<3>[    4.194537] rk29_i2c rk29_i2c.1: i2c transfer err, client address is 0x30 [20110106]
<3>[    4.202297]
<3>[    4.202300]  ov2655 write reg(0x3012, val:0x80) failed, try to write again!
<6>[    4.210893] rk29_i2c rk29_i2c.1: addr: 0x30 receive no ack
<3>[    4.216451] rk29_i2c rk29_i2c.1: i2c transfer err, client address is 0x30 [20110106]
<3>[    4.224202]
<3>[    4.224205]  ov2655 write reg(0x3012, val:0x80) failed, try to write again!
<6>[    4.232808] rk29_i2c rk29_i2c.1: addr: 0x30 receive no ack
<3>[    4.238367] rk29_i2c rk29_i2c.1: i2c transfer err, client address is 0x30 [20110106]
<3>[    4.246117]
<3>[    4.246119]  ov2655 write reg(0x3012, val:0x80) failed, try to write again!
<3>[    4.254587] soft reset ov2655 failed
<4>[    4.258167] XXX sensor_video_probe(): probe failed for ov2655
<4>[    4.258171]
<4>[    4.265409] *** nt99250 sensor_video_probe() set power on
<4>[    4.270824] nt99250 sensor_ioctrl  cmd(1) on(0)
<6>[    4.277422] rk29_i2c rk29_i2c.1: addr: 0x36 receive no ack
<3>[    4.282990] rk29_i2c rk29_i2c.1: i2c transfer err, client address is 0x36 [20110106]
<3>[    4.290733]
<3>[    4.290735]  nt99250 read reg(0x307e val:0xc0) failed, try to read again!
<6>[    4.299175] rk29_i2c rk29_i2c.1: addr: 0x36 receive no ack
<3>[    4.304745] rk29_i2c rk29_i2c.1: i2c transfer err, client address is 0x36 [20110106]
<3>[    4.312499]
<3>[    4.312502]  nt99250 read reg(0x307e val:0xc0) failed, try to read again!
<6>[    4.320937] rk29_i2c rk29_i2c.1: addr: 0x36 receive no ack
<3>[    4.326496] rk29_i2c rk29_i2c.1: i2c transfer err, client address is 0x36 [20110106]
<3>[    4.334249]
<3>[    4.334251]  nt99250 read reg(0x307e val:0xc0) failed, try to read again!
<3>[    4.342629] read chip id high byte failed
<4>[    4.346642] XXX sensor_video_probe(): probe failed for nt99250
<4>[    4.346646]
<4>[    4.353972] +++sensor_video_probe():
<4>[    4.357633] sensor_video_probe()
<4>[    4.360870] *** sensor_video_probe set powerdown
<4>[    4.365492] ***gc0307 sensor_ioctrl  cmd(1) on(0)
<4>[    4.370196] +++sensor_ioctrl(): Sensor_PowerDown
<6>[    4.376977] rk29_i2c rk29_i2c.1: addr: 0x21 receive no ack
<3>[    4.382546] rk29_i2c rk29_i2c.1: i2c transfer err, client address is 0x21 [20110106]
<4>[    4.390288]
<4>[    4.390291]  gc0307 read reg(0x0 val:0x0) failed, try to read again!
<4>[    4.398235] gc0307 read chip id high byte failed
<4>[    4.402865] XXX sensor_video_probe(): probe failed for gc0307
<4>[    4.402870]
<6>[    4.431274] rk29_i2c rk29_i2c.1: addr: 0x21 receive no ack
<3>[    4.436836] rk29_i2c rk29_i2c.1: i2c transfer err, client address is 0x21 [20110106]
<3>[    4.444638]
<3>[    4.444640]  ov7675 write reg(0x12, val:0x80) failed, try to write again!
