[RECOVERY] ClockWorkMod Recovery
  • 563 Antworten
teddy3
teddy3
Dauer-User
283
Frisch aus der Chainfire-Bäckerei:
Chainfire schrieb:
If you just want to get your device rooted ASAP, see this thread instead: CF-Root. It includes this recovery in it's installation, and automatically installs root. This thread is for the recovery only.
Check your device model ! Settings -> About device -> Model number. This stuff is made for the GT-I9300 and GT-I9300T, if your model number has a suffix, it may not work, or if it is a totally different model, it will not work (may even brick) !
Not compatible with ROM Manager ! Use the CWM Manager provided instead.
Here's my port of CWM 5.5.0.4 to the SGS3. There's a second version number in the thread title, as I think there will be multiple versions.
As is the case with every SGS release (it happened with the SGS1 and the SGS2, and now again with the SGS3), CWM source isn't built to correctly deal with our setup (internal storage vs sdcard). I had to make a number of changes to the source to get it working correctly. From my tests, it all seems to work, but it's quite possible I missed something (report issues).
(I have tested backup/restore to both internal and external storage, wipes, installing zips from both internal and external, etc, all works as I expect it to)
Aside from the base fixes, there is currently nothing fancy about this build of CWM. I'm not sure if the SGS3 suffers from the brick bug (that SGS2 and Note have), but I patched out the relevant code to be sure (I think). Backups are rather big, system alone is about a GB.
I'll do more some other day!
Instructions - Short
Extract the attached CF-SGS3-CWM-vX.X-vY.Y zip file, to get the tar file you can flash in Odin as PDA.
Instructions - Long
- Follow these instructions to the letter. Do not touch any buttons or checkboxes that are not listed below to touch!
- Unzip the attached Odin3-vX.X.zip file
- Unzip the attached CF-SGS3-CWM-vX.X-vY.Y.zip file
- If you end up with a recovery.img file, you've extracted twice. You need to end up with a .tar file - don't extract that one
- (USB) Disconnect your phone from your computer
- Start Odin3-vX.X.exe
- Click the PDA button, and select CF-SGS3-CWM-vX.X-vY.Y.tar
- Put your phone in download mode (turn off phone, then hold volume-down + home + power to boot - if it asks you to press a button to continue, press the listed button)
- (USB) Connect the phone to your computer
- Make sure Repartition is NOT checked
- Click the Start button
- Wait for the phone to reboot
- Done (if it took you more than 30 seconds, you need practise!)
New to Samsung? Unfamiliar with Odin? Think all the above is a hassle? Get used to it. It's very simple, and us Samsung folk use Odin (or Mobile ODIN
) for everything! It's so very very convenient once you get used to it.
Navigation
In recovery, use the volume buttons to move up/down, power or home button to select, and back to go back.
Manually rooting
Note: if you're just flashing CWM to root, it is easiest to follow this thread instead: CF-Root. It includes this recovery in it's installation, and automatically installs root.
Applying root once you have this recovery installed is easy.
- Go to the SuperSU thread and download the CWM-SuperSU-...zip file attached to the first post
- Put the zip file on your sdcard (either internal storage or external sdcard will do)
- Put your phone in recovery mode (turn off phone, then hold volume-up + home + power to boot - release power after one second) - Alternatively, use the "adb reboot recovery" command
- Select "install zip from sdcard"
- Select "choose zip from sdcard" or "choose zip from internal sdcard" (depending on where you put the zip)
- Select the CWM-SuperSU-...zip file
- Done !
Root in ADB
If you root through recovery and are not running a custom kernel, chances are that ADB does not have root when Android is booted. You can enable root in ADB even on stock kernels by using the adbd Insecure app. This does require the device to be rooted!
When flashing a new firmware ...
... you probably want to keep recovery. Most stock firmwares include the stock recovery, so if you flash those with Odin this recovery will be overwritten. Alternatively, if you are using Mobile ODIN to flash, first open the firmware files you want to flash using the "Open file ..." entry (sometimes several times), then select the "Recovery" entry and press the "Clear" button in the popup. This way, recovery will not be overwritten.
CWM Manager
Also attached is CWM Manager, a tool I wrote to manage my CWM kernels and recoveries. Download the APK to your device and open it to install. You may need to go to Settings -> Security -> Device Administration first and enable Unknown sources.
Note that v1.1 or newer of my CWM build is required to use CWM Manager.
Flash counter
To reset the flash counter to 0, see the Triangle Away thread.
OTA's
Since v1.5, flashing OTA updates is supported directly using this recovery. You should however be aware that said OTA will most likely re-install stock recovery and remove this one. Furthermore, it may keep doing so every time you boot. CF-Root v6.3 (and newer) will try to disable this, it is advised you flash that. Just reflashing this CWM recovery will likely not help.
