pais83
it could be great, i'm always looking for new soft to test... and a kernel is the top one
JochenKauz schrieb:Great!
Okay, then I can keep this kernel as a final version 0.1.
If you want or have fun testing a next kernel release, please tell me.
I'm in the beginning to have a merge with Astralix kernel, so we can form a kernel that is compilable for different RK2918 boards. That would make it possible to have only one source witch must be updated for future android versions.
pais83 schrieb:no, pascal 2 has another display size and resolution. this kernel is for rk2918 tablets with 8" 800x600 1gb ram
Der ursprüngliche Beitrag von 08:22 Uhr wurde um 08:24 Uhr ergänzt:
P.D: battery consumption is much better with your kernel![]()
I'm not really sure, but if the pascal 2 is a clone of the Odys NEO X7, you could give that kernel a try:lmemperador schrieb:do you mean that this future kernel could be flashed in a PASCAL 2 board too?
JochenKauz schrieb:I'm not really sure, but if the pascal 2 is a clone of the Odys NEO X7, you could give that kernel a try:
Spezifischer Kernel NEO X8/X7 mit Autorotation Fix
I've posted a Testkernel for the X7, witch has a 7" display with 800x480 512MB RAM.
You can try it with ICS, but I have never tested my X8 kernel with ICS, only with JB. I think the worst case would be that the akkufix and the rotation is broken.lmemperador schrieb:only one question, this kernels only works in jb roms isn't it? or can i try it with a ics rom?![]()
Does the pascal2 has 1024MB RAM too?pais83 schrieb:The only difference between pascal2 and kepler 2 is the display, the other hardware is the same
JochenKauz schrieb:You can try it with ICS, but I have never tested my X8 kernel with ICS, only with JB. I think the worst case would be that the akkufix and the rotation is broken.
Der ursprüngliche Beitrag von 15:40 Uhr wurde um 15:41 Uhr ergänzt:
JochenKauz schrieb:What I would need is a dmesg log from original kernel, is it possible for you to provide one?
On your rooted device, you install the app Terminal Emulator.lmemperador schrieb:i don't know how to do this, can you tell me an advice on how to make this dmesg log please.
su
dmesg >/mnt/sdcard/dmesg.txt
Pearl Touchlet X5? I thought it would be a Touchlet X7?Oma7144 schrieb:Just to clearify ;-)
Odys Neo X7: 7", 800*480 (16:9), capacitive touch, ft5x0x-TS, RTL8188 WLAN on USB2.0, MMA7660 Sensor, RT5631 Audio, GC0308 fCam, ANX7150 HDMI, HYM8563 Clock
~ BQ Pascal 2, Pearl Touchlet X5, yifang M712HC (OEM)
JochenKauz schrieb:Pearl Touchlet X5? I thought it would be a Touchlet X7?
No problem... here is a new X7 kernel, I hope that fixes the touch problem..lmemperador schrieb:due to touch problems i can not make the dmesg from your test kernel. maybe with the next kernel. typing with the keyboard is a madness...sorry
