kingoftf
Ehrenmitglied
- 46.016
Basierend auf Meizus OS Flyme, was wiederum auf CM13 basiert.
Also Android 6.0.
Gapps sind keine integriert, per Opengapps direkt mit flashen nach dem Flashen der ROM.
ROM ist Multi Language.
Thread auf leeco.re:
(05.19)Pro Flyme6.7.5.19R experience version
Features gemäß Google Übersetzer:
Precautions:
Dual card user recommended to configure the following settings, dial pad input * # * # 4636 # * # * - phone information - set the preferred network type-LAN / GSM / CDMA auto, and then restart
Dual card users can not use the data network solution: hot boot after a phone card, select the status bar of the SIM card has been replaced - select the mobile data SIM card, click once
Brush before upgrading to EUI5.8 / 5.9 bottom
Statement / thanks:
This ROM prohibits any form of secondary packaging. Pack party popular, exclusive results do not steal, please specify the source, thank you with.
Thanks to YC for BASE-CM
Update log
Meizu open source with Flyme6 Pile fit, based on cm13 fit, currently meet the daily experience
Repair the call to restart
Fix Reboot Card Boot Problem
Fix the camera into the library FC problem
Fix the input method icon resident status bar problem
Fix the connection to the computer and click the USB reboot problem
Repair settings for more than 2 alarm restart problems
Repair lock screen Variety wallpaper Gaussian blur effect
Optimize system stability to reduce probabilistic restart
Update source code to Flyme6.7.5.15R
Personal first Flyme6, to meet the needs of the experience
Fingerprints and basic functions are normal
Built-in root privileges and
Fix the problem of writing an exception to the NFC tag interface
Repair the calculator interface exception, display incomplete problem
Repair Toolbox The flashlight stops running
Fix the problem of invalid network control
BUG does not support telecom cards
Installation:
ROM und Gapps auf das X620 runterladen, Reboot in Recovery, Fullwipe, ROM und direkt danach gapps flashen.
Erster Start dauert Ewigkeiten, bis zu 10 Minuten, keine Panik.
Download:
MEGA
Screenshots:
Also Android 6.0.
Precautions:
Statement / thanks:
Update log
Installation:
Download:
MEGA
Screenshots:
