[ICS][GSM] Custom Roms 4.X [ICS-Kernel] [Bootmenu-Guide]
  • 408 Antworten
Hier zum vergleich das unveränderte Script, ich verstehe nicht wo der Fehler ist :/
Code:
ui_print(getprop("ro.product.device") == "umts_spyder" ||
       getprop("ro.build.product") == "umts_spyder");
show_progress(0.500000, 0);
ui_print("Formatting system...");
[COLOR="Red"]mount("ext3", "EMMC", "/dev/block/mmcblk1p20", "/system");[/COLOR]
delete_recursive("/system/app", "/system/bin", "/system/etc", "/system/fonts", "/system/framework", "/system/lib", "/system/media", "/system/tts", "/system/usr", "/system/vendor", "/system/xbin","/system/build.prop", "/system/default.prop","/system/multiconfig","/system/lost+found","recovery-from-boot.p","0");
ui_print("Installing system files...");
package_extract_dir("system", "/system");
ui_print("Creating system links...");
symlink("Roboto-Bold.ttf", "/system/fonts/DroidSans-Bold.ttf");
symlink("Roboto-Regular.ttf", "/system/fonts/DroidSans.ttf");
symlink("hijack", "/system/bin/logwrapper");
symlink("mksh", "/system/bin/sh");
symlink("motobox", "/system/bin/[", "/system/bin/cp",
        "/system/bin/getconfig", "/system/bin/masterclear",
        "/system/bin/md5sum", "/system/bin/mkswap", "/system/bin/ptf",
        "/system/bin/setconfig", "/system/bin/swapoff", "/system/bin/swapon",
        "/system/bin/test");
symlink("nvs_map_mac80211.bin", "/system/etc/firmware/ti-connectivity/wl12xx-fac-nvs.bin");
symlink("toolbox", "/system/bin/cat", "/system/bin/chmod",
        "/system/bin/chown", "/system/bin/cmp", "/system/bin/date",
        "/system/bin/dd", "/system/bin/df", "/system/bin/dmesg",
        "/system/bin/getevent", "/system/bin/getprop", "/system/bin/hd",
        "/system/bin/id", "/system/bin/ifconfig", "/system/bin/iftop",
        "/system/bin/insmod", "/system/bin/ioctl", "/system/bin/ionice",
        "/system/bin/kill", "/system/bin/ln", "/system/bin/log",
        "/system/bin/ls", "/system/bin/lsmod", "/system/bin/lsof",
        "/system/bin/mkdir", "/system/bin/mount", "/system/bin/mv",
        "/system/bin/nandread", "/system/bin/netstat",
        "/system/bin/newfs_msdos", "/system/bin/notify", "/system/bin/printenv",
        "/system/bin/ps", "/system/bin/reboot", "/system/bin/renice",
        "/system/bin/rm", "/system/bin/rmdir", "/system/bin/rmmod",
        "/system/bin/route", "/system/bin/schedtop", "/system/bin/sendevent",
        "/system/bin/sendevent2", "/system/bin/setconsole",
        "/system/bin/setprop", "/system/bin/sleep", "/system/bin/smd",
        "/system/bin/start", "/system/bin/stop", "/system/bin/sync",
        "/system/bin/top", "/system/bin/touch", "/system/bin/umount",
        "/system/bin/uptime", "/system/bin/vmstat", "/system/bin/watchprops",
        "/system/bin/wipe");
symlink("wl12xx-nvs.bin", "/system/etc/firmware/ti-connectivity/wl12xx-upd-nvs.bin");
ui_print("Set permission...");
set_perm_recursive(0, 0, 0755, 0644, "/system");
set_perm_recursive(0, 2000, 0755, 0755, "/system/bin");
set_perm(0, 0, 04755, "/system/bin/busybox");
set_perm(0, 10024, 0755, "/system/bin/hijack");
set_perm(0, 10024, 0755, "/system/bin/logwrapper.bin");
set_perm(0, 3003, 02750, "/system/bin/netcfg");
set_perm(0, 3004, 02755, "/system/bin/ping");
set_perm(0, 1001, 04770, "/system/bin/pppd-ril");
set_perm(0, 2000, 06750, "/system/bin/run-as");
set_perm_recursive(1002, 1002, 0755, 0440, "/system/etc/bluetooth");
set_perm(0, 0, 0755, "/system/etc/bluetooth");
set_perm(1000, 1000, 0640, "/system/etc/bluetooth/auto_pairing.conf");
