Y
yank555
Gast
- Themenstarter
- #1.801
So, dann wieder hier und vor allen anderen auf xda, gibt es den 3.1'er Kernel zu testen ![Blinzeln ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Es ist noch kein offizielles Release, wenn aber alles passt, wird er morgen offiziell released !
Ist alles noch ganz frisch, kompiliert wurde er gerade erst um 21:46:09 heute abend![Grinsendes Gesicht mit offenem Mund :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Changlog :
Download Link
MD5 : c148f18c60599e6d7354e324ce80bcc6
JP.
Changlog :
- Samsung JB Update 7 sources (Linux 3.0.31)
- updated to kernel.org Linux 3.0.58
- using XXELLA ramdisk
- swap support
- zram support (Android optimized)
- /proc/config.gz support
- optimized for size
- ntfs (rw) support (kernel support only)
- Forced Fast Charge v1.2a
- CPU OC up to 1.6GHz
- Triangle away support
- dynamic fsync support (faux123)
- TCP westwood congest ctrl (faux123)
- Proport. Rate Reduction TCP (faux123)
- ARM AES/SHA1 (faux123)
- JIT compiler for packet filters(faux123)
- fix ipv6 protocol lookup (faux123)
- ipv4 check ret.val. dst_alloc (faux123)
- ipv6 check ret.val. dst_alloc (faux123)
- updated LZO compression (faux123)
- do_fsync() to fget_light() (faux123)
- disabled mali state tracking (AndreiLux)
- reduce mali utilization sampling timeout (AndreiLux)
- added SIO scheduler
- added ROW v4 scheduler
- black crush fix (AndreiLux/AndiP71)
- added lulzactiveq CPU governor
- sysfs interface to delay fsearlysuspend (Yank555.lu, base idea Codeworkx)
- Boeffla-Sound: Engine 1.4.3 (AndiP71) - Huge thanks for offering me to include his hard work and great sound engine
Download Link
JP.
