[APP][Inoffiziell][Xposed][ARM64][5.1.1/6.0.X] Xposed Port v87.1 for Samsung S6 LL/MM by wanam
  • 337 Antworten
Update
[UNOFFICIAL][5.1.1][02 Oct]Xposed for Samsung Lollipop
xposed-v74-sdk22-tw-arm64-custom-build-by-wanam-20151002.zip
xposed-v74-sdk22-tw-arm-custom-build-by-wanam-20151002.zip
xposed-tw-uninstaller-20151002-arm64.zip
xposed-tw-uninstaller-20151002-arm.zip
Changelog:v74 (02/10/2015
This update comes with XZ compression support, thanks to @rovo85 for pointing me to xz-embedded.
It should fix SPlanner, Samsung core apps and few other xz compressed System apps odexes...
Xposed will takes more time to decompress and recompile those apps, according to my tests, it takes 6 seconds to dexopt compressed S Planner odex with a size of 2.6MB/10MB, Samsung uses this compression type because of its low compression ratio to gain more space for more and more bloats
XDA-Thread
Reaktionen: maxe
Ich persöhnlich habe diese Version drauf, welche auch einwandfrei läuft.
Sie stammt aus dem XDA Thread.
[UNOFFICIAL][5.1.1][07 Oct]Xposed for Samsung Lollipop
xposed-v74-sdk22-tw-arm64-custom-build-by-wanam-20151007.zip - [Click for QR Code] (5.70 MB, 28 views)
xposed-v74-sdk22-tw-arm-custom-build-by-wanam-20151007.zip - [Click for QR Code] (3.39 MB, 22 views)
xposed-tw-uninstaller-20151007-arm64.zip - [Click for QR Code] (299.2 KB, 16 views)
xposed-tw-uninstaller-20151007-arm.zip - [Click for QR Code] (29
XDA-Thread
Changelog:
v74 (07/10/2015):
This update revert "disable must_relocate=false" and avoid the header image checks instead, as it seems the only change on previous version that may cause the random reboots reported by some users.I posted also a variant (under android_511_r19 folder) that is compatible with some newest FWs (OI9+ on GS6), these FWs comes with a new security commit introducing a new zygote parameter that breaks Xposed.
Die funktionieren auf der OI9 beide bei mir.
Was ist die "normale" bei dir?
Die "nomale" ist die offizielle, die Du im Post vor meinem reinkopiert hast. xposed-v74-sdk22-tw-arm64-custom-build-by-wanam-20151007.zip
Laut wanam und rovo läuft die garnicht, oder nicht korrekt mit der OI9 Firmware. Die r19 ist speziell für OI9.
Wie gesagt: Läuft auf meiner OI9 - ohne wenn und aber, probier es selbst.
LG
Bin noch nicht auf OI9 und auch wenn das bei dir, oder anderen augenscheinlich problemlos läuft, muss das nicht bei jedem so sein.
Es wird schon einen Grund haben, warum die Entwickler das so deutlich schreiben und daher gebe ich die Info selbstverständlich weiter.
Kann ja jeder für sich entscheiden, ob er sich dran hält, oder nicht. ;-)
Ich hab ihm schon vor ein paar Stunden geschrieben, dass sie tadellos auf dem S6 läuft.
Update
[UNOFFICIAL][5.1.1][08 Oct]Xposed for Samsung Lollipop
xposed-v75-sdk22-tw-arm64-custom-build-by-wanam-20151008.zip
xposed-v75-sdk22-tw-arm-custom-build-by-wanam-20151008.zip
xposed-tw-uninstaller-20151008-arm64.zip
xposed-tw-uninstaller-20151008-arm.zip
Changelog:
v75 (08/10/2015):
Updated to @rovo89 latest changes:
- Unified version to support old Roms and new ones that come with new app_process changes
- Disabled dex2oat watchdog
Check here for more details.
XDA-Thread
[DOUBLEPOST=1444301434,1444300426][/DOUBLEPOST]
Pitcher90 schrieb:
Mit der von Wicki verlinkten Version hatte ich Bootloops bei CarHDRom 12. Also lieber nicht ausprobieren ;)
Die liefen alle bei mir auf der CarHD.
Hast du vorher den Uninstaller genutzt?
Auf Original ROM mit UniKernel schon jemand getestet?
Und wenn ich schon die Vorgänger Version drauf habe installiere ich da einfach drüber oder muss ich die Alte vorher entfernen mit den Uninstaller?
Nicht 100 % Stock, aber sehr nah dran mit WanamLite odexed und UniKernel. Läuft prima.
Kannst Du einfach drüber flashen, ja, aber trotzdem vorher ein Backup machen ;-).
Im Angesicht der Bootloops der anderen Version, wie berichtet, ist ein Backup das einzig sichere... Danke!
Das sollte man sowieso immer machen. ;-)
Reaktionen: Megolk
Kann mir einer von euch sagen wo der Unterschied zwischen den arm und arm64 dateien liegt?
Welche brauche ich für das galaxy s6 mit vader rom v6?
Danke
Du brauchst die arm64.
LG
Edit:
Wenn du unter System > build.prop< nachschaust, dann siehst du auch deine Version.
64=64Bit=Galaxy S6
Danke
