Cheyenne
Stamm-User
- 188
Hab da bei XDA was gefunden, vllt. interessiert es den einen oder anderen.
Funktioniert super, macht trotzdem lieber vorher ein Backup.
Hier noch der Link zum Thread: XDA-Notification Bar Power Controls for any stock ROM
It's not fully my work - it's just port with some tweaks from Arctic 2.2.0.
Fully worked at SPU-12. Should work on SPU-9/11/15
How-to install:
1. Download NotifBar_TOGGLES_all_spu_v1_b01281118_stable.zip to your SD Card
2. Reboot into Recovery
3. Select "install zip from sdcard" > "choose zip from sdcard"
4. Choose NotifBar_TOGGLES_all_spu_v1_b01281118_stable.zip
4.1. If your ROM deodexed then go to advanced > Wipe Dalvik Cache
5. Enjoy!
Don't forget to do a nandroid backup!
