kingoftf
Ehrenmitglied
- 46.016
Hier eine neue AOSP, bisher ohne Bugs, flott und nur 600 Mb groß
Nach der Installation ist erst mal alles in Chinesisch, durchhangeln Settings und die Weltkugel, da ganz oben kann man die Sprache verstellen.
[MTK X20 ROM] music as 2 / Pro AOSP native system optimization version supports fingerprint infrared stable and smooth 7/9/5
乐视2/Pro AOSP原生系统优化版 支持指纹红_最新最全的ROM刷机包ROM刷机包下载、刷机教
Features laut Google:
Google native ROM;
Baseband, signal, bluetooth, wifi, camera are normal;
Display, dual card, call, mobile Unicom Telecom are normal;
Camera, sensor, breathing light, keyboard lights are tested;
Fingerprint recognition test is normal;
Infrared remote control test is normal;
Fast charge test is normal;
Timing switch machine test is normal;
Screen color temperature test is normal;
Default use Arrow desktop;
Default modified DPI to 440;
The default support for call attribution;
Default built-in root privileges;
The default to add Viper sound, has been activated;
The default support for split-screen mode, the developer mode to open the 'multi-window mode', the task manager to open the split screen;
Update the file manager
Merge part of the program ODEX, reduce ROM volume;
Built a few gadgets;
More features to experience
Download
MEGA
Screenshots:
Google native ROM;
Download
MEGA
Screenshots:
