lmemperador
- 18
@JochenKauz
awesome...you are absolutely awesome.
Hmm.. but you can activate it without switching bluetooth on?lmemperador schrieb:ohhh...no luck this time, wifi is not working. it keeps getting the message "activating wifi" and no wifi networks are in the list
JochenKauz schrieb:Hmm.. but you can activate it without switching bluetooth on?
Then I can try to switch bluetooth off in this kernel, only for a try.
Do you have time for this test?
Finelmemperador schrieb:and of course, yes, i have time for testing...thx JochenKauz![]()
Yes, it should do. was not able to test it yet, but support is enabled.pais83 schrieb:your kernel support bluetooth?
JochenKauz schrieb:lets try the last one...
JochenKauz schrieb:Perfect!
Okay... hope you have another minute
As the last try... I will activate BT and only for your pleasure.. 1024MB
Okay?
JochenKauz schrieb:Here you go... please tell me if wifi is working correct, if not, I'll have to disable BT again and search for a solution, but that will take much more time.
