Baumann
Stamm-User
- 262
CyanogenMod 9 - ICS Alpha 13:
Es wird weiter an ICS gewerkelt.
Vielen Dank an wrldsuksgo2mars, jokersax11 und das Photon dev team!
Ich möchte drauf hinweisen, dass es sich hierbei noch um eine Alpha Version handelt. Das flashen geschieht wie immer auf eine Gefahr hin!
Installation:
1. In die Recovery booten.
2. Ins Menü "mount and storage" gehen.
3. "format system" ausführen.
4. Zurück ins Hauptmenü und Data wipen.
5. Dann im "advanced menü", "reboot recovery" ausführen.
6. danach einfach wie immer die .zip flashen.
7. neustarten
DOWNLOAD:
Testbuild:
CM9-Atrix-alpha13-t8.zip
GoogleAPPS:
gapps-ics-v3.zip
Geht:
Geht Nicht:
Bekannte Bugs:
XDA:
[ICS] CM9 Photon alpha13 build for Atrix
Installation:
7. neustarten
DOWNLOAD:
Testbuild:
- Really early camera support (no connection problem to the camera, but still no image from both front and back camera)
- Fix gallery sync issue with Picasa and Google+
- Recompile build.prop
- Recompile boot.img
- Replace RomManager by RomToolbox
- Remove PinyinIME.apk from system app
- Added the latest default launcher version
gapps-ics-v3.zip
Geht:
- CDMA/GSM auto switching
- Calling
- Data
- Roaming
- Roaming data
- SMS
- MMS
- Compass
- Gyroscope
- HDMI portrait out
- Proximity sensor
- Wifi
- Bluetooth
- Calendar sync
- Maps
- Google earth
- YouTube HQ
- Games (sure I did not test them all)
- Gallery
- Movie editor
- Pic editor
- Touch screen
- USB mount
- Fingerprint sensor
- GPS (fix in tb4)
- Sound (fix in tb4)
- Orientation sensor (fix in tb4)
- Astro SMB and Bluetooth (added in tb5 Since there's no filemanager in ICS)
Geht Nicht:
- Adobe Flash (only some part work)
- Auto brightness
- Built in video playback
- HDMI landscape
- YouTube LQ
- Car dock
- Fingerprint unlock
- Webtop
- Hardware Acceleration
- Voice command
- Camera (obviously... like almost every ICS roms)
Bekannte Bugs:
- Gallery show a littlle graphic wiggle when changing screens due to the lack of Hardware Acceleration.
- The wifi does not work after the initial install, trigger the activation and reboot the phone, after that you will have no more problem.
- The Softkey light turn on after few minutes of use.
- Media scan not happening on boot.
- When the battery is full charged, the battery icon on the notification bar disappears. Because of this, it has another amazing function, it shows how much percent you have overcharged
(thanks to alistair3149)![]()
- Wallpaper is unscrollable in Trebuchet, use Nova launcher to use this function. It's a bug with the launcher (thanks to wywerny)
- Getting a random offset number during installation, due to a bug in the installation script (no to worry the install is completed when the offset happens). (thanks to munchkers13)
- Facebook sync dont work with ICS, you can use friendcaster (thanks to mitchell.23) or HaxSync.
XDA:
