kingoftf
Ehrenmitglied
- 46.016
Hier ein neues ROM vom chinesischen Dev Wazl
Basis ist AOSP 6.0
http://bbs.ydss.cn/forum.php?mod=viewthread&tid=995684&extra=page=1&filter=typeid&typeid=3357
[MTK X20 ROM] [AOSPV3] Andrews 6.0 core xposed floating ball double row speed | shaking lock screen sliding brightness | IOS animation fingerprint infrared
Features laut Goggle:
ROM introduction
【note】
1. Brush before, please back up your own Nvram partition, no matter what package you brush, brush who package!
3. Built a small amount of promotional software, do not need to uninstall, can not accept the promotion of the other brush! The
Other optimization:
Developers / off animation & open Gpu rendering & background process limit no more than 4
I repair bugs, are driven one by one investigation, spend a lot of time with the energy, apply the party please specify! Otherwise found by the depth of investigation
Download Link
MEGA
Basis ist AOSP 6.0
ROM introduction
- Thanks to the big bottom package
- Team exclusive transplant production, prohibited reference extraction!
- Two desktop styles
- The feedback on the oil is updated as follows:
- Increase the temperature of the forced shutdown of the phone
- Double line speed display
- The flashlight can be set to advanced settings
- Modify the key vibration logic
- Optimize the fingerprint code
Optimize the camera, I test everything is normal, if there is Caton, clear the background can be
Optimize remote controller initialization failure
MZ suspension ball, pull down more convenient
IOS animation - Advanced settings update
- Mainly maintain official stability
- Promotions can be uninstalled by the re manager
- After testing, ROOT authority is normal
- Percentage of electricity displayed
- Dolby
- Freeze unloading
- CPU content
- Advanced settings are implemented using code, not bundled with a large number of apk
- Dat format brush machine, better authority
- Pull down the lunar display
- Optimize init.d permissions
- Integrated busybox instruction set
Past Update: - Advanced settings, misappropriation!- Screen assistant
- Strong unloading
- Power menu
- CPU parameter settings, control of heat, manual control core
- Go directly to the developer option
- Time to stay in the next period to add
- Self-opening management
- Status bar advanced settings
- Slide brightness adjustment
- Shake set
- Please click on the specific function
- It is so simple, brush into the experience
【note】
Other optimization:
Download Link
MEGA
