kingoftf
Ehrenmitglied
- 56.174
Vom gleichen spanischen Dev der 23s multi hier die Version auf Basis der 26s.
Wie auch bei der anderen Version inklusive gapps und einem separat zu installierenden Patch, um das ROM Multi-Language zu machen.
NUN AUCH BACKUP MÖGLICH!!!
Features:
ROM cooked with ASSAYYED.
Translation patch needed to be put into multi language.
ROOT
BusyBox
Zippaling
No Deodex (due to errors in the installation)
Liteada (deleted all unnecessary APPs.)
Sqlite
Added Google app (Play Store, Keyboard, Gmail, Calendar, Calculator ...)
Added VLC app, QuickRebbot (recovery) New Launcher, Sony Wolkman Player, Es Explorer PRO. All these can be uninstalled if you do not like it.
Added LOGO Spanish and BootAnimation International.
Xposed Installer
AdBlock Reborn (required xposed module installed).
Added support for WallPapers and Animated Backgrounds (in the previous 23s I did this did not work).
Added Launcher LeEco.
Added LeEco Browser (This I added because it is the one in charge of the native QR Code Scanner that comes in the multi-task button.) I recommend unlinking it with
Installation instructions:
Restart in recovery TWRP 3.0.2
Make Wipes: Data, Cache and Dalvik as minimums (for this it enters the recovery in Wipes and slides to the right.)
Install LeEco ROM Le 2 X620 5.9.26S06.141 r2.0 by_WoRFReD.
Reboot and leave about 10 minutes to boot.
Finish the initial configuration and get to the launcher.
Then go to the SuperSU and open it. Choose a new user.
Then open the Quick Reboot application and give SuperSU permissions.
Restart in Recovery.
Once in recovery now if NO WIPES NO CLEAN NOTHING (NOT WIPE) install the MULTI LeEco Patch Le 2 X620 5.9.26S06.141 r2.0 by_WoRFReD
Now if you want
NOTE: Install "Google Play Services" as soon as possible so that you do not get errors.
Nach der Beendigung der Konfiguration Google Play Service Update durchführen, sonst kann es zu Fehlern kommen.
Download ROM und Patch
MEGA
MEGA
Erster Boot dauert Ewigkeiten, nicht verzweifeln, irgendwann geht es.....
Features:
ROOT
BusyBox
Zippaling
Sqlite
Xposed Installer
Now if you want
MEGA
MEGA