Downloads
CF-SGS3-CWM-v5.5-v1.5.zip
CWMManager-SGS3-v3.60.apk
Original bei xda: [RECOVERY][31.05.2012] ClockWorkMod Recovery 5.5.0.4 - "v1.0" - xda-developers
Changelog:
v1.5: Now supports flashing OTA updates as well. But flashing an OTA may overwrite recovery. You need to re-flash CF-Root after an OTA to get CWM back - just re-flashing recovery will likely not work, unless you manage to boot into recovery immediately after flash, before Android starts
v1.4: now with larger text, CWM Manager updated to "v3.60", which should not properly work on the GT-I9300T as well
v1.3: Should take care of the occasional mount issue. Let me know!
v1.2: exfat is now supported in recovery!
v1.1: -
Installation:
- Flashen per Odin in PDA oder
- Flashen per Mobile Odin über die Funktion "Open file..."
Detailierte Flashanleitung hier: https://www.android-hilfe.de/forum/...itung-fuer-das-galaxy-s3-via-odin.249239.html :)thumbsup: Android-SGS)
FAQ:
Kann ich mit hiermit auch OTA Updates von Samsung erhalten?
Seit v1.5 ja!
Kann ich ein Backup auf einer große externe SD-Karte speichern, die mit exFAT formatiert wurde?
Seit v1.2 ja!
Kann ich Backups, die mit v1.0 oder v1.1 erstellt wurden, mit v1.2+ wiederherstellen?
Ja.
Ich bekomme beim Versuch ein Backup zu erstellen die Fehlermeldung "Can't mount backup path.". Was kann ich tun?
Du musst die SD-Karte zuerst mounten. Dazu gehst du in CWM in den Punkt Mount and Storage und dort auf den Punkt mount SD-Card. Nach Bestätigung ist die Karte gemountet und du kannst das Backup erstellen.
  • Odin3-v1.85.zip
  • CWMManager-SGS3-v3.60.apk
  • CF-SGS3-CWM-v5.5-v1.5.zip
Reaktionen: Sossy, craP_cillA, mobilkom und 14 andere
ist da root auch schon mit dabei?? oder muss man noch extra rooten...
sorry...war im letzten jahr nur noch auf semaphore...(i9000)
Root und Recovery überschneiden sich nicht
kein root...nur das cwm
Reaktionen: CMcRae
Root und CWM kann man unabhängig von einander flashen. Das eine hat mit dem anderen nichts zu tun. Wer Root braucht muss rooten, wer CWM braucht muss das flashen, wer beides braucht muss beides flashen.
Der ursprüngliche Beitrag von 01:26 Uhr wurde um 02:58 Uhr ergänzt:
Kleines Update:
Bei mir funktioniert die Installation ohne Probleme. CWM lässt sich öffnen, backup kann ich allerdings nur auf den internen Speicher machen. Beim "normalen" Backup kommt die Fehlermeldung: "Can't mount backup path". Ich hab das mal im xda gespostet. Hat das Problem noch jemand?
Gestern hab ich gelesen, dass CF noch Probleme mit beiden Möglichkeiten hat. Er kann es momentan nur für eine der beiden Speicherbereiche realisieren.
Ich denke "beide" werden noch etwas dauern.
also das originale recovery vom chainfire mounted beide sdkarten.
Gerade gemerkt, dass sich der Counter um 1 erhöht.
Wurscht, ich sag's nur.
Mein Counter steht schon bei 2 :cursing:
gerade problemlos mit mobile odin geflasht. counter wurde nicht erhöht.
Die CWM funktioniert schon besser. erkennt problemlos interne und externe sd karte
Wer sich hier die CWM geflasht hat kann auch einfacher zu Root kommen: supersu.zip von XDA saugen auf die interne legen und im Recovery Mode installieren.
BOOM ROOT ;)
Gesendet von meinem GT-I9300
aber muss man nicht eh zuerst root haben bevor man das cwm flashen kann?
Nein, du flasht das Recovery über Odin als *.tar File.
Interessant, also funktioniert die CWM auch ohne Root?
Dann wäre das ja aktuell die einfachste Methode für Root oder? CWM via Odin flashen und dann die supersu.zip via CWM? Das hört sich doch nach meinem ersten Video an am Samstag :D Was meinste Android-SGS?
ahja gut über odin am pc gehts natürlich. für mobile odin braucht man root
So sollte es laut Chainfire gehen ;)
Ich werde mal die Root Anleitung anpassen..
Kann mal bitte jemand ein kurzes Howtodo schrieben. Hatte noch kein Samsung Smartphone und kenne mich nicht so aus mit Odin und wie ich beim Samsung in den CWM komme. Vielen dank.
Gesendet von meinem Optimus 2X mit der Android-Hilfe.de App
Folge meiner Signatur, habe kurz die "einfachere Methode" eingefügt, die ADB Methode ist aber immer noch dabei (wer will...)
Reaktionen: Muck11, eagle1977 und chrissi77
Wenn ich mir root mache hat das schon Einfluss auf den counter? Oder erst wenn ich eine custom rom flashe ?
Counter geht beim rooten hoch (+1)
Bei normalen Samsung Firmwares bleibt er gleich
Es wird irgendwann die Möglichkeit geben den Counter zu resetten