<6>[    4.453003] rk29_i2c rk29_i2c.1: addr: 0x21 receive no ack
<3>[    4.458563] rk29_i2c rk29_i2c.1: i2c transfer err, client address is 0x21 [20110106]
<3>[    4.466364]
<3>[    4.466367]  ov7675 write reg(0x12, val:0x80) failed, try to write again!
<6>[    4.474727] rk29_i2c rk29_i2c.1: addr: 0x21 receive no ack
<3>[    4.480287] rk29_i2c rk29_i2c.1: i2c transfer err, client address is 0x21 [20110106]
<3>[    4.488089]
<3>[    4.488091]  ov7675 write reg(0x12, val:0x80) failed, try to write again!
<3>[    4.496385] soft reset ov7675 failed
<4>[    4.499964] XXX sensor_video_probe(): probe failed for ov7675
<4>[    4.499969]
<6>[    4.509287] rk29_i2c rk29_i2c.1: addr: 0x21 receive no ack
<3>[    4.514865] rk29_i2c rk29_i2c.1: i2c transfer err, client address is 0x21 [20110106]
<3>[    4.522617]
<3>[    4.522620]  gc0308 read reg(0x0 val:0x0) failed, try to read again!
<3>[    4.530554] gc0308 read chip id high byte failed
<4>[    4.535183] XXX sensor_video_probe(): probe failed for gc0308
<4>[    4.535188]
<4>[    4.542429] gt2005 sensor_ioctrl  cmd(1) on(1)
<4>[    4.548220]
<4>[    4.548222]  gt2005  pid = 0x5138
<4>[    4.553035] OOO sensor_video_probe(): probe OK for gt2005
<4>[    4.553040]
<4>[    4.559921]
<4>[    4.559924] sensor_probe..drivers/media/video/fcam.c..501  ret = 0
<4>[    4.568253]
<4>[    4.568256] gt2005..sensor_ioctl..cmd:1
<4>[    4.573690]
<4>[    4.573692] gt2005..sensor_deactivate.. Enter
<4>[    4.579560] gt2005 sensor_ioctrl  cmd(1) on(0)
<4>[    4.691575] ipp irq 46
<6>[    4.694510] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
<6>[    4.702398] ThumbEE CPU extension supported.
<6>[    4.709403] rtc_hym8563 0-0051: setting system clock to 2012-11-29 18:42:35 UTC (1354214555)
<6>[    4.718937] rk29_serial rk29_serial.1: baud:115200
<4>[    4.723891] serial.1 timeout:1000000
<6>[    4.728424] Freeing init memory: 624K
<4>[    4.735242] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
<3>[    4.795445] init: could not open /dev/keychord
<6>[    4.800073] rk29_serial rk29_serial.1: baud:115200
<4>[    4.804899] serial.1 timeout:1000000
<4>[    4.872778] rk29xxnand_ko: module license '' taints kernel.
<4>[    4.878378] Disabling lock debugging due to kernel taint
<4>[    4.889437] gp_rknand_info = : 0xd2e79740
<4>[    4.893861] FlashCopyProgBuf1=0xc14aa000
<4>[    4.897843] ATime: 40 ns AHB: 144 timming: 1081
<4>[    4.902402] No.1 FLASH INFO:2c 68 4 4a a9
<4>[    4.907118] ATime: 32 ns AHB: 144 timming: 1061
<4>[    4.911814] ATime: 32 ns AHB: 144 timming: 1061
<4>[    4.916350] randomizer = 0 , EccBits = 18
<4>[    4.949279] FTL INFO:Version = 438,Date = 20120806
<4>[    4.954083] totalLogicBlkRaw  = 1907
<4>[    4.957686] gBootMedia = 0 gSdmmcFwPartOffset =0!
<5>[    4.962612] 10 cmdlinepart partitions found on MTD device rk29xxnand
<5>[    4.968973] Creating 10 MTD partitions on "rk29xxnand":
<5>[    4.974237] 0x000000400000-0x000000800000 : "misc"
<5>[    4.980244] 0x000000800000-0x000001000000 : "kernel"
<5>[    4.986125] 0x000001000000-0x000002000000 : "boot"
<5>[    4.991754] 0x000002000000-0x000003000000 : "recovery"
<5>[    4.997712] 0x000003000000-0x000012000000 : "backup"
<5>[    5.003806] 0x000012000000-0x000019400000 : "cache"
<5>[    5.009642] 0x000019400000-0x000059400000 : "userdata"
<5>[    5.016767] 0x000059400000-0x000059800000 : "kpanic"
<6>[    5.022785] apanic: Bound to mtd partition 'kpanic'
<6>[    5.027670] apanic: No panic data available
<5>[    5.032035] 0x000059800000-0x000071800000 : "system"
<5>[    5.038326] 0x000071800000-0x0000ee600000 : "user"
<4>[    5.046201] startBlk = 157  sysProtAddr = 156
<6>[    5.074416] EXT3-fs: barriers not enabled
<6>[    5.078603] EXT3-fs (mtdblock8): mounted filesystem with ordered data mode
<6>[    5.085530] kjournald starting.  Commit interval 5 seconds
<6>[    5.108500] EXT3-fs: barriers not enabled
<6>[    5.112789] EXT3-fs (mtdblock6): using internal journal
<6>[    5.118028] EXT3-fs (mtdblock6): mounted filesystem with ordered data mode
<6>[    5.124950] kjournald starting.  Commit interval 5 seconds
<6>[    5.140386] EXT3-fs: barriers not enabled
<6>[    5.144664] EXT3-fs (mtdblock5): using internal journal
<6>[    5.149906] EXT3-fs (mtdblock5): mounted filesystem with ordered data mode
<6>[    5.156830] kjournald starting.  Commit interval 5 seconds
<3>[    5.185963] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
<3>[    5.219209] init: skipping insecure file '/system/lib/modules/wlan.ko'
<6>[    5.235031] rk29_serial rk29_serial.0: baud:9600
<4>[    5.246084] serial.0 timeout:1000000
<6>[    5.254697] rk29_serial rk29_serial.2: baud:9600
<4>[    5.259329] serial.2 timeout:1000000
<6>[    5.275018] rk29_serial rk29_serial.2: baud:9600
<4>[    5.279650] serial.2 timeout:1000000
<6>[    5.290749] rk29_serial rk29_serial.0: baud:9600
<4>[    5.300938] serial.0 timeout:1000000
<3>[    5.306245] init: using deprecated syntax for specifying property 'ro.product.usbfactory', use ${name} instead
<3>[    5.323455] android_usb: already disabled
<6>[    5.328070] rk29_serial rk29_serial.1: baud:115200
<6>[    5.333676] DWC_OTG: USB SUSPEND
<4>[    5.337579] serial.1 timeout:1000000
<3>[    5.937951] EXT3-fs (mtdblock8): error: unrecognized mount option "noauto_da_alloc" or missing value
<4>[    5.978252] .334.. MMC0 receive the message sd-No-Media from VOLD.====xbw[sd_mmc]====
<4>[    5.986144] .359.. MMC0 receive the message No-Media from VOLD. waitTimes=0 ====xbw[sd_mmc]====
<3>[    6.001865] EXT3-fs (mtdblock6): error: unrecognized mount option "noauto_da_alloc" or missing value
<4>[    6.045731] Current WiFi chip is BCM4329.
<3>[    6.071591] EXT3-fs (mtdblock5): error: unrecognized mount option "noauto_da_alloc" or missing value
<4>[    7.007222]
<4>[    7.007228] gt2005..sensor_ioctl..cmd:2
<4>[    7.025886]
<4>[    7.025890] gt2005..sensor_ioctl..cmd:3
<3>[    7.044276] gt2005 sensor_ioctl cmd(0x3) is unknown !
