2.3.4 DE for you!
  • 109 Antworten
Good Morning!
just another thing i have found:
it is not possible to send pics and so on directly to facebook, whatsapp etc.
Der ursprüngliche Beitrag von 07:52 Uhr wurde um 07:59 Uhr ergänzt:
Good Morning!
Anzeige
  • Gerade eben
  • Neu
Boogie schrieb:
Good Morning!
Good Morning!
Mmmm... Sure? I didn't try... But you don't see the specific app when you hit to "share"?
Yes, the normal Gallery says: "no connection to any application."
But i fixed that now with installing QuickPic - there it works fine ^^
Ah! Yes! I've removed a lot of stuff and so you must do the same things with other software...
For me it is better, because you can choose which app that you want!
For example quickpic is more fast and more light than stupid stock gallery!
Sent from My Motosola....
Yeah, there you are right ^^
Did you also remove the dictonary function? Because while texting it doesn't give me suggestions for words like fur = für etc.
Yes I suggest you smartkeyboard pro...!
The default dictionary is very poor...
Sorrry detto but are you kidding? ^^
You want me to install a virtual keyboard? I bought the Pro because i want to use a physical keyboard :p
I just tried it and the App only gives me suggestions if i really open it.
Will google the problem this afternoon, maybe i can find antoher solution :)
No, no you must see under option! There are a lot of settings for enabling suggestions with hardware keyboard...
aahhh... i must start thinking before writing... ^^
Thank you very much, works perfect!
I think that it is the best keyboard...
You can use also for your future phones...
New update....
0.3 (09/05/2012)
Replaced Calculator with other Multilanguages
Removed other stuff
Removed Global popup
Added a generic email client
Replaced zeam launcher with adw launcher
Updated market and gmail
Added new sms/mms program (multilanguages) and removed motorola conversation
Replaced motorola gallery with gallery 3d (multilanguages)
Added voicel dialer (multilanguages)
Other bugfixes...
See the xda topic, also for changelogs..
FOR ALL PRO/DROID PRO
(USA/Europe/Arg)
Dettofatto V.0.3 09/05/2012 98% translated...
But:
If you have American (all versions, but not the newest 2.3.4) or European (2.2 froyo) you must put the kernel below
If you have Argentinian 2.3.6 or american 2.3.4 don't change your kernel, but restore only backup......
I've added italian/deutch/french/Russian language and deoxeded... I've also removed a lot of stuff..
Make your backup before!
1) Download kernel and nandroid backup put on your sd card reboot into recovery
2) Install kernel KernelPROGB473.zip If you have Argentinian 2.3.6 DON't install any kernel, remain with yours!
3) Install (unzip and put under /clocwordmod/backup/) my backup from backup/restore and choose restore: I'm uploading..
You can choose also advanced restore and restore only system.... You can try...
4) Wipe all data, if you have any issues...
5) Reboot and now you can choose your language ...
6) Wait...
7) If you want enable cdma dial *#*#4636#*#* phone information and set cdma only or what do you want (I've removed global switch... Thanks to Artemide...!!)
8) If you want manage your account, with adw launcher create a shortcut to account settings in your home screen..
9) if you have quertz keyboard, rename the file, that you can find some post below in the zip file , from umts_venus2-keypad.kl to cdma_venus2-keypad.kl.
Copy in /system/usr/keylayout, overwrite and set permission to rw-r-r, with root explorer...
Reboot...
See here: [ROM] 2.3.4 En/Es/Ita/De/Fr/Ru Deodexed from standard 2.3.4 Verizon... - Page 2 - xda-developers
P.s.: If you want go back, you must put before your previous kernel...
And so if you come from froyo put this kernel KernelFroyoEu.zip and then put your nandroid backup (without wipe!)
If you come from American 2.3.4 or argentinian 2.3.6 don't change your kernel, only your backup (don't wipe data)
p.s.2: If you want edit your apk files use apk manager 4.9. (for editing blur stuff)
Put in folder "other" my files that you find in /system/framework moto-res.apk, framework-res.apk, blue-res.apk
open apk manager
type 22
choose your apk that you want modify/traduce (before you must put this in "place-apk-here-for-modding")
type 9
then go in project folder and modify your apk decompressed
then search in the same folder apktool.yml, open and modify with notepad from:
......usesFramework: ids: - 1- 3 - 2
to
.....usesFramework ids: - 1 - 2 - 3
then type 11
yes
yes
delete resources.arsc from keep folder and now rename your file from unsignedxxx.apk to xxx.apk move to your /system folder change permission to rw-r-r and move it in /system/app
mo
ATTENTION... for the file framework-res.apk you must copy always in /system, again set permission to rw-r-r, but then you must move in /system/framework and say yes to overwrite..reboot
Nice Nice, can't wait to come Home to test mit :D
On the xda i've added link!
Reaktionen: Boogie
Okay... got it loaded yesterday and since then it runs stable, no problems so far.
I already changed the keyboard to QWERTZ but i still have the problem with switched _ and 6. Will try to fix the data file at the weekend, hopefully ^^
I'm sorry.... ;-)
New Version:
0.4 (11/05/2012)
Build.prop improved
Changed stock notification
Added new alarm app (multilanguages)
New music app (multilanguages)
New video app (multil)
New camera app (multilanguages)
New calendar app (multilanguages)
Removed other motorola's stuff
A lot of thinng that I can't remember... But now it is very good!!
added zip fil for qwertz
Quadrant score is about 1900...
Gtlak...? No.. I've removed... (see the the second attachment...)
Really.... Install this and you'll see the differences..
[ROM] 2.3.4 En/Es/Ita/De/Fr/Ru Deodexed from standard 2.3.4 Verizon... - xda-developers
Will try Thema new Version After my holidays :)
But the current one ist also already very good, Top!
Gesendet von meinem DROID Pro mit Tapatalk 2
dettofatto schrieb:
New update....
New Version:
0.5 (17/05/2012)
Replaced Launcher
Build.prop improved
More translations
Removed other motorola's stuff and dependences
added tether
Zippalign on reboot
init.d added
a lot of script running
Memory tweaks
Added H symbol for gsm users
More fast
http://forum.xda-developers.com/show....php?t=1627435
0.3 (09/05/2012)
Removed other stuff
Other bugfixes...
(USA/Europe/Arg)
But:
6) Wait...
Reboot...
open apk manager
type 22
type 9
to
then type 11
yes
yes
mo
New Version:
0.5 (17/05/2012)
Replaced Launcher
Build.prop improved
More translations
added tether
Zippalign on reboot
init.d added
Memory tweaks
More fast
Der ursprüngliche Beitrag von 18:02 Uhr wurde um 18:02 Uhr ergänzt:
New Version:
0.5 (17/05/2012)
Replaced Launcher
Build.prop improved
More translations
added tether
Zippalign on reboot
init.d added
Memory tweaks
More fast
Reaktionen: Boogie
Hi!
Cool, will make the Update tonight :)
Andere i can tell, that the last version runs absolutely stable, very good job!
Oh no, page can not be found :(
failure 404...
EDIT:
Ah okay, just go via the link of an older version here ^^
