saintsimon
Dauer-User
- 415
- Themenstarter
- #21
Falls die LED gar nicht blinken will, so ist es ein altes Motorola-Phänomen, für welches Moto eine Lösung bereithält:
https://play.google.com/store/apps/details?id=com.motorola.ledwidget
How to fix the Moto G notification LED | Android Central
".. The glitch is a side effect of restoring from your Google account to the Moto G, which is part of the setup process for the phone. The feature downloads apps and settings from the cloud, which is usually a good thing. But in some instances it can tell the Moto G to restore the notification LED setting from another phone, leaving the light disabled with no way to re-enable it.
Fortunately there's a simple fix for this issue, and it's one that apparently applies to some other Motorola phones too ..."
. Ist das bei Euch auch so? Muß mann die Benachrichtigung für verpasste Anrufe irgentwo aktivieren? Mail (K9-Mail)- und SMS-Benachrichtigungen funktionieren, allerdings nur in weiß.