<4>[    7.063187]
<4>[    7.063192] gt2005..sensor_ioctl..cmd:1
<4>[    7.068612]
<4>[    7.068615] gt2005..sensor_deactivate.. Enter
<4>[    7.124261] gt2005 sensor_ioctrl  cmd(1) on(0)
<3>[    8.009494] init: sys_prop: permission denied uid:1003  name:sys.gvglk.version
<3>[    8.034519] init: sys_prop: permission denied uid:1003  name:sys.gvglu.version
<4>[    8.935686] ion_ioctl: alloc 0x1db000 bytes, phy addr is 0x7a000000
<4>[    9.220064] ion_ioctl: alloc 0x1db000 bytes, phy addr is 0x7a1db000
<4>[    9.272038] gpu: change freq to 552, got 426
<6>[   17.920880] DWC_OTG: ********vbus detect*********************************************
<6>[   18.367171] DWC_OTG: ********soft connect!!!*****************************************
<6>[   18.378704] DWC_OTG: USB SUSPEND
<6>[   18.496973] DWC_OTG: USB RESET
<6>[   18.586454] DWC_OTG: USB RESET
<6>[   18.690945] android_work: sent uevent USB_STATE=CONNECTED
<6>[   18.710619] android_usb gadget: high speed config #1: android
<6>[   18.710761] android_work: sent uevent USB_STATE=CONFIGURED
<6>[   18.948536] DWC_OTG: dwc_otg_hcd_qh_init tt->hub null!
<6>[   19.062467] DWC_OTG: dwc_otg_hcd_qh_init tt->hub null!
<6>[   22.028978] warning: `zygote' uses 32-bit capabilities (legacy support in use)
<6>[   32.012725] bt turn on power
<6>[   32.627912] rk29_serial rk29_serial.2: baud:9600
<4>[   32.627923] serial.2 timeout:1000000
<6>[   32.627971] rk29_serial rk29_serial.2: baud:9600
<4>[   32.627978] serial.2 timeout:1000000
<6>[   32.628005] rk29_serial rk29_serial.2: baud:115200
<4>[   32.628011] serial.2 timeout:1000000
<4>[   32.877770] Current WiFi chip is BCM4329.
<4>[   32.894131] =======================================================
<4>[   32.931491] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
<4>[   32.969657] =======================================================
<4>[   33.005159] BCM4329 Wi-Fi driver (Powered by Rockchip,Ver 2.00) init.
<4>[   33.043549] wifi_set_power = 1
<6>[   33.065042] rk29sdk_wifi_power: 1
<6>[   33.141768] acc_open
<6>[   33.154547] acc_release
<6>[   34.470260] wifi turn on power
<4>[   34.490951] wifi_set_carddetect = 1
<6>[   34.510180] rk29sdk_wifi_set_carddetect:1
<6>[   34.510194] mmc1: slot status change detected(0-1)
<4>[   34.510244] rk29_sdmmc_change_clk_div..1663..  newDiv=40, newCLK=300Khz====xbw[sdio]=====
<4>[   34.514176]
<4>[   34.514182] Dongle Host Driver, version 4.218.248.18
<4>[   34.700880]
<4>[   34.700887] drivers/mmc/core/core.c...1823..  ===== mmc_rescan Begin....======xbw[mmc1]=====
<4>[   34.744951]
<4>[   34.744955] mmc_attach_sdio..800..  ===== Begin to identify card as SDIO-card===xbw[mmc1]===
<7>[   34.778657] mmc1: queuing unknown CIS tuple 0x80 (50 bytes)
<7>[   34.820919] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
<4>[   34.824541] rk29_sdmmc_change_clk_div..1663..  newDiv=0, newCLK=24000Khz====xbw[sdio]=====
<6>[   34.835394] mmc1: new high speed SDIO card at address 0001
<4>[   34.850219] DHD: dongle ram size is set to 294912(orig 294912)
<6>[   35.826669] rk29_i2c rk29_i2c.0: addr: 0x4c receive no ack
<3>[   35.826757] rk29_i2c rk29_i2c.0: i2c transfer err, client address is 0x4c [20110106]
<6>[   35.826828] rk29_i2c rk29_i2c.0: addr: 0x4c receive no ack
<3>[   35.826914] rk29_i2c rk29_i2c.0: i2c transfer err, client address is 0x4c [20110106]
<4>[   35.826923] [ZWP]mma7660_set_rate,rate = 32
<6>[   35.826988] rk29_i2c rk29_i2c.0: addr: 0x4c receive no ack
<3>[   35.827066] rk29_i2c rk29_i2c.0: i2c transfer err, client address is 0x4c [20110106]
<6>[   35.827132] rk29_i2c rk29_i2c.0: addr: 0x4c receive no ack
<3>[   35.827210] rk29_i2c rk29_i2c.0: i2c transfer err, client address is 0x4c [20110106]
<6>[   35.827275] rk29_i2c rk29_i2c.0: addr: 0x4c receive no ack
<3>[   35.827353] rk29_i2c rk29_i2c.0: i2c transfer err, client address is 0x4c [20110106]
<6>[   35.827419] rk29_i2c rk29_i2c.0: addr: 0x4c receive no ack
<3>[   35.827497] rk29_i2c rk29_i2c.0: i2c transfer err, client address is 0x4c [20110106]
<4>[   35.980967] dhdsdio_htclk: HT Avail timeout (1000000): clkctl 0x50
<4>[   35.980981] dhd_bus_init: Failed to set backplane clock: err -1
<4>[   35.981021] dhd_bus_start, dhd_bus_init failed -1
<4>[   35.981028] dhdsdio_probe: failed
<4>[   36.265890] ion_ioctl: alloc 0x1db000 bytes, phy addr is 0x7a3b6000
<4>[   36.618697] ion_ioctl: alloc 0x1c8000 bytes, phy addr is 0x7a591000
<4>[   36.990957] dhdsdio_htclk: HT Avail timeout (1000000): clkctl 0x50
<4>[   37.152092] ion_ioctl: alloc 0x1c8000 bytes, phy addr is 0x7a759000
<4>[   38.000906] dhdsdio_htclk: HT Avail timeout (1000000): clkctl 0x50
<4>[   38.001202] mmc_rescan_try_freq..1674..  ===== Initialize SDIO successfully. ===xbw[mmc1]===
<6>[   42.561063] bt shouldn't shut off power, wifi is using it!
<4>[   47.996822] ion_ioctl: alloc 0x378000 bytes, phy addr is 0x7a921000
<4>[   49.708817] ion_ioctl: alloc 0xf000 bytes, phy addr is 0x7a3b6000
<3>[   49.950169] init: sys_prop: permission denied uid:1003  name:service.bootanim.exit
<3>[   50.855995] init: sys_prop: permission denied uid:10025  name:sys.gvglk.version
<3>[   50.870196] init: sys_prop: permission denied uid:10025  name:sys.gvglu.version
<4>[   52.088403] ion_ioctl: alloc 0x1c2000 bytes, phy addr is 0x7a000000
<4>[   52.270541] ion_ioctl: alloc 0x1c2000 bytes, phy addr is 0x7a1c2000
<4>[   52.379452] ion_ioctl: alloc 0x13000 bytes, phy addr is 0x7a384000
<4>[   53.120938] rk2918_get_bat_capacity,first_flag=0,openfailflag=0,openfailcount=19
<4>[   53.183181] bryan---->open file /data/bat_last_capacity.dat failed
<4>[   53.196596] truecapacity = 2
<4>[   53.202691] rk2918_get_bat_capacity,first_flag=0,openfailflag=1,openfailcount=18
<4>[   53.266087] bryan---->open file /data/bat_last_capacity.dat failed
<4>[   53.279452] truecapacity = 1
