2.3.4 DE for you!
  • 109 Antworten
Yes, worked really fine yesterday and if you know CM 7 from the Milestone it is exactly the same - love it :)
very cool ROM, thank you very much!
9) if you have quertz keyboard: unzip and put these folders in /ststem/usr/
overwrite all and set permission to rw-r-r for all files and rwxr-xr-x for all folders
reboot...
quertz.7z
But I have just a short question for all: how do I change the querty keyboard to quertz? I understand I have to copy all files to /system/usr/, overwrite and everything. But when I did that my phone just restart after a while I was not able to set new permissions (chmod 644 and chmod 751) and now the keyboard is disabled... all I can do is restore a system.img backup. Or is possible to set the permissions via my computer? I would appreciate any help / hint to a solution. :sad:
Don't forget to set the permissions!
As I wrote: I was not able to able to set permissions as my phone restarted appr. 30 secs after I copied the files. I do not know why or how this happened. What did you use? A shell script to set them instantly? I used the Root Explorer to copy and then I wanted to set the permissions in a terminal emulator but then it restarted.
(Antworten gehen auf Deutsch, ich dachte nur falls hier jemand Englisch besser kann ;) )
Hey, ich hab die Recht direkt über den Root Explorer gesetzt. Langer Tastendruck und dann Berechtigungen :)
Dann neustarten und alles ist shiny
Just did it with the root explorer itself. Long push on the file and set permissions.
Ich probiere es mal auf dem Weg, mal schauen ob mein Pro dann wieder neu startet.
(I will give it a try, let's see if my Pro restarts again)
UPDATE: Funktioniert. Vielleicht wäre ein kleiner Hinweis in der Anleitung hilfreich, falls man den Root Explorer noch nicht kennt ^^ Danke dir!
(Worked. Maybe a short hint in the guide could be useful if some doesn't know the Root Explorer ^^ Thank You!)
habe das selbe Problem wie perpetuum.mobile aber ich habe die Berechtigungen gesetzt. Oder muss ich zuerst die Berechtigungen setzen und dann die Dateien kopieren, aber das geht gar nicht richtig?
Zweite Frage:funktioniert das Ganze auch mit dem CyanogenMod den dettofatto weiter oben erwähnt, habe aktuell den Mod drauf, und der ist wirklich wesentlich besser als die Version von dettofatto. Habe momentan smart keyboard drauf, weil ich gelesen habe, dass man hiermit den Fehler beheben kann, aber egal was ich einstelle, das z und das y tauschen sich nicht.
Habt ihr sonst noch eine Idee?
Yes, with CM you can do also.
Das originale ROM mit Froyo enthält ja nur den über Google zu syncenden Kalender. Befindet sich im hier vorgestellten ROM 2.3.4 auch ein integrierter offline Kalender, der mir den Umweg über Google erspart?
Hallo und guten morgen.
Ich bin ziemlich neu in der ganzen android-Materie und hatte heute das Problem, mein Droid Pro nach einer endlos-boot-Schleife mit einem SBF wieder auf Werkszustand flashen zu müssen.
Jetzt wollte ich in diesem Zuge gleich mal ein Update auf die hier besprochene 2.3.4 vornehmen. Leider verzettel ich mich dabei irgendwie, vermutlich mangels fehlender Spezial-Kenntnisse beim thema "Android-Upgrade".
Könnte mir mal bitte jemand verständlich erklären, wie ich von einer deutschen 2.2 - Version upgraden kann?
  • dettofatto
dettofatto
  • dettofatto
dettofatto
dettofatto
