dj-7
Hat das Moto X 2014 eine Benachrichtigungs-LED?
Unterstützt es USB Otg?
android Lollipop now includes a similar feature, called Ambient Display, that displays notifications like those shown on the lockscreen.**If you prefer to try the new Ambient Display feature, you can uncheck the Moto Display setting in the Moto app.*Note: Ambient Display does not use Motorolas low-power core and will turn on more of the display, so battery life may be impacted. The Moto Actions Approach gesture will not wake Ambient Display.