set_perm(3002, 3002, 0444, "/system/etc/bluetooth/blacklist.conf");
set_perm(1002, 1002, 0440, "/system/etc/dbus.conf");
set_perm(1014, 2000, 0550, "/system/etc/dhcpcd/dhcpcd-run-hooks");
set_perm(0, 2000, 0550, "/system/etc/init.goldfish.sh");
set_perm(0, 0, 0444, "/system/etc/install-recovery.cfg");
set_perm(0, 0, 0544, "/system/etc/install-recovery.sh");
set_perm_recursive(0, 0, 0755, 0555, "/system/etc/ppp");
set_perm_recursive(0, 0, 0755, 0444, "/system/lib/egl");
set_perm(0, 0, 0644, "/system/lib/egl/libGLES_android.so");
set_perm_recursive(0, 2000, 0755, 0755, "/system/usr/bin");
set_perm(0, 0, 0755, "/system/usr/bin");
set_perm(0, 2000, 0755, "/system/vendor");
set_perm_recursive(0, 2000, 0755, 0755, "/system/vendor/bin");
set_perm(0, 2000, 0755, "/system/vendor/lib");
set_perm_recursive(0, 2000, 0755, 0644, "/system/vendor/lib/drm");
set_perm(0, 0, 0644, "/system/vendor/lib/drm/libdrmwvmplugin.so");
set_perm(0, 2000, 0755, "/system/vendor/lib/egl");
set_perm(0, 2000, 0755, "/system/vendor/lib/hw");
set_perm_recursive(0, 2000, 0755, 0644, "/system/vendor/pittpatt");
set_perm(0, 0, 0644, "/system/vendor/pittpatt/models/detection/multi_pose_face_landmark_detectors.3/left_eye-y0-yi45-p0-pi45-r0-ri20.2d_n2/full_model.bin");
set_perm(0, 0, 0644, "/system/vendor/pittpatt/models/detection/multi_pose_face_landmark_detectors.3/left_eye-y0-yi45-p0-pi45-rn7-ri20.2d_n2/full_model.bin");
set_perm(0, 0, 0644, "/system/vendor/pittpatt/models/detection/multi_pose_face_landmark_detectors.3/left_eye-y0-yi45-p0-pi45-rp7-ri20.2d_n2/full_model.bin");
set_perm(0, 0, 0644, "/system/vendor/pittpatt/models/detection/multi_pose_face_landmark_detectors.3/nose_base-y0-yi45-p0-pi45-r0-ri20.2d_n2/full_model.bin");
set_perm(0, 0, 0644, "/system/vendor/pittpatt/models/detection/multi_pose_face_landmark_detectors.3/nose_base-y0-yi45-p0-pi45-rn7-ri20.2d_n2/full_model.bin");
set_perm(0, 0, 0644, "/system/vendor/pittpatt/models/detection/multi_pose_face_landmark_detectors.3/nose_base-y0-yi45-p0-pi45-rp7-ri20.2d_n2/full_model.bin");
set_perm(0, 0, 0644, "/system/vendor/pittpatt/models/detection/multi_pose_face_landmark_detectors.3/right_eye-y0-yi45-p0-pi45-r0-ri20.2d_n2/full_model.bin");
set_perm(0, 0, 0644, "/system/vendor/pittpatt/models/detection/multi_pose_face_landmark_detectors.3/right_eye-y0-yi45-p0-pi45-rn7-ri20.2d_n2/full_model.bin");
set_perm(0, 0, 0644, "/system/vendor/pittpatt/models/detection/multi_pose_face_landmark_detectors.3/right_eye-y0-yi45-p0-pi45-rp7-ri20.2d_n2/full_model.bin");
set_perm(0, 0, 0644, "/system/vendor/pittpatt/models/detection/yaw_roll_face_detectors.3/head-y0-yi45-p0-pi45-r0-ri30.4a/full_model.bin");
set_perm(0, 0, 0644, "/system/vendor/pittpatt/models/detection/yaw_roll_face_detectors.3/head-y0-yi45-p0-pi45-rn30-ri30.5/full_model.bin");
set_perm(0, 0, 0644, "/system/vendor/pittpatt/models/detection/yaw_roll_face_detectors.3/head-y0-yi45-p0-pi45-rp30-ri30.5/full_model.bin");
set_perm(0, 0, 0644, "/system/vendor/pittpatt/models/recognition/face.face.y0-y0-22-b-N/full_model.bin");
set_perm_recursive(0, 2000, 0755, 0755, "/system/xbin");
set_perm(0, 0, 06755, "/system/xbin/busybox");
set_perm(0, 0, 06755, "/system/xbin/invoke-as");
set_perm(0, 0, 06755, "/system/xbin/su");
show_progress(0.200000, 0);
show_progress(0.200000, 10);
show_progress(0.100000, 0);
set_perm_recursive(0, 2000, 06755, 06755, "/system/xbin");
unmount("/system");
Kann ich die Webtop-Partition nicht auch einfach im Bootmenu formatieren?
Sonst müsste mir wer erklären wie ich das mit ADB Shell hinkriege... -.-
dhacker hat jetzt die Daten zum laufen bekommen bei CM9 ... -->
good news Thanks to @flavio_frow We now have data in CM9 for XT910 :) have to look at camera more but check it out
oh wie geil! freu mich schon :)
AdO089 schrieb:
Also stehen die Chancen für Black Window gut?
Das hat mit Black Widow nichts zu tun. CM9 wird für das GSM Razr entwickelt und Black Widow wurde/wird für das CDMA Razr entwickelt. Das heißt, wir brauchen einen GSM Patch
danke für den link.
ist es eigentlich möglich ein fertig eingerichtetes second rom zu sichern und es als 1st rom zu flashen? da muss man dann wahrscheinlich das update script wieder ändern odeR?
In Second System Recovery booten, Backup anlegen. Danach in Stock Recovery wechseln, Daten wipen und das Backup auf dieser wiederherstellen.
Gesendet von meinem XT910 mit Tapatalk 2
ohne update script ändern? das muss man ja wenn man es als second flashen möchte
Du flashst ja nicht. Da gibt es kein Update Script in einem Backup.
Reaktionen: inVi`--
Schon klar, aber da black Window auf CM basiert, hatte ja sein können dass das jetzt eine Leichtigkeit ist...
hätte aber ja sein können das man trotzdem was ändern muss, danke dir :cool2:
Wie kann ich eigentlich mein Razr Übertakten?
Schade das es durch die Bootloader Geschichte nur so wenige ROMs gibt...
Kann die DEVs da aber auch verstehen, ich werde mein RAZR nächste Woche eintauschen... einerseits weil ich mal wieder was neues haben will und andererseits auch etwas die Vorzüge einenes offenen BL vermisse ;)
...ge[RAZR]t via Tapatalk 2.
Ich hab das mal mit dem "Jelly Bean Animationen" probiert und iwie ändert sich da nichts.. also ich geh ins CWM -> mount & Storage -> mount system -> back -> install zip from sd card -> Jelly Bean Animationen.zip installiert dann -> Reboot Sytem now.. da kommt aber nichts .. also es ändert sich nichts
Dest du von Epsilon?
Die hat doch die JB Animation von haus aus drauf!
Du kannst sie dort nur auswählen, wenn du mal eine andere genommen hast, kannst du quasi wiederer zurück!
Oder irre ich? Epsilon hatte doc hdas x als Animation?
@all
Ich habe epsilon drauf, ud der Akku hält nur noch extrem wenig!
Bei Black Window habe ich schonmal 2 Tage durchgehalten udn war dann immernoch auf 30 % (habe on dieser Akkustatistik einen Screenshot, weil mir mal nicht geglaubt wurde als ich das gesagt habe) heute bin ich bei gleicher Nutzung am Abend bei 30 %. Mobile Daten traue ich mich garnicht erst ein zu schalten!
Durch die CM9 rom könnte ich evtl. einen GSM Patch für BW basteln..
Reaktionen: AdO089 und Slipi
Das wäre wirklich der Hammer :thumbup::cool2:
  • CMue
CMue
Bene26
  • Bene26
schuramura
  • steffenhellriegel
steffenhellriegel
