Summary for Droid Pro...
  • 1 Antworten
dettofatto
18
Sorry for my English, but I think that can be useful...
There are 2 Motorola Pro, but they are very similar (European/Argentinian Motorola Pro only GSM and American Motorola Droid Pro CDMA/GSM)……
We have discovered that you can swap the mod kernel and apply your preferred rom
And so…
If you have 2.2 (EU/AR/USA) or 2.3.3 (USA) you can put all rom/backup with specific kernel (see below).
But:
If you have American 4.7.3 (GB 2.3.4) without root, see here: http://forum.xda-developers.com/show....php?t=1556237 http://forum.xda-developers.com/show....php?t=1590489
If you have Argentinian 2.3.6 GB without root, see here: http://forum.xda-developers.com/show....php?t=1606353!). With this rom (from sbf installer) don't change your kernel!!! (2.3.6 argentinian) you can put this rom, http://www.droidforums.net/forum/dro...7-12-beta.html, without any kernel, or american backup 2.3.4, without any kernel. But anyway I've made a kernel and backup for putting this rom in our device. Before i've flashed (with sbf_flash under linux knoppix live cd) my verizon/american droid with argentinia 2.3.6 sbf, then i've applied the root and then i've done the backup... But I've bootloader error when i'm trying to restore my 2.2 backup and kernel... The Argentinian sbf have a lock bootloader (for now only argentinian 2.3.6, and american 2.3.4), and so I think that in all phones without lock bootloader, this trick go ok!
I think that this modified kernel don't lock your bootloader, but flashing your phone with that rom will lock your bootloader...
And so.. Remember you must put the specific kerenel with specific rom/Backup, see the scheme below:
A) European backup – only with Froyo Kernel
B) All roms, and all official American backup – only with American Kernel 4.7.3 (If you have anny issues you can choose also American kernel 4.6.8 http://www.mediafire.com/download.php?racmsfbovf6i8yt. But you can’t use this kernel with American 4.7.3 backup)
C) Argentinian Backup 2.3.6 - only Argentinian Kernel 2.3.6 Don't change your kernel if you came from this sbf (argentinian 2.3.6. sbf)! You can't put froyo kernel.
Steps:
1) Root with http://www.psouza4.com/Bionic/ or what do you prefer..
2) Install droid 2 bootstrapper from market, open the app click on the first button, say ok…
3) Choose and download your right kernel for right rom or backup, see below
(summary: While in recovery mode, and without rebooting at all:
...a) Wipe Data
...b) Install Radio Unlock (only if you are american user: http://forum.xda-developers.com/show....php?t=1365444)
...c) Install specific Kernel (see below)
...d) Restore specific Clockworkmod backup (you should have extracted the clockworkmod zip so the folder is located on your sdcard at [ie clockworkmod\backup\...] folder (with the system.img and other images under that folder))
5) Download them in your sd (kernel and rom are a .zip, backup is about five files that you must put on your sd under clockworkmod\backup\nameofbackupwithoutspaces.)
6) Reboot in clockwordmod choose backup and backup your data!!
7) Always in clockwordmod, choose install zip from sdcard and choose your kernel. Now we have 2 options, if you have choosed a backup to restore (7), or a rom to install (8)
8) If you have choosed a bckup Without reboot choose backup and restore and choose restore the new backup if you have choosed a backup, then wipe data.
9) If you have choosed a rom, choose install zip from sdcard and choose your rom, then wipe data
10) Did you make your backup? Did you have done wipe all data? Did you have choosed right kernel for right backup/rom?
11) Only now reboot Reboot!!
12) If You want unlocked gsm (for American users) see here… http://forum.xda-developers.com/show....php?t=1365444
13) If you are restoring your backup, don't wipe data, but remeber the right kernel for your backup...
14) For enabling gsm on ics see the attachment!!
- European Kernel: http://www.mediafire.com/download.php?3d4369udj1mii9z
- European Backup: http://www.mediafire.com/download.php?wn3pyy5fw3i1nr2
- American Kernel 4.7.3 http://www.mediafire.com/?swv4bl7wa47mpxg
- American Backup 4.7.3: http://www.mediafire.com/?yhr4b768qbnyote
- Argentinian Backup 2.3.6 GB: http://www.mediafire.com/download.php?od9zpccibsu3ocd
- Optional Roms - CM7 for Droid Pro (http://goo.gl/M6e4s) or Apex for Droid Pro (http://goo.gl/sTwSp), or Gummy ICS http://www.droidforums.net/forum/dro...7-12-beta.html, Or ICS 9 http://www.droidforums.net/forum/dro...droid-pro.html (all this optional roms want american kernel, or argentinian kernel)
Keymapping: http://forum.xda-developers.com/show....php?t=1565620
You can't reboot in recovery clockwordmod because you have installed a wrong rom (bootloop or you see only motorola's logo)?
Install droid exlorer on your pc and open (http://de.codeplex.com/releases/view/66510), plug in usb cable to your computer (have you installed the right drivers for adb?) reboot your phone (shift+alt+del), let to your computer (and droid explorer) to recognize your device, choose on droid explorer "tools > apply rom update > choose any little zip (also a fake zip, it isn't important!) on your pc > reboot and apply now...
Youre phone will reboot and you are on the standard recovery, press volume up and down together (or @) and choose reboot... Now you are in clockwordmod...
SBF: send me a private message (thank you. to me..?...)...
2.26.20 Verizon USA (Only english and spanish, root!)
2.26.60 Verizon USA (Only english and spanish, root!)
3.0.8.7 Verizon USA (Only english and spanish, root!)
2.3.3 Verizon GB USA (Only english and spanish, root!)
2.2.2 Argentinian and european (Only english and spanish, root!)
2.3.6 Argentine and European (Only english and spanish, root see here: http://forum.xda-developers.com/show....php?t=1606353!)
Credits:
JackpotClavin - for his rom and porting
Axl - Created the Droid2 Kernel which allowed me to use the same method for the Droid Pro (http://goo.gl/ErLAR)
dettofatto - Clockworkmod backup and kernel for European 4.7.3
JohnS - Clockworkmod backup and kernel for Verizon US 4.7.3
ngtwolf - For all
13th Angel - for his rom and porting
rodrigojfuentes - for rooting Argentinian 2.3.6
NOT MY FAULT IF YOU MESS UP SOMETHING....
attachment.php
Reaktionen: Elf, Tekkaro und Boogie
Updated...
black8900
  • derLU
PINTY
PINTY
vagasbunderos
V
