[G920F] 5 way reboot menu
  • 1 Antworten
Leon73
Leon73
hallo,
gibt es das 5 way reboot menu separat ?
was ich auf ein stock gerootet g920f flashen kann ?
mfg
Schau mal hier.
[APP][6.0+] XTouchWiz | Customize your Stock Samsung Roms
Features:
- Fast PIN unlock
- Advanced Power Menu: Screen Capture/Record (Busybox required) and Reboot options
- Fake System status
- Disable TIMA/KAP
- Clock positions
- Call Recording
- Auto call recording
- Extended Multi-window support for all apps
- Skip Music track with Volume buttons long press
- Bypass Email Exchange restrictions
- Disable tether provisioning
- Disable battery level/temp checks while using Camera
- Disable wake on Home button
- Long back press to kill App
- Show Data usage
- Disable some annoying quick settings notifications
- Switch between LTE and 4G icon
- Hide Alarm icon
- Disable Adb during secured lockscreen
- Enable Message save and restore from sdcard
- And few other features
Reaktionen: Leon73
eSali
hanspampel
hanspampel
Leon73
Wicki
Wicki
O
  • opposmartjunkie
opposmartjunkie
O