<4>[   53.287121] rk2918_get_bat_capacity,first_flag=0,openfailflag=1,openfailcount=17
<4>[   53.347786] bryan---->open file /data/bat_last_capacity.dat failed
<4>[   53.362723] truecapacity = 2
<4>[   53.368221] rk2918_get_bat_capacity,first_flag=0,openfailflag=1,openfailcount=16
<4>[   53.432039] bryan---->open file /data/bat_last_capacity.dat failed
<4>[   53.432060] truecapacity = 2
<4>[   53.432697] rk2918_get_bat_capacity,first_flag=0,openfailflag=1,openfailcount=15
<4>[   53.491983] bryan---->open file /data/bat_last_capacity.dat failed
<4>[   53.505322] truecapacity = 2
<4>[   53.511501] rk2918_get_bat_capacity,first_flag=0,openfailflag=1,openfailcount=14
<4>[   53.572915] bryan---->open file /data/bat_last_capacity.dat failed
<4>[   53.587256] truecapacity = 2
<4>[   53.594506] rk2918_get_bat_capacity,first_flag=0,openfailflag=1,openfailcount=13
<4>[   53.657085] bryan---->open file /data/bat_last_capacity.dat failed
<4>[   53.670899] truecapacity = 2
<4>[   53.677563] rk2918_get_bat_capacity,first_flag=0,openfailflag=1,openfailcount=12
<4>[   53.742075] bryan---->open file /data/bat_last_capacity.dat failed
<4>[   53.755647] truecapacity = 2
<4>[   53.763340] rk2918_get_bat_capacity,first_flag=0,openfailflag=1,openfailcount=11
<4>[   53.825684] bryan---->open file /data/bat_last_capacity.dat failed
<4>[   53.839065] truecapacity = 2
<4>[   53.846537] rk2918_get_bat_capacity,first_flag=0,openfailflag=1,openfailcount=10
<4>[   53.909927] bryan---->open file /data/bat_last_capacity.dat failed
<4>[   53.909942] truecapacity = 1
<4>[   53.910021] rk2918_get_bat_capacity,first_flag=0,openfailflag=1,openfailcount=9
<4>[   53.954724] bryan---->open file /data/bat_last_capacity.dat failed
<4>[   53.975366] truecapacity = 2
<4>[   53.985911] rk2918_get_bat_capacity,first_flag=0,openfailflag=1,openfailcount=8
<4>[   54.053751] bryan---->open file /data/bat_last_capacity.dat failed
<4>[   54.068705] truecapacity = 2
<4>[   54.074252] rk2918_get_bat_capacity,first_flag=0,openfailflag=1,openfailcount=7
<4>[   54.137506] bryan---->open file /data/bat_last_capacity.dat failed
<4>[   54.151392] truecapacity = 2
<4>[   54.158662] rk2918_get_bat_capacity,first_flag=0,openfailflag=1,openfailcount=6
<4>[   54.221396] bryan---->open file /data/bat_last_capacity.dat failed
<4>[   54.234690] truecapacity = 2
<4>[   54.241042] rk2918_get_bat_capacity,first_flag=0,openfailflag=1,openfailcount=5
<4>[   54.303938] bryan---->open file /data/bat_last_capacity.dat failed
<4>[   54.317652] truecapacity = 2
<4>[   54.324500] rk2918_get_bat_capacity,first_flag=0,openfailflag=1,openfailcount=4
<4>[   54.391679] bryan---->open file /data/bat_last_capacity.dat failed
<4>[   54.405154] truecapacity = 2
<4>[   54.411750] rk2918_get_bat_capacity,first_flag=0,openfailflag=1,openfailcount=3
<4>[   54.475920] bryan---->open file /data/bat_last_capacity.dat failed
<4>[   54.489545] truecapacity = 2
<4>[   54.495737] rk2918_get_bat_capacity,first_flag=0,openfailflag=1,openfailcount=2
<4>[   54.560655] bryan---->open file /data/bat_last_capacity.dat failed
<4>[   54.573812] truecapacity = 2
<4>[   54.580131] rk2918_get_bat_capacity,first_flag=0,openfailflag=1,openfailcount=1
<4>[   54.642285] bryan---->open file /data/bat_last_capacity.dat failed
<4>[   54.657262] truecapacity = 2
<4>[   54.662502] rk2918_battery_load_capacity...............2
<4>[   54.673884] rk2918_battery_load_capacity...............4
<4>[   54.684845] rk2918_battery_load_capacity...............6
<4>[   54.696442] rk2918_battery_load_capacity...............8
<4>[   54.708680] rk2918_battery_load_capacity...............10
<4>[   54.719341] rk2918_battery_load_capacity...............10
<4>[   55.605589] ion_ioctl: alloc 0x1c2000 bytes, phy addr is 0x7a3c5000
<4>[   55.686571] ion_ioctl: alloc 0xd000 bytes, phy addr is 0x7a397000
<4>[   55.725476] ion_ioctl: alloc 0x1c2000 bytes, phy addr is 0x7a587000
<4>[   55.802060] ion_ioctl: alloc 0x13000 bytes, phy addr is 0x7a749000
<4>[   56.973921] ion_ioctl: alloc 0xf000 bytes, phy addr is 0x7a3a4000
<4>[   57.917650] ion_ioctl: alloc 0x1c8000 bytes, phy addr is 0x7a3b3000
<4>[   57.987242] ion_ioctl: alloc 0x1c8000 bytes, phy addr is 0x7a57b000
<4>[   58.014055] ion_ioctl: alloc 0xf000 bytes, phy addr is 0x7a384000
<4>[   58.104938] ion_ioctl: alloc 0x1c8000 bytes, phy addr is 0x7a743000
<4>[   58.121134] ion_ioctl: alloc 0x1c8000 bytes, phy addr is 0x7ac99000
<4>[   58.232201] ion_ioctl: alloc 0xd000 bytes, phy addr is 0x7a000000
<6>[   62.335732] request_suspend_state: sleep (3->3) at 62334898805 (2012-11-29 18:43:33.124115303 UTC)
<4>[   62.344779] ==ft5x0x_ts_suspend=
<4>[   62.349290] backlight suspend!!
<4>[   62.366872] gpu: change freq to 288, got 288
<4>[   62.376605] gpu: change freq to 552, got 426
<6>[   95.514617] request_suspend_state: wakeup (3->0) at 95513785693 (2012-11-29 18:44:06.303002163 UTC)
<4>[   95.564209] gpu: change freq to 288, got 288
<4>[   95.673904] backlight resume!!
<6>[   96.074908] bt shouldn't shut off power, wifi is using it!
<4>[   97.711698] release all points!!!!!!
<4>[   97.731869] gpu: change freq to 552, got 426
<6>[   97.804086] enter rt5631_hifi_codec_set_dai_sysclk, syclk=11289600
<3>[   98.342399] init: sys_prop: permission denied uid:10055  name:sys.gvglk.version
<3>[   98.358696] init: sys_prop: permission denied uid:10055  name:sys.gvglu.version
<4>[   98.446284] ion_ioctl: alloc 0x1c8000 bytes, phy addr is 0x7a000000
<4>[   98.486483] ion_ioctl: alloc 0x1c8000 bytes, phy addr is 0x7ae61000
<4>[   99.635809] release all points!!!!!!
<4>[  100.853476] release all points!!!!!!
<4>[  101.125795] ion_ioctl: alloc 0x12c000 bytes, phy addr is 0x7a1c8000
<4>[  101.153443] ion_ioctl: alloc 0x12c000 bytes, phy addr is 0x7a3b3000
<4>[  101.890492] release all points!!!!!!
<4>[  102.582294] release all points!!!!!!
<4>[  107.234288] release all points!!!!!!
