kingoftf
Ehrenmitglied
- 46.016
Hier eine neue MIUI-Version von Wazl, diesmal gnädigerweise als "Poland", sprich mit etlichen Sprachen zur Auswahl.
Kommt wie immer ohne gapps.
Android Patch ist von 5/12/17
Face Unlock funktioniert laut Beschreibung, kommt, wie bei Wazl üblich, mit Leeco Stock Kamera (28s Version)
乐视2 波兰MIUI9.8.1.6 人脸速充 核心省电_最新最全的乐2/乐2 ProROM刷机包下载、刷
Features laut Google Übersetzer:
MEGA
- Polish version
- New code power calibration
- New Core Schema Visual GPU Mode Optimized
- Add Xposed activation uninstall does not like to use, you do not need to activate it!
- Temperature control manual restart better
- Update pull-down 5 fast
- Add transition animation two
- Status bar virtual key settings
- Fast charge method: plug the charger, bright screen - off screen - bright screen - off screen
- Resolution power saving program
- About resolution: 720P can be used with the DPI300 280 can be used to display a better default theme display incomplete, you can change the other theme, perfect display!Other self-test the best value
- Transport storage cleaning more smooth
- Face unlocked
- WeChat Video Can not Shoot Problem has been fixed
- Black-field usage: can be used directly, if you can not use, click on the activation wait for the black box to open automatically
- Please ensure that your bottom is EUI5.9 This communication will be more perfect
- Support xposed various modules can be used as appropriate
- Add time to display Lunar New Year and other styles
- Meizu suspended ball: down to open the status bar / slide left and right to open the taskbar / slide back to the desktop, other features under development .....
- Support infrared
- Exclusive music as the camera
- King glory tips: advanced settings
- Upon discovering the contents of this advanced setting must be:
- Multiple animation elements
- Shake / Swipe / Double-click the status bar lock screen and other definitions
- cpu set new performance mode, support for manual control of the core! Support boot from Kai! Prohibit theft without permission!
- Screen assistant, support for screen shots
- Freeze, uninstall arbitrary use
- LCD global size adjustment
- MIUI features switching: desktop layout, time-centered
- WiFi password check
- Increase millet store recovery, please restore in other additional settings, manual restart to take effect
MEGA
