[ROM] Mokee 4.4.4 z7 Max
  • 26 Antworten
freejess schrieb:
The second version of Mokee 28/08 also Multilanguage ... Concretely 2 roms are almost identical, which I prefer in Mokee is the effect of vertical scrolling ..
Thank you for that information, I don't noticed that newest version of mokee is also multilanguage.
Maybe then I change back to mokee these days, I hope it will also recognize my SIM correctly.
Hi! I only 2.46 Giga memory storage for applications on Mokee Rom ... It's possible to increase capacity?
On nubia forum I found some guides to change partitions, but google translation is to bad for this dangerous job.
Can you share the link please?
Warnung: cm11 nx505j II Edition.zip oder cm-11-20140901-lwang-nx505j.zip
There is unwanted system application included by author which is not part of CM.
APK: system/app/Statics.apk . Presents itself as System Server 1.4.2, package name com.system.analytics.cpa
Original:
CM11 NX505J for Z7 Max WARNING - Post #54 - XDA Forums
Reaktionen: mirakulixs
No update for mokee rom...???
Update auf Android 5?
choppaONE
Dr.med.Wurst
nait-chris