<6>[  107.335414] enter rt5631_hifi_codec_set_dai_sysclk, syclk=11289600
<4>[  107.403511] ion_ioctl: alloc 0x1c8000 bytes, phy addr is 0x7a3b3000
<4>[  108.235967] ion_ioctl: alloc 0x1c8000 bytes, phy addr is 0x7a000000
<4>[  108.415993] ion_ioctl: alloc 0xd000 bytes, phy addr is 0x7a1c8000
<4>[  108.484766] ion_ioctl: alloc 0x1c8000 bytes, phy addr is 0x7a57b000
<4>[  108.942282] ion_ioctl: alloc 0x114000 bytes, phy addr is 0x7a1d5000
<4>[  109.129025] ion_ioctl: alloc 0x114000 bytes, phy addr is 0x7a3b3000
<6>[  111.148488] enter rt5631_hifi_codec_set_dai_sysclk, syclk=11289600
<4>[  111.254492] release all points!!!!!!
<4>[  111.434729] release all points!!!!!!
<4>[  111.855520] release all points!!!!!!
<4>[  112.482757] gpu: change freq to 288, got 288
<4>[  112.493720] gpu: change freq to 552, got 426
<3>[  113.095390] init: sys_prop: permission denied uid:10043  name:sys.gvglk.version
<3>[  113.095551] init: sys_prop: permission denied uid:10043  name:sys.gvglu.version
<4>[  113.244020] ion_ioctl: alloc 0x44000 bytes, phy addr is 0x7a1d5000
<4>[  113.371611] ion_ioctl: alloc 0xd000 bytes, phy addr is 0x7a219000
<4>[  114.124722] release all points!!!!!!
<4>[  114.816141] release all points!!!!!!
<4>[  115.327268] release all points!!!!!!
<4>[  115.622776] ion_ioctl: alloc 0x44000 bytes, phy addr is 0x7a219000
<4>[  115.778161] release all points!!!!!!
<4>[  116.484527] release all points!!!!!!
<6>[  116.508329] enter rt5631_hifi_codec_set_dai_sysclk, syclk=11289600
<4>[  117.247449] ion_ioctl: alloc 0x114000 bytes, phy addr is 0x7a1c8000
<4>[  117.753687] ion_ioctl: alloc 0x13000 bytes, phy addr is 0x7a2dc000
<4>[  118.304798] ion_ioctl: alloc 0x114000 bytes, phy addr is 0x7a3b3000
<4>[  118.438393] release all points!!!!!!
<4>[  119.144846] release all points!!!!!!
<4>[  119.430436] release all points!!!!!!
<4>[  119.836324] release all points!!!!!!
<4>[  120.136940] release all points!!!!!!
<4>[  121.083738] release all points!!!!!!
u0_a58@android:/ #
Is this dmesg from my kernel together with Oma's JB?
I'll ask, because Oma told me that in his rom are extra configs for the bcm, without this special configs the wifi would not work.
Der ursprüngliche Beitrag von 11:11 Uhr wurde um 11:14 Uhr ergänzt:
Compile now was working?
JochenKauz schrieb:
JK, worked very well! Thank you very much for all your effort!
Reaktionen: JochenKauz
Yes, compile now, is working...
I have tested kernel with my rom, not with Oms's rom... sorry
Can I have Oma tricks for bcm wifi ?
thanks.
Glad to hear that.
I'm sorry, I don't know exactly what Oma included in his ROM for the BCM chip.
Best would be to try the rom first and look if it is working as expected, cause I know that wifi is working in Odys Xpress together with Oma's JB. The Xpress has a BCM chip too.
If it works, best is to ask Oma directly, cause I can make kernel, but have no idea of roms. Only thing I have seen, is, that the driver uses a firmware directory with firmware in it. Could be, that this is the point you are searching for.
You need to place at least the attached files into /system/etc/firmware.
:thumbup:
  • bcm43X9.7z
The firmware in post #178 is for BCM4329. For BCM4319 you will need the attached firmware.
:thumbup:
  • bcm4319.7z
Reaktionen: yattodettaman
